APWorkbench套件使用FTDI驱动程序与硬件进行通信
http://www.st.com/web/en/catalog/tools/FM116/SC1028/PF253187
,通过USB。
如果必须运行使用APWLink的评估板,则需要安装驱动程序(通常都是http://www.st.com/soundterminal
放大器板)。 MEMS麦克风评估套件不需要FTDI驱动器,因为它使用不同的USB接口,http://www.st.com/web/en/catalog/tools/FM116/SC1028/PF258331
可以从FTDI网站(D2XX版本)下载更新的驱动程序:
http://www.ftdichip.com/Drivers/D2XX.htm
注意:安装FTDI驱动程序需要管理员权限。
以上来自于谷歌翻译
以下为原文
FTDI drivers are used by APWorkbench suite to communicate with the hardware
, via USB.
Driver installation is required in case evaluation boards using APWLink have to be operated (typically all http://www.st.com/soundterminal
amplifier boards). FTDI drivers are not required for MEMS Microphone evaluation kit since it makes use of a different USB interface, http://www.st.com/web/en/catalog/tools/FM116/SC1028/PF258331
Updated drivers can be downloaded from FTDI website (D2XX version):
Note: admin rights are required to install FTDI drivers.
,通过USB。
以上来自于谷歌翻译
以下为原文
, via USB.
