这两个位可以通过冲击成功配置到FPGA中,现在我使用黄金映像和多重启动映像分别生成两个mcs,多启动mcs可以下载到FPGA并启动良好,但黄金mcs失败,配置完成
编程后信号保持低电平且影响信息失败。
我还是不知道为什么,BitGen选项的每一步都来自本william hill官网
的其他经验,我已经阅读了SP605的数据,但我无法获得任何有用的信息来生成正确的位或mcs
方式.....所有我学习的是在这个william hill官网
和spartan6配置数据表。
所以你能告诉我在ise中产生正确的黄金位的正确方法吗?
(引导我产生一个正确的金色mcs)
你提到我是否在生成多重引导mcs时在影响中添加了带有黄金位的标题,等待....当我在ise中生成黄金位时(在BitGen选项中设置黄金开始地址和下一个配置地址),
是不是包含在黄金位中的标题?
或者头文件是独立的,应该分别添加黄金图像和多重启动图像?
影响中的mcs数应该是3?
那是我第一次做多重启动,我觉得有很多东西我都不知道......
不管怎么说,还是要谢谢你!
以上来自于谷歌翻译
以下为原文
the two bits can be config into the FPGA by impact successfully, now i use the golden image and multiboot image to generate two mcs respectively, the multiboot mcs can be download into FPGA and boot well, but the golden mcs was failed ,the config done signal keep low after the programing and the message on impact is failed.
i still don`t know why , every step of the BitGen option is from other`s experience in this forum, i have read the SP605`s data, but i can`t get any useful information for generating the bit or mcs in right way.....all i learn is on this forum and spartan6 config datatsheet.
so could you show me the right way to generate the right golden bit in the ise ? (lead me to generate a right golden mcs)
you mentioned if i add the header with golden bit in the impact when i generate the multiboot mcs, wait.... when i generate the golden bit in the ise (set the golden start address and next config address in the BitGen option), isn`t the header included in the golden bit? or the header file is independent which should be add with the golden image and multiboot image respectively ? the mcs number in the impact should be 3 ?
that`s my first time to do the multiboot, i think there are a lot things i don`t know...
thanks anyway!
编程后信号保持低电平且影响信息失败。
和spartan6配置数据表。
(引导我产生一个正确的金色mcs)
是不是包含在黄金位中的标题?
影响中的mcs数应该是3?
不管怎么说,还是要谢谢你!
以上来自于谷歌翻译
以下为原文
thanks anyway!
