Cypress技术william hill官网
李韵
7年用户 201经验值
GSM调制解调器与PSoC 3接口是否有应用说明
GSM调制解调器与PSoC 3接口是否有应用说明。首先,我想将GSM调制解调器与PSoC 3接口,并通过发送和接收简单的文本消息与HythMetime通信
以上来自于百度翻译
     以下为原文
  Is there any application note on interfacing GSM modem with PSoC 3. primarly i want to interface the GSM modem with PSoC 3 and communicate with Hyperteminal by sending and recieving simple text messages.
回帖(7)
郭雨桐
2019-7-22 08:11:19
我们没有任何项目或应用笔记的GSM调制解调器。然而,很容易通过UART将任何GSM调制解调器与PSoC接口。任何GSM调制解调器都可以接受来自PSoC的命令。这些命令被称为AT命令。不同的AT命令从PSoC发送到GSM调制解调器的解释不同,调制解调器执行适当的操作。因此,与PSoC接口的GSM调制解调器的一种可能实现是将GSM调制解调器连接到PSoC的RX和TX线路并发送AT命令。每个GSM调制解调器数据表提供了一组调制解调器可以接受的AT命令。通过这个数据表,并从PSoC发送这些命令。
以上来自于百度翻译
     以下为原文
  We do not have any project or App Note for GSM modem. However, it is easy interface any GSM modem with PSoC via UART. Any GSM modem can accept commands from PSoC. These commands are called AT commands. Different AT commands sent from PSoC to GSM modem is interpreted differently and the modem performs suitable operation. Hence, a possible implementation to interface GSM modem with PSoC is to connect, the GSM modem to RX and TX lines of PSoC and send AT commands. Each GSM modem datasheet provides a set of AT Commands that the modem can accept. Go through this datasheet and send these commands from PSoC.
马昱
2019-7-22 08:28:47
嗨,Cbraj,
您可以下载UART上的一个示例项目,并修改它来发送ATM命令来发送和接收来自GSM调制解调器的文本消息。
您可以将GSM调制解调器连接到PC机,通过超终端发送和接收文本消息。在这种情况下,UART用于GSM调制解调器和PC.之间的通信。
当您与PSoC连接GSM调制解调器时,您正在用PSoC替换PC,以便UART用于通过PSoC向GSM调制解调器发送AT命令。
以上来自于百度翻译
     以下为原文
  Hi Cbraj,
    You can download a sample project on UART and modify it to send AT commands to send and receive text messages from GSM Modem.
    You can connect the GSM modem to a PC to send and receive text messages via Hyperterminal. In this case UART is used for communication between the GSM modem and PC.
    When you are interfacing the GSM Modem with PSoC, you are replacing the PC with PSoC so that the UART is used to send AT commands to GSM modem by PSoC.
王琳
2019-7-22 09:11:19
你使用开发工具包吗?哪一个?你使用的是哪个版本的创建者????
鲍勃
以上来自于百度翻译
     以下为原文
  Are you using a development kit? Which one?? Which version of Creator are you using???
    Bob
陈洁
2019-7-22 09:21:33
先生我用Axios 1.0 psoc5基础开发包,其PSoC Creator 2.2
以上来自于百度翻译
     以下为原文
  sir im using AXIOS 1.0 PSOC5 based development kit, and its psoc creator 2.2
