您好,可以尝试按照此处提到的步骤重新生成核心:http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/pp_p_process_regenerate_core.htm如果仍无法生成比特流,请附上xinfo文件开始菜单 - >
Xilinx设计工具 - > ISE设计套件 - >附件 - >点击Xinfo System Checker
问候,阿希什-----------------------------------------------
- - - - - - - - - - - - - - - - - - - - - - - -请注意-
如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .--------------------
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hello,
Can you try regenerating the core by following the steps mentioned here
If it still fails to generate bitstream, please attach the xinfo file
Start Menu -> Xilinx Design Tools -> ISE Design Suite -> Accessories -> Click on Xinfo System CheckerRegards,
Ashish
Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
----------------------------------------------------------------------------------------------View solution in original post
在原帖中查看解决方案
以上来自于谷歌翻译
以下为原文
Hello,
Ashish
