是德科技
张慧玲
7年用户 186经验值
请问是否有william hill官网 可以在4263B LCR仪表上发布问题?
我有一个关于为4263B添加选项的问题。是否有一个william hill官网 可以在4263B LCR仪表上发布问题?谢谢,Victor
以上来自于谷歌翻译
     以下为原文
  I have a question about adding options to the 4263B.
Is there a forum for posting questions on the 4263B LCR meters?
Thanks,
Victor
回帖(2)
张博
2019-7-26 15:54:26
您好,新型Agilent 4263B上提供的选项如下:4263B LCR Meter4263B-001添加N / M / DCR测量功能4263B-002添加20kHz测试频率我看到的唯一改装如下:4263V-001添加N / M
/ DCR测量功能。
这是针对改装选件001所需的组件。它不包括安装成本和/或后续校准要求。有一个FAQ在http://www.home.agilent.com/agilent/editorial.jspx上确认了这一点。
?CC = US&安培; LC =主机&安培; CKEY = 1502026&安培; NID = -536902441.536879695.00和ID = 1502026.Sincerely,tsilchia。
以上来自于谷歌翻译
     以下为原文
  Hello,
The options available on a new Agilent 4263B are listed below:
    4263B LCR Meter
    4263B-001 Add N/M/DCR Measurement Function
    4263B-002 Add 20kHz Test Frequency
The only retrofit I see is noted below:
    4263V-001 Add N/M/DCR Measurement Function . This is for the components required to retrofit option 001. It does not include the cost of installation and / or subsequent calibration requirements.
There is an FAQ confirming this at http://www.home.agilent.com/agilent/editorial.jspx?cc=US&lc=eng&ckey=1502026&nid=-536902441.536879695.00&id=1502026.
Sincerely,
tsilchia.
张慧玲
2019-7-26 16:13:49
感谢您的答复。
是的,我已经看过选件001套件。所有套件包括的是一张软盘。
添加选项001时,4263B没有硬件更改。鉴于安捷伦现在已经在所有4263B上同时提供选项001和002,是否可以获得选项001套件软盘中包含的程序?谢谢,Victor
以上来自于谷歌翻译
     以下为原文
  Thank you for the reply. Yes, I have seen that option 001 kit.
All that kit includes is a floppy disk. There is no hardware change to the 4263B when adding option 001.
Given that Agilent is giving away both option 001 and 002 on all 4263Bs now, would it be possible to get the program that is contained in the option 001 kit floppy?
Thanks,
Victor
