嗨,男孩。我买了100台TDA7297并且只跑了2台。我想知道这款Amp型号市场上是否有假货,或者是否有其他版本可用于建议的原理图数据表以外的版本。有人发生了类似的事吗?每百台设备的批号为:SINGAPORE W88030938。感谢您的帮助和评论。
#tda7297 以上来自于谷歌翻译 以下为原文 hi, boys.I bought 100 TDA7297 and ran only 2. I wonder if there might be fakes in the market for this Amp Model , or if there is another version that works with other than the proposed schematic datasheet . Someone has something similar happened ?. The number of the batch of every hundred devices is : SINGAPORE W88030938 . Thanks for the help and comments. #tda7297 |
3个回答
嗨Salazar,
当ST仍被命名为SGS-Thomson时,TDA7297是非常成熟的AB类设备。 根据您的描述,如果您的应用威廉希尔官方网站 (原理图和PCB布局)在过去已经通过TDA7297进行了验证,那么您应该得到一些非ST原装的器件。 澄清一下,最好与您的经销商联系。 谢谢 YT 以上来自于谷歌翻译 以下为原文 Hi Salazar, TDA7297 was very mature class AB device when ST was still named as SGS-Thomson. according to your description , if your application circuitry (both of schematic and PCB layout) had been proven with TDA7297 in the past , you should get some device that was not ST original . to clarify it , it's better to contact with your dealer. thanks YT |
是的陶先生,我想是的,这台设备并非原创。我在ALIEXPRESS购买。这些TDA7297我在ALIEXPRESS购买它们,我认为它是严肃的卖家,但事实证明不是原始的。如果另外一个设备可以替代pin到pin?或者你可以建议另一个类似的放大器,或者你知道我在哪里买原装TDA7297知道吗?陶先生,谢谢你。
以上来自于谷歌翻译 以下为原文 Yes Mr Tao, I think so, this device was not original. I bought in ALIEXPRESS. These TDA7297 I buy them in ALIEXPRESS, I thought it was serious sellers, but proved not original.Sabe you if another device that can replace pin to pin? or you can advise another similar amplifier, or Do you know where I can buy the original TDA7297 know? Thank you, Mr. Tao. |
你好Salazar,
你可以在下面的链接找到它, http://www.st.com/web/catalog/sense_power/FM125/CL1503/SC979/PF65157?s_searchtype=partnumber # 它可以在digikey和Mouser中使用。 谢谢 , YT 以上来自于谷歌翻译 以下为原文 hi Salazar, you may find it in below link , http://www.st.com/web/catalog/sense_power/FM125/CL1503/SC979/PF65157?s_searchtype=partnumber # it's available in digikey and Mouser . thanks , YT |
2760 浏览 1 评论
3247 浏览 1 评论
1820 浏览 1 评论
3663 浏览 6 评论
6051 浏览 21 评论
1346浏览 4评论
207浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
363浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
458浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
279浏览 2评论
GMT+8, 2025-1-2 04:15 , Processed in 1.221908 second(s), Total 81, Slave 66 queries .
