最近可以保存的噪声数据类型有所变化,可能在A.09.85中。
你正在运行什么?
您可能已经看过这个,但为了以防万一,以下是新信息:http://na.tm.agilent.com/pna/help/latest/Applications/Noise_Figure.htm#SaveNoiseData(我无法输入
链接,所以将此URL粘贴到浏览器中。)您可以从前面板保存所需的数据吗?
如果可行,那么我们就可以使用SCPI命令。
以上来自于谷歌翻译
以下为原文
There have been changes recently in the type of Noise data that can be saved, probably in A.09.85. What FW are you running?
You have probably seen this, but just in case, here is the new information:
(I am having trouble putting in a link, so paste this URL into the browser.)
Can you save the data that you want from the front-panel? If that works, then we can expolore the SCPI commands.
你正在运行什么?
以上来自于谷歌翻译
以下为原文
