是德科技
方夏少
7年用户 183经验值
如何替换零件?
嗨安捷伦的支持,我需要得到我的33120A的显示器和****,因为VFD显示器降级(我讨厌VFD老化很快!)并且****坏了。我已经搜索了安捷伦
具有以下结果的网站。部分编号说明Status33120-89301 DISPLAY VAC-FL作废33120-87401 **** Orderable如何订购DISPLAY VAC-FL?
我发现此项目无法通过网站订购。
获得此替换部分的任何替代方法?谢谢,VR2WHFdicksonfuhk([at])yahoo([dot])com([dot])hk(请删除电子邮件地址中的明显错误)
以上来自于谷歌翻译
     以下为原文
  Hi Agilent support,
I need to get the display and the **** for my 33120A, since that the VFD display is degraded (I hate VFD aging quickly!) and the **** is broken.
I have searched through the Agilent website with the following result.
Part Number  Description           Status
33120-89301 DISPLAY VAC-FL    Obsolete
How could I order the DISPLAY VAC-FL? I found this item is not orderable via on the website. Any alternative way to get this replacement part?
Thanks,
VR2WHF
dicksonfuhk ([at])yahoo([dot])com([dot])hk  (please remove the obvious error in the email address)
回帖(1)
杨梅
2019-8-13 09:10:34
显示屏列为可用,直至消失,您只需要更高级别的部件号33120-66502。您可以在安捷伦零件网页上找到它。这是该部件的屏幕截图。
以上来自于谷歌翻译
     以下为原文
  The display is listed as available till gone, you just needed the higher level part number which is 33120-66502.
You can find it on the Agilent parts web page.
Here is a screenshot of the part.
