Hello Oleg,官方说来,目前不支持以太网连接。
但是我已经将它与PNA一起使用并且没有任何问题。
可以将PNA视为LAN接口,例如
添加接口>> lan“左括号”“pna的IP地址”“右括号”:“pna sicl ..often hpib7”例如:lan“left bracket”1.2.3.4“right bracket”:hpib7(其中左括号=
=“[”等)此外,必须将PNA设置为期望通过以太网进行gpib通信。
我没有用B2200进行测试,但我希望它也可以工作,前提是它配置为通过以太网接受gpib。
如果您对这种方法感兴趣,尝试它应该没有任何缺点。
唯一的问题是,如果遇到一些与以太网接口特别相关的问题,则无法保证它会被解决,至少不会立即解决,因为它目前尚未得到官方支持。
如果您还有其他问题,请联系eesof_support@agilent.com。
我们在LinkedIn上也有一个IC-CAP用户组。
最好的问候Else
以上来自于谷歌翻译
以下为原文
Hello Oleg,
Officially, the ethernet connection is not supported at this time. However I have used it with the PNA and have not had any problems with it.
One can treat the PNA as if it were a lan interface e.g. add interface >> lan "left bracket" " ip address of pna " " right bracket" : " pna sicl ..often hpib7 "
for example: lan "left bracket" 1.2.3.4 "right bracket" : hpib7
(where left bracket == "[" etc.)
In addition, one must set the PNA up to be expecting the gpib communications via the ethernet.
I have not tested it with the B2200, but I would expect it would likely work also, provided it was configured to accept the gpib via ethernet.
If you are interested in this approach, there should be no downside to trying it. The only issue is that if you ran into some issue specifically
related to the ethernet interface, it is not assured it would be addressed, at least not immediately, since it is not currently officially supported.
If you have further questions, please contact eesof_support@agilent.com. We also have an IC-CAP User's Group on LinkedIn.
Best regards
Else
可以将PNA视为LAN接口,例如
最好的问候Else
以上来自于谷歌翻译
以下为原文
Hello Oleg,
Best regards
Else
