芯片求购|供应发布区
Gtina
6年用户 105经验值
擅长:EMC/EMI设计 嵌入式技术 接口/总线/驱动 处理器/DSP 控制/MCU
[供应]
NCS8803芯片HDMI转EDP功能简介
NCS8803 HDMI-to-eDP w/ Scaler guo18770755707/Q1456415694
Features
--Embedded-DisplayPort (eDP) Output
1/2/4-lane eDP @ 1.62/2.7Gbps per lane
HD to WQXGA (2560*1600) supported
Up to 6dB pre-emphasis
--HDMI Input
HDMI 1.4a supported
RGB444/YCbCr444/YCbCr422 supported
Pixel clock up to 340MHz
2-channel audio supported
Adaptive equalization
--Reference Clock
Any freq. between 19MHz and 100MHz
Crystal or single-ended clock input
Built-in 5000ppm SSC generator
--Misc
I2C for chip configuration
Built-in eDP handshake protocol
I2C-AUX channel for TCON/DPCD/EDID
control
Built-in video test pattern
--Power
1.2V core supply
2.5V or 3.3V IO supply
Power consumption ~ 150mW
@ 2560*1600*24bit*60Hz
Deep-sleep mode power <1mW
--Package
QFN-56 (7mm x 7mm) package
RoHS Compliant
--Availability
Samples by the end of 2016
Block Diagram
附件: 您需要登录才可以下载或查看附件。没有帐号?注册
