如何使用C#访问POP3服务器
内容:
This is a follow up to my SMTP example that shows how to
access your POP3 server. This program connects and logs on
to your POP3 server, and checks to see how many new
messages you have.
The instantiation of the POP is in Main() like this:
POP pop = new POP("pop-server", "loginname", "password");
You must replace "pop-server" with the name of your POP
server, "loginname" with your own log in, and "password"
with your password. The class has two methods. The Connect
method takes care of actually logging in to the server. The
TCPClient class is used to establish the connection.
The "user" and "pass" commands are used to login. Connect
returns a NetworkStream object created during the
connection process. The second method is
GetNumberOfNewMessages, which returns the number of unread
messages on the server. The response to the "stat" command
is parsed to extract the number of new messages.
Requirement:
Requires .NET SDK
How To Compile?
csc /r:System.Net.dll /r:System.IO.dll pop.cs
Source Code
using System.Net.Sockets;
using System.IO;
using System.Net;
using System;
class POP
string POPServer;
string user;
string pwd;
public POP(){}
public POP(string server, string _user, string _pwd)
POPServer = server;
user = _user;
pwd = _pwd;
private NetworkStream Connect()
TCPClient sender = new TCPClient(POPServer,110);
Byte[] outbytes;
string input;
NetworkStream ns = null;
try{
ns = sender.GetStream();
StreamReader sr = new StreamReader(ns);
Console.WriteLine(sr.ReadLine() );
input = "user " + user + "rn";
outbytes = System.Text.Encoding.ASCII.GetBytes
(input.ToCharArray());
ns.Write(outbytes,0,outbytes.Length) ;
input = "pass " + pwd + "rn";
return ns;
catch(InvalidOperationException ioe){
Console.WriteLine("Could not connect to mail server");
return ns;
public int GetNumberOfNewMessages()
Byte[] outbytes;
string input;
try{
NetworkStream ns = Connect();
input = "stat" + "rn";
ns.Write(outbytes,0,outbytes.Length);
string resp = sr.ReadLine();
Console.WriteLine(resp);
string[] tokens = resp.Split(new Char[] {' '});
input = "quit" + "rn";
Console.WriteLine(sr.ReadLine());
sr.Close();
ns.Close();
return tokens[1].ToInt32();
return 0;
public static void Main()
Console.WriteLine("New Messages = {0}",
pop.GetNumberOfNewMessages() );
Console.ReadLine();
命令解析部分
private bool SwitchCommand(string POP3_commandTxt)
try
//---- Parse command --------------------------------------------------//
string[] cmdParts = POP3_commandTxt.TrimStart().Split(new char[]{' '});
string POP3_command = cmdParts[0];
POP3_command = POP3_command.ToUpper();
//----- loging stuff --------------------------------------------------------------------------//
if(m_pPOP3_Server.LogCommands){
string lCmdTxt = POP3_commandTxt.Replace("rn","
m_pLogWriter.AddEntry(lCmdTxt,this.SessionID,m_ConnectedIp,"C");
//---- End of loging ---------------------------------------------------------------------------//
switch(POP3_command)
case "USER":
USER(Core.GetArgsText(POP3_commandTxt,"USER"));
break;
case "PASS":
PASS(Core.GetArgsText(POP3_commandTxt,"PASS"));
break;
case "STAT":
STAT();
break;
case "LIST":
LIST(Core.GetArgsText(POP3_commandTxt,"LIST"));
break;
case "RETR":
RETR(Core.GetArgsText(POP3_commandTxt,"RETR"));
break;
case "DELE":
DELE(Core.GetArgsText(POP3_commandTxt,"DELE"));
break;
case "NOOP":
NOOP();
break;
case "RSET":
RSET();
break;
case "QUIT":
QUIT();
return true;
//----- Optional commands ----- //
case "UIDL":
UIDL(Core.GetArgsText(POP3_commandTxt,"UIDL"));
break;
case "APOP":
APOP(Core.GetArgsText(POP3_commandTxt,"APOP"));
break;
case "TOP":
TOP(Core.GetArgsText(POP3_commandTxt,"TOP"));
break;
default:
SendData("-ERR Invalid commandrn");
//---- Check that maximum bad commands count isn't exceeded ---------------//
if(m_BadCmdCount > m_pPOP3_Server.MaxBadCommands-1){
SendData("421 Too many bad commands, closing transmission channelrn");
return true;
m_BadCmdCount++;
break;
catch(Exception x)
// Connection lost
if(!m_pClientSocket.Connected){
return true;
SendData("-ERR Unkown temp errorrn");
m_pPOP3_Server.OnSysError(x,new System.Diagnostics.StackTrace());
return false;
我做了一个pop3接收客户端,在收取邮件时,服务器返回得内容如下:
+OK Return-Path:
其中的汉字如何解析出来?
(注:我得连接类如下:
public class Pop3Connection
private TcpClient socket;
private StreamReader reader;
private StreamWriter writer;
private bool connected;
public bool Connected
get{return connected;}
public Pop3Connection()
// TODO: 在此处添加构造函数逻辑
connected=false;
socket=new TcpClient();
~Pop3Connection()
socket=null;
internal void Open(string host,int port)
if(host==null || host.Trim()=="")
throw new ArgumentException("Host is null!");
if(port<0)
throw new ArgumentException("Port is invalid!");
try
socket.Connect(host,port);
reader=new StreamReader(socket.GetStream(),System.Text.Encoding.ASCII );
writer=new StreamWriter(socket.GetStream(),System.Text.Encoding.ASCII);
connected=true;
catch(Exception e)
connected=false;
internal void SendCommand(string cmd)
writer.WriteLine(cmd);
writer.Flush();
internal void GetReply(out string reply )
if(Connected)
{reply=reader.ReadLine();}
else
{reply="";}
internal void Close()
reader.Close();
writer.Flush();
writer.Close();
reader=null;
writer=null;
socket.Close();
connected=false;
