FPGA|CPLD|ASICwilliam hill官网
刘闯
6年用户 14经验值
ad5432不受控制是为什么
ad5432不受控制,vhdl程序如下所示,请问是芯片还是程序的问题
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity ad5432_driver is
        port(
                clk : in std_logic;
                rst : in std_logic;
                din : in std_logic_vector(9 downto 0);
                sclk : out std_logic;
                sync : out std_logic;
                sdin : out std_logic
end entity ad5432_driver;
architecture one of ad5432_driver is
        signal clk_cnt : std_logic_vector(3 downto 0);
        signal din_reg : std_logic_vector(15 downto 0);
        signal sclk_reg : std_logic;
        signal flag : std_logic;
        type state is (
                s0,
                s1,
                s2,
                s3,
                s4,
                s5,
                s6,
                s7,
                s8,
                s9,
                s10,
                s11,
                s12,
                s13,
                s14,
                s15,
                s16
        signal c_st, n_st : state;
begin
        process(clk, rst)
        begin
                if rst = '0' then
                        clk_cnt <= (others => '0');
                elsif clk'event and clk = '1' then
                        clk_cnt <= clk_cnt + '1';
                end if;
        end process;
        sclk_reg <= clk_cnt(2);
        process(sclk_reg, rst, n_st)
        begin
                if rst = '0' then
                        c_st <= s0;
                elsif sclk_reg'event and sclk_reg = '1' then
                        c_st <= n_st;
                end if;
        end process;
        process(c_st)
        begin
                case c_st is
                        when s0 => n_st <= s1;
                        when s1 => n_st <= s2;                when s2 => n_st <= s3;
                        when s3 => n_st <= s4;
                        when s4 => n_st <= s5;
                        when s5 => n_st <= s6;
                        when s6 => n_st <= s7;
                        when s7 => n_st <= s8;
                        when s8 => n_st <= s9;
                        when s9 => n_st <= s10;
                        when s10 => n_st <= s11;
                        when s11 => n_st <= s12;
                        when s12 => n_st <= s13;
                        when s13 => n_st <= s14;
                        when s14 => n_st <= s15;
                        when s15 => n_st <= s16;
                        when s16 => n_st <= s0;
                        when others => n_st <= s0;
                end case;
        end process;
        process(sclk_reg, rst, din, n_st)
        begin
                if rst = '0' then
                        din_reg <= "0000000000000011";
                        sync <= '1';
                        case n_st is
                                when s0 => din_reg <= "1001" & din & "11"; sync <= '1';
                                when s1 => sdin <= din_reg(15); sync <= '0';
                                when s2 => sdin <= din_reg(14); sync <= '0';
                                when s3 => sdin <= din_reg(13); sync <= '0';
                                when s4 => sdin <= din_reg(12); sync <= '0';
                                when s5 => sdin <= din_reg(11); sync <= '0';
                                when s6 => sdin <= din_reg(10); sync <= '0';
                                when s7 => sdin <= din_reg(9); sync <= '0';
                                when s8 => sdin <= din_reg(8); sync <= '0';
                                when s9 => sdin <= din_reg(7); sync <= '0';
                                when s10 => sdin <= din_reg(6); sync <= '0';
                                when s11 => sdin <= din_reg(5); sync <= '0';
                                when s12 => sdin <= din_reg(4); sync <= '0';
                                when s13 => sdin <= din_reg(3); sync <= '0';
                                when s14 => sdin <= din_reg(2); sync <= '0';
                                when s15 => sdin <= din_reg(1); sync <= '0';
                                when s16 => sdin <= din_reg(0); sync <= '0';
                                when others => din_reg <= "1001000000000011"; sync <= '1';
                        end case;
                end if;
        end process;
--        process(sclk_reg, rst, din, n_st)
--        begin
--                if rst = '0' then
--                        sdin <= '0'; sync <= '1'; flag <= '0';
--                elsif sclk_reg'event and sclk_reg = '1' then
--                        case n_st is
--                                when s0 => sdin <= '0'; sync <= '1'; flag <= '0';
--                                when s1 => sdin <= '1'; sync <= '0'; flag <= '1';
--                                when s2 => sdin <= '0'; sync <= '0'; flag <= '1';
--                                when s3 => sdin <= '0'; sync <= '0'; flag <= '1';
--                                when s4 => sdin <= '1'; sync <= '0'; flag <= '1';
--                                when s5 => sdin <= din(9); sync <= '0'; flag <= '1';
--                                when s6 => sdin <= din(8); sync <= '0'; flag <= '1';
--                                when s7 => sdin <= din(7); sync <= '0'; flag <= '1';
--                                when s8 => sdin <= din(6); sync <= '0'; flag <= '1';
--                                when s9 => sdin <= din(5); sync <= '0'; flag <= '1';
--                                when s10 => sdin <= din(4); sync <= '0'; flag <= '1';
--                                when s11 => sdin <= din(3); sync <= '0'; flag <= '1';
--                                when s12 => sdin <= din(2); sync <= '0'; flag <= '1';
--                                when s13 => sdin <= din(1); sync <= '0'; flag <= '1';
--                                when s14 => sdin <= din(0); sync <= '0'; flag <= '1';
--                                when s15 => sdin <= '0'; sync <= '0'; flag <= '1';
--                                when s16 => sdin <= '0'; sync <= '0'; flag <= '1';
--                                when others => sdin <= '0'; sync <= '1'; flag <= '0';
--                        end case;
--                end if;
--        end process;
        sclk <= sclk_reg;
end architecture one;
