Prepared 属性范例 (VB)
本范例通过打开两个 Command 对象(一个是准备好的,另一个是未准备好的)来演示 Prepared 属性。
Public Sub PreparedX()
Dim cnn1 As ADODB.Connection
Dim cmd1 As ADODB.Command
Dim cmd2 As ADODB.Command
Dim strCnn As String
Dim strCmd As String
Dim sngStart As Single
Dim sngEnd As Single
Dim sngNotPrepared As Single
Dim sngPrepared As Single
Dim intLoop As Integer
' Open a connection.
strCnn = "Provider=sqloledb;" & _
"Data Source=srv;Initial Catalog=Pubs;User Id=sa;Password=; "
Set cnn1 = New ADODB.Connection
cnn1.Open strCnn
' Create two command objects for the same
' command - one prepared and one not prepared.
strCmd = "SELECT title, type FROM Titles ORDER BY type"
Set cmd1 = New ADODB.Command
Set cmd1.ActiveConnection = cnn1
cmd1.CommandText = strCmd
Set cmd2 = New ADODB.Command
Set cmd2.ActiveConnection = cnn1
cmd2.CommandText = strCmd
cmd2.Prepared = True
' Set a timer, then execute the unprepared
' command 20 times.
sngStart = Timer
For intLoop = 1 To 20
cmd1.Execute
Next intLoop
sngEnd = Timer
sngNotPrepared = sngEnd - sngStart
' Reset the timer, then execute the prepared
' command 20 times.
sngStart = Timer
cmd2.Execute
Next intLoop
sngEnd = Timer
sngPrepared = sngEnd - sngStart
' Display performance results.
MsgBox "Performance Results:" & vbCr & _
" Not Prepared: " & Format(sngNotPrepared, _
"##0.000") & " seconds" & vbCr & _
" Prepared: " & Format(sngPrepared, _
cnn1.Close
End Sub
