芯片求购|供应发布区
kuake
4年用户 394经验值
擅长:电源/新能源
[供应]
代理FR9702降压转换器芯片
Description
  The FR9702 is a monolithic step-down switch mode converter with a built-in power MOSFET. It achieves 1.8A output current over a wide input supply range with excellent load and line regulation. Current mode operation provides fast transient response and eases loop stabilization. Fault condition protection includes cycle-by-cycle current limit and over temperature protection.
  The FR9702 requires a minimum number of available standard external components. The FR9702 is available in SOT23-6, TSOT23-6, MSOP-10 and SOP-8 (Exposed Pad) packages.
Features
● 1.8A Output Current
● 180mΩ Internal Power MOSFET Switch
● Stable with Low ESR Output Ceramic Capacitors
● Up to 92% Efficiency
● Fixed 1.4MHz Frequency
● Current Mode Operation
● Over-Temperature Protection with Hiccup-Mode
● Cycle-by-Cycle Over Current Protection
● Wide 4.5V to 23V Operating Input Range
● Output Adjustable from 0.805V to 15V
● 10μA Shutdown Current
● Miniature Packages:
SOT-23-6, TSOT23-6, MSOP-10 and SOP-8
(Exposed Pad)
Applications
● Battery Charger
● Pre-Regulator for Linear Regulator
● OLPC, Netbook
● Distributed Power System
● WLED Driver
