韩国HITROL振动传感器 HTM-930振动棒料位开关
详询请致电:132,4667,5433 吴经理
工作Q:1662543848
地址:深圳市南山区南海大道4050号
HITROL
振棒料位开关的振动棒是一个
电子线路进行激励并保持共振,当被测介质到达并部分覆盖住振棒开关的探头时,振棒开关的振动阻尼空然增强,这种振动参数的改变将通过检测回路触发继电器,从而为物位控制提供了上、下限开关信号。
HTM-930,HR-30S-3F,HLG-100F,HLG-100FT,HLV-300H,HLV-310,HLV-310AP,HLV-310H
HM-90,HM-95,HM-90S,MH-90SE,HR-30S HR-30T,HR-30V,HM-12S,HM-12H,HM-12D,HM-10,HPC-509N
HCC-75P,HT-100W,HLT-2110, HTM-920,HLC-900 HLC-900L,HT-100R HT-100PS,HT-100RT,HT-100RT
HT-100RV,HT-100C-2,HPC-100C,HLC-100C-P,HR-30S-2F、HT-100F、HT-100R、HTM-930ST、HM-12S、HR-30S-4F
热质量流量计
HAT-1000,HAT-1000-EX,HAT-5000,HAT-5000-EX,HCV-0100,HCV-0150
HBA-418-4,HBA-418-8,HBA-425-4,HBA-425-8,HBL-450-4
流量计:FT2A-09I-SS-ST-E4-BO-G4,FT2A-12I-SS-ST-E3-B0-G1,FT2A-15I-SS-ST-E4-BO-G2,
FT2A-18I-SS-ST-E3-B0-G1,FT3-18I-SS-ST-E3-DD-MB-G2-101570 (66FT)
气体质量流量计:FT4A,HTML-S,HTML-TC,HTML-TM,HUL-2100N,HUL-2100S,HUL-2100T
HVT-0040,HVT-0050,HVT-0150,HVT-0800,HVT-0900,HVT-1150,HVT-1800
模块:HC-1515-F,HC-2150-F,HC-3300-F,HC-3300-S,HC-3600-F,HC-3600-S,HC-2150-S
HC-2300-F,HC-2300-S ,HC-2515-F,HC-2V15-F,HC-2V15-S,HC-3900-F,HC-3V15-F,HC-3V15-S
HC-4150-F,HC-4150-S,HC-4300-F,HC-4300-S,HC-4600-F,HC-4600-S,HC-4900-F,HC-4900-S
HC-4V15-S,HC-5900-F,HC-5V15-F,HC-6150-F,
液位开关:HCC-95P,HCC-95P-EX,HCC-95PH-EX,HCC-95PW,HCC-95PW-EX
HCC-95PWH,HCC-95PWH-EX,HCC-95R,HCC-95RH,HCC-95RW,HCC-95RWH
HCC-95T,HCC-95TH,HCC-96RF-C,HCC-96RF-R,HCC-96RF-RH,HCC-96RF-S
电极开关:HE-1S,HE-3H,HE-3H-S,HE-3H-SP,HE-3S,HE-3V,HE-4H,HE-4H-S
HE-4H-SP,HE-4S,HE-4V,HE-5H,HE-5H-S,HE-5H-SP,HE-5S,HE-5V,HE-6V,HE-7V
流量开关:HFS-12S,HFS-2S,HFS-2T,HFS-95R,HFT-7050,HFT-7065,HFT-7080,HFT-7100
HFV-0015,HFV-0020,HFV-0025,HFV-0032,HFV-0040,HFV-0100,HFV-0125,HFV-0150
指示单元/控制器:HHT-2000,HI-100D,HI-100D-EX,HI-200AL-EX
HFR-981 HFT-7100 HMF-700 HFC-6532G HFC-6532S
HFV-0850 HFV-0900 HFV-0950 HFV-1000 HFV-1050 HFV-1100 HFV-1150 HFV-1200 IVCM-01 IVCM-1H IVCM-3Q HMF-800L HMF-800R
HMF-800S HHG-1FA HHG-1FB HHG-2FA HHG-2FB HSG-1FA HSG-1FB HSG-2FA HSG-2FB HSG-3FA HSG-3FB HCC-609N-FS HCC-75R-FS
超声波HUL-2100N HUT-2000N HUL-2100S HUL-2100T HUT-2000S HUT-2000T
液位传感器
HM-95 HM-95-EX HM-95H HM-95H-EX HM-95V HM-95V-EX HM-95VH HM-95VH-EX
HM-90S HM-90S-EX HM-90SH HM-90SH-EX HR-30 HR-30CH-EX
韩国HITROL HQ系列是一款快速浮点式液位开关,是利用重力与力浮力的原理设计而成。适用于一般工业,特别是污水处理厂的液位控制, 使用方便,结构 坚固而简单。
工作原理:
浮球液位开关是利用浮球内藏接点来发信号的液位信号器。球内密封一滑动磁环及一干簧转换接点,其引线为三芯橡套软电缆。当介质液体液位升高, 浮子因为浮力上升。 当浮子到达设定点时, 浮子内的内置水银开关或微型开关接通或关闭。当液位下降,开关将被接通或关闭。
特性:
安装简单,性能稳定可靠;安装使用非常方便,现场调解方便。由于无金属外露部分,所以具有耐腐蚀性,使用寿命长;
外观简单,结构坚固;可与各种水泵配套使用,并广泛应用于给排水及含腐蚀,悬浮物的液体自动控制。
产品参数:
安装方式:法兰
附加功能:耐风雨 (IP54)
工作压力:ATM
工作温度:Max. 60℃
开关类型:水银开关,微型开关
触点容量:AC 110V 1A, DC 24V 0.5A
切触形式:SPST
头部材料: SS41, SUS 304不锈钢
应用:一般液体(电缆: :NBR),酸性或油性液体(电缆:聚氨酯)
安装方法:
传感器应安装使用英制3/4管螺纹,耦合或指定法兰;传感器不应安装在入口待测材料;然而,当传感器安装在入口待测材料,保护板应安装传感棒以承受***力;电缆压盖的方向应转发到地面。
布线方法:
采用双线绞合屏蔽电缆当接线传感器和单元;标准长度是6米;然而,当之间的距离传感器和单位超过6米,这是必需的电缆规格与代理商咨询;传感器与单元之间的接线时应使用单独的电缆管道供电传感器信号;它应该接地的传感器或单位;灵敏度可以调整使用拨号;如果它是逆时针拨号,振动变弱灵敏度变高;但是,如果顺时针方向,振动变强和灵敏度变低。
