经常碰到orcad仿真库中找不到某些器件的情况,但是从这些器件的厂家网站上往往可以下到其spice model,一般是.cir文件,下面介绍一下如何使用这些.cir文件。以AD8131.cir为例。
首先,运行Model Editor (in PSpice Accessories),打开ADAD8131.cir文件,另存为(save as)AD8131.lib,add this to pspice library,for simulation purpose.
use File->Export to capture part library… ,to generate AD8131.olb,add this to capture library,this can perform circuit connection.
when you run simulation ,open simulation setting/configuration file/library add the AD8131.lib to this design.
