示例文件
[tr]示例程序路径说明[/tr]
本例程使用了 RT-Thread 官方 TLS 测试网站 www.rt-thread.org,使用 mbedtls_client_write 函数发送 HTTP 测试请求,成功后,该网站会返回文本数据,测试例程将解析后的数据输出到控制台。
获取软件包
SSL/TLS 服务器进行证书校验的过程中,会对当前发起校验请求的时间进行认证,如果时间不满足服务器的要求,就会校验证书失败。因此,我们需要为设备同步本地时间。
msh />date 2018 08 02 12 23 00msh />dateThu Aug 2 12:23:01 2018msh />
msh />ntp_syncGet local time from NTP server: Thu Aug 2 14:31:30 2018The system time is updated. Timezone is 8.msh />dateThu Aug 2 14:31:34 2018启动例程 在 MSH 中使用命令 tls_test 执行示例程序,成功建立 TLS 连接后,设备会从服务器拿到一组密码套件,设备 log 如下所示: msh />tls_testMbedTLS test sample!Memory usage before the handshake connection is established:total memory: 33554408used memory : 20968maximum allocated memory: 20968Start handshake tick:3313[tls]mbedtls client struct init success...[tls]Loading the CA root certificate success...[tls]mbedtls client context init success...msh />[tls]Connected www.rt-thread.org:443 success...[tls]Certificate verified success...Finish handshake tick:6592MbedTLS connect success...Memory usage after the handshake connection is established:total memory: 33554408used memory : 45480maximum allocated memory: 50808Writing HTTP request success...Getting HTTP response...HTTP/1.1 200 OKServer: nginx/1.10.3 (Ubuntu)Date: Fri, 31 Aug 2018 08:29:24 GMTContent-Type: text/plainContent-Length: 267Last-Modified: Sat, 04 Aug 2018 02:14:51 GMTConnection: keep-aliveETag: "5b650c1b-10b"Strict-Transport-Security: max-age=1800; includeSubdomains; preloadAccept-Ranges: bytesRT-Thread is an open source IoT operating system from China, which has strong scalability: from a tiny kernel running on a tiny core, for example ARM Cortex-M0, or Cortex-M3/4/7, to a rich feature system running on MIPS32, ARM Cortex-A8, ARM Cortex-A9 DualCore etc.MbedTLS connection close success. |
AI模型部署边缘设备的奇妙之旅:边缘端设备的局域网视频流传输方案
1625 浏览 0 评论
1493 浏览 0 评论
AI模型部署边缘设备的奇妙之旅:如何在边缘端部署OpenCV
6729 浏览 0 评论
tms320280021 adc采样波形,为什么adc采样频率上来波形就不好了?
1867 浏览 0 评论
3765 浏览 0 评论
78543 浏览 21 评论
GMT+8, 2025-1-28 01:37 , Processed in 0.444547 second(s), Total 41, Slave 35 queries .
