TI公司的CC2541是2.4GHz蓝牙低功耗系统级芯片(SoC),支持250kbps, 500kbps, 1Mbps和2Mbps数据速率,具有极好的连接预算,应用时不外接前端,输出功率可编程到0dBm, 1Mbps时的接收灵敏度为-94dBm,主要用在2.4GHz蓝牙低功耗系统,个人2.4GHz系统,人机接口如键盘,鼠标和遥控等,体育和休闲设备,手机附件和消费类电子。本文介绍了CC2541主要特性,方框图, 应用威廉希尔官方网站
图和CC2541评估模块主要特性,威廉希尔官方网站
图和材料清单以及采用TPS62370的CC2541EM电源威廉希尔官方网站
图和材料清单。
The CC2541 is a power-optimized true system-on-chip (SoC) solution for both low energy and proprietary 2.4-GHz applications. It enables robust network nodes to be built with low total bill-of-material costs. The CC2541 combines the excellent performance of a leading RF transceiver with an industry-standard enhanced 8051 MCU, in-system programmable flash memory, 8-KB RAM, and many other powerful supporting features and peripherals. The CC2541 is highly suited for systems where ultralow power consumption is required. This is specified by various operating modes. Short transition times between operating modes further enable low power consumption.
The CC2541 is pin-compatible with the CC2540 in the 6-mm × 6-mm QFN40 package, if the USB is not used on the CC2540 and the I2C/extra I/O is not used on the CC2541.
CC2541主要特性:
CC2541 WITH TPS62730
• TPS62730 is a 2-MHz Step-Down Converter With Bypass Mode
• Extends Battery Lifetime by up to 20%
• Reduced Current in All Active Modes
• 30-nA Bypass Mode Current to Support
• RF Performance Unchanged
• Small Package Allows for Small Solution Size
• CC2541 Controllable
CC2541应用:
• 2.4-GHz Bluetooth low energy Systems
• Proprietary 2.4-GHz Systems
• Human-Interface Devices (Keyboard, Mouse, Remote Control)
• Sports and Leisure Equipment
• Mobile Phone Accessories
• Consumer Electronics
图1.CC2541方框图
图2.CC2541应用威廉希尔官方网站
图
CC2541评估模块
The CC2541 Evaluation Module Kit contains two CC2541 Bluetooth low energy Evaluation Modules, which can be used either as standalone modules (requires a power source and a simple carrier board like the SoC Battery Board or connected to e.g. the SmartRF05EB Evaluation Boards (included in the CC2540DK) for full control from the PC.
The evaluation modules can be used as a reference board for prototyping and for verifying the performance of the CC2541 RF IC.
CC2541评估模块主要特性:
The CC2541EMK includes:
2 x CC2541EM Evaluation Modules
2 x 2.4 GHz Antennas
Documentation
图3.CC2541评估模块外形图
注:CC2541评估模块要和CC2540DK开发套件的SmartRF05EB一起使用。
图4.CC2541评估模块威廉希尔官方网站
图
CC2541评估模块材料清单见:
图5.CC2541评估模块采用TPS62370的电源威廉希尔官方网站
图
采用TPS62370的CC2541EM电源材料清单见:
CC2541EM电源材料清单.rar(50.5 KB)2012-2-28 22:04 上传
-1
详情请见:
swrs110a[1].pdf(785.84 KB)2012-2-28 22:05 上传
-1
和
swrr096.zip(820.87 KB)2012-2-28 22:05 上传
-1
以及
swrr095.zip(582.21 KB)2012-2-28 22:04 上传
-1
图和材料清单。
CC2541主要特性:
CC2541应用:
图1.CC2541方框图
图2.CC2541应用威廉希尔官方网站
图
CC2541评估模块
CC2541评估模块主要特性:
Documentation
图3.CC2541评估模块外形图
图
CC2541评估模块材料清单见:
图
-1
详情请见:
-1
和
-1
以及
-1
