关于Servo.write()和Servo.writeMicroseconds()
0.Servo.writeMicroseconds(): Writes a value in microseconds (uS) to the servo, controlling the shaft accordingly. On a standard servo, this will set the angle of the shaft. On standard servos a parameter value of 1000 is fully counter-clockwise, 2000 is fully clockwise, and 1500 is in the middle.
1.servo.write() allows a maximum of 180 servo positions
servo.writeMicroseconds() allows a maximum of 1000 servo positions
2.The “write” method simply maps the “degrees” to microseconds and calls the “writeMicroseconds” method anyway.
The “degree” of turn is simply a convenient abstraction, and few bother to calibrate it.
控制程序:
控制程序:
