/*--------------------------start file---------------------------------*/
typedef struct
int id;
char name[10];
int score;
}student;
int struct_array(char* des, student *src)
int num;
char *temp = (char *) src ;
for(num=0;num
*(des+num)= temp[num];
return num;
void array_struct(student * des ,char * src)
char* temp = (char *) des;
int num;
for(num=0 ;num < sizeof(student);num++)
*(temp++)= src[num] ;
void show_student(student * name)
printf("id is : %dn",name->id);
printf("name is : %sn",name->name);
printf("score is : %d n",name->score);
void show_array(char *str ,int len )
printf("len is : %d n" ,len);
while(len--)
putchar('|');
putchar(*str++);
printf("|n");
int main()
char name[10] ="laomao";
student laomao = { 123 , {"laomao"} , 99 } ;
char save[100] ;
int len ;
student * answer;
len = struct_array(save, &laomao) ;
show_array(save , len);
array_struct(answer , save) ;
show_student(answer);
show_student(&laomao);
return 0;
/*---------------------------end file----------------------------------*/
运行结果:
len is : 20
|{| | | |l|a|o|m|a|o| | | | | | |c| | | |
id is : 123
name is : laomao
score is : 99
id is : 123
name is : laomao
score is : 99
串口传输 结构体 就是 把结构体 转换为 数组 ,然后传输 数组中的 char。
即 struct - - - - - - ->> char [ ] ;
然后 char[ ] - - - -- - - - -->> struct .
给出一下简单实例代码 :
#include
#include
typedef struct
int id;
char name[10];
int score;
}student;
int num;
for(num=0;num
return num;
int num;
while(len--)
putchar('|');
putchar(*str++);
printf("|n");
int main()
char save[100] ;
int len ;
student * answer;
return 0;
运行结果:
len is : 20
id is : 123
name is : laomao
score is : 99
id is : 123
name is : laomao
score is : 99
