STM32
kmno4
12年用户 965经验值
STM32捕获模式是怎样连续测量脉冲周期或者频率的
STM32捕获模式是怎样连续测量脉冲周期或者频率的?其程序配置是怎样的?
回帖(1)
李敏
2021-10-25 10:00:04
  STM32捕获模式连续测量脉冲周期/频率,使用类似中断的方式,使用STM32内部的硬件滤波器,脉冲周期量程很大(固定时间脉冲计数的方式,量程有限)。
  硬件: STM32F103R8T6 TIM2 CH1通道
  程序配置如下:
  /*TIM2初始化*/
  void MX_TIM2_Init(void)
  TIM_MasterConfigTypeDef sMasterConfig = {0};
  TIM_IC_InitTypeDef sConfigIC = {0};
  htim2.Instance = TIM2;
  htim2.Init.Prescaler = 71; /*1us per tick*/
  htim2.Init.CounterMode = TIM_COUNTERMODE_UP;
  htim2.Init.Period = 0xffff;
  htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV2;
  htim2.Init.RepetitionCounter = 0;
  HAL_TIM_Base_Init(&htim2);
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig);
  sConfigIC.ICPolarity = TIM_INPUTCHANNELPOLARITY_RISING; /*上升沿*/
  sConfigIC.ICSelection = TIM_ICSELECTION_DIRECTTI;
  sConfigIC.ICPrescaler = TIM_ICPSC_DIV1;
  sConfigIC.ICFilter = 7; /*硬件滤波器值*/
  HAL_TIM_IC_ConfigChannel(&htim2, &sConfigIC, TIM_CHANNEL_1);
  HAL_TIM_Base_Start_IT(&htim2); /*启动TIM2定时器 */
  HAL_TIM_IC_Start_IT (&htim2, TIM_CHANNEL_1); /*开启捕获 */
  /*配置端口*/
  void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(htim_base-》Instance==TIM2) /*改用捕获模式测量频率*/
  /* USER CODE BEGIN TIM2_MspInit 0 */
  /* USER CODE END TIM2_MspInit 0 */
  /* Peripheral clock enable */
  __TIM2_CLK_ENABLE();
  /**TIM2 GPIO Configuration
  PA0-WKUP ------》 TIM2_CH1
  GPIO_InitStruct.Pin = GPIO_PIN_0;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  /* USER CODE BEGIN TIM2_MspInit 1 */
  HAL_NVIC_SetPriority(TIM2_IRQn, 1, 0); /*中断优先级*/
  HAL_NVIC_EnableIRQ(TIM2_IRQn); /*使能中断*/
  /* USER CODE END TIM2_MspInit 1 */
  /*中断处理调用*/
  void TIM2_IRQHandler(void)
  HAL_TIM_IRQHandler(&htim2);
  typedef struct //测量周期的脉宽
  uint8_t ucFinishFlag;
  uint16_t usCtr;
  uint16_t usPeriod;
  uint32_t usCycle; /*捕捉的周期*/
  }STRUCT_CAPTURE;
  STRUCT_CAPTURE strCapture1 = { 0, 0, 0 };
  /*输入捕获回调*/
  * 函数功能: 定时器输入捕获中断回调函数
  * 输入参数: htim:定时器句柄
  * 返 回 值: 无
  * 说 明: 无
  void HAL_TIM_IC_CaptureCallback(TIM_HandleTypeDef *htim)
  if(htim == &htim2) /*使用通道1,实际是间隔1个周期测量*/
  strCapture1 .usCtr = HAL_TIM_ReadCapturedValue(htim,TIM_CHANNEL_1);
  /*计算脉冲的周期*/
  strCapture1.usCycle = strCapture1.usPeriod * 0xFFFF + strCapture1 .usCtr; /*直
  接把周期计算出来了*/
  strCapture1 .ucFinishFlag = 1;
  htim-》Instance-》CNT = 0; /*提前设置好,测量整个周期的时钟,单位
  1us*/
  strCapture1.usCtr = 0;
  strCapture1.usPeriod = 0;
  /*定时器计数溢出处理 可处理周期 0 - 0xffffffff us 的周期*/
  void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
  if(htim-》Instance == TIM2)
  strCapture1.usPeriod++; /*溢出*/
  strCapture1.usCycle 即所求的脉冲周期,时间除以周期即可得到所求脉冲的频率。
