STM32
笑过就走
9年用户 899经验值
擅长:可编程逻辑 电源/新能源 MEMS/传感技术
如何对STM32 USB进行初始化呢
如何对STM32 USB进行初始化呢?有哪些操作步骤呢?
回帖(1)
刘世晓
2021-11-1 15:29:40
  硬件原理图
  在开始枚举设备的一些初始化
  void bsp_USBInit(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_USB_PULL_UP, ENABLE);
  USB_CABLE_DISABLE();
  GPIO_InitStructure.GPIO_Pin = PIN_USB_PULL_UP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  NVIC_InitTypeDef NVIC_InitStructure;
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USB, ENABLE);
  USB_Init();
  现在开始分析真正的初始化
  第一步:初始化,总线复位及向默认地址 0发送 GET_DESCRIPTOR 指令包,请求设备描述
  1)Index[4 - 5]:表示 USB插入总线复位;
  2)Index[7 - 8]:表示主机向默认地址发送GET_DESCRIPTOR指令包,详细信
  息也抓出来了,如(图二)所示
  3)Index[15 - 17]:表示设备向主机发送设备描述数据 Index[16]
  4)Index[18 - 19]:表示主机完成 GET_DESCRIPTOR指令后,给设备发送一个
  空应答
  现在具体的分析103的usb的执行过程 按顺序向下执行
  ***************(1)**************
  DEVICE_INFO *pInformation;
  DEVICE_PROP *pProperty;
  DEVICE_PROP Device_Property =
  Joystick_init,
  Joystick_Reset,
  Joystick_Status_In,
  Joystick_Status_Out,
  Joystick_Data_Setup,
  Joystick_NoData_Setup,
  Joystick_Get_Interface_Setting,
  Joystick_GetDeviceDescriptor,
  Joystick_GetConfigDescriptor,
  Joystick_GetStringDescriptor,
  0,
  0x40
  USER_STANDARD_REQUESTS User_Standard_Requests =
  Joystick_GetConfiguration,
  Joystick_SetConfiguration,
  Joystick_GetInterface,
  Joystick_SetInterface,
  Joystick_GetStatus,
  Joystick_ClearFeature,
  Joystick_SetEndPointFeature,
  Joystick_SetDeviceFeature,
  Joystick_SetDeviceAddress
  //USB内核将主机发送过来的用于实现USB设备的设置包保存在设备信息结构表中
  typedef struct _DEVICE_INFO
  uint8_t USBbmRequestType;
  uint8_t USBbRequest;
  uint16_t_uint8_t USBwValues;
  uint16_t_uint8_t USBwIndexs;
  uint16_t_uint8_t USBwLengths;
  uint8_t ControlState;
  uint8_t Current_Feature;
  uint8_t Current_Configuration;
  uint8_t Current_Interface;
  uint8_t Current_AlternateSetting;
  ENDPOINT_INFO Ctrl_Info;
  }DEVICE_INFO;
  u***_init.c文件里面的
  void USB_Init(void)
  pInformation = &Device_Info;
  pInformation-》ControlState = 2;
  pProperty = &Device_Property;
  pUser_Standard_Requests = &User_Standard_Requests;
  pProperty-》Init();
  ***************(2)**************通过函数指针指向这个初始化函数pProperty 在u***_prop.c文件里面
  void Joystick_init(void)
  Get_SerialNum(); //得到串行号
  pInformation-》Current_Configuration = 0; //
  PowerOn(); //将USB上电 连接设备
  USB_SIL_Init(); //主要是CNTR寄存器的初始化
  bDeviceState = UNCONNECTED; //设备状态标志 当前状态未连接
  hw_config.c文件里面 这个和标准的不一样有改动,获取设备版本号,将其存入到版本号字符串。
  void Get_SerialNum(void) //得到串行号
  uint32_t Device_Serial0, Device_Serial1, Device_Serial2;
  Device_Serial0 = *(__IO uint32_t*)(0x1FFFF7E8);
  Device_Serial1 = *(__IO uint32_t*)(0x1FFFF7EC);
  Device_Serial2 = *(__IO uint32_t*)(0x1FFFF7F0);
  Device_Serial0 += Device_Serial2;
  if (Device_Serial0 != 0)
  IntToUnicode (Device_Serial0, &Joystick_StringSerial[2] , 8);
  IntToUnicode (Device_Serial1, &Joystick_StringSerial[18], 4);
  u***_pwr.c文件里面 在这个文件里面只是使能了复位,挂起,唤醒中断,在PowerOn函数使能了复位中断以后,将进入到USB的复位中断里面去。
  然后再执行函数USB_SIL_Init 将所有的USB中断都打开。在D+被接通上拉以后,设备就能被主机检测到。
  RESULT PowerOn(void)
  #ifndef STM32F10X_CL
  uint16_t wRegVal;
  USB_Cable_Config(ENABLE); //将USB上电连接
  //对USB模块强制复位,类似于USB总线上的复位信号。USB模块将一直保持在复位状态下
  //直到软件清除此位。如果USB复位中断被使能,将产生一个复位中断。
  wRegVal = CNTR_FRES; //强制复位
  _SetCNTR(wRegVal);
  wInterrupt_Mask = 0;
  _SetCNTR(wInterrupt_Mask); //清除复位信号
  _SetISTR(0);
  //复位中断屏蔽位 挂起中断屏蔽位 唤醒中断屏蔽位使能
  wInterrupt_Mask = CNTR_RESETM | CNTR_SUSPM | CNTR_WKUPM; _SetCNTR(wInterrupt_Mask);
  #endif
  return USB_SUCCESS;
  u***_istr.c文件里面,下面只写了进入到复位中断函数,进入到USB连接状态
  void USB_Istr(void)
  wIstr = _GetISTR();
  #if (IMR_MSK & ISTR_RESET) //USB复位请求中断
  if (wIstr & ISTR_RESET & wInterrupt_Mask)
  _SetISTR((uint16_t)CLR_RESET); //清楚复位中断标志
  Device_Property.Reset(); //进入到复位中断
  #ifdef RESET_CALLBACK
  RESET_Callback();
  #endif
  #end
  u***_prop.c文件里面,实现对端点的设置。
  void Joystick_Reset(void)
  pInformation-》Current_Interface = 0;
  pInformation-》Current_Feature = Joystick_ConfigDescriptor[7]; //供电模式选择
  #ifdef STM32F10X_CL
  OTG_DEV_EP_Init(EP1_IN, OTG_DEV_EP_TYPE_INT, 4);
  #else
  SetBTABLE(BTABLE_ADDRESS); //分组缓冲区描述表地址设置
  SetEPType(ENDP0, EP_CONTROL); //初始化为控制端点类型
  SetEPTxStatus(ENDP0, EP_TX_STALL); //端点以STALL分组响应所有的发送请求。
  //也就是端点状态设置成发送无效,也就是主机的IN令牌包来的时候,回送一个STALL。
  SetEPRxAddr(ENDP0, ENDP0_RXADDR); //设置端点0描述符的接受地址,
  SetEPTxAddr(ENDP0, ENDP0_TXADDR); //设置端点0描述符的发送地址
  Clear_Status_Out(ENDP0);
  //仅用于控制端点 如果STATUS_OUT位被清除,OUT分组可以包含任意长度的数据
  SetEPRxCount(ENDP0, Device_Property.MaxPacketSize);
  //设置端点0的接受字节寄存器的最大值是64
  SetEPRxValid(ENDP0); //设置接受端点有效
  SetEPType(ENDP1, EP_INTERRUPT); //初始化为中断端点类型
  SetEPTxAddr(ENDP1, ENDP1_TXADDR); //设置发送数据的地址
  SetEPTxCount(ENDP1, 4); //设置发送的长度
  SetEPRxStatus(ENDP1, EP_RX_DIS); //设置接受端点关闭
  SetEPTxStatus(ENDP1, EP_TX_NAK); //设置发送端点端点非应答
  SetDeviceAddress(0); //设置设备用缺省地址相应
  #endif
  bDeviceState = ATTACHED; //当前状态连接
  u***_sil.c的文件里面,主要是使能了如下这些中断
  CNTR_CTRM 正确传输(CTR)中断使能 CNTR_WKUPM 唤醒中断使能
  CNTR_SUSPM 挂起(SUSP)中断使能 CNTR_ERRM 出错中断使能
  CNTR_SOFM 帧首中断使能 CNTR_ESOFM 期望帧首中断使能CNTR_RESETM 设置此位将向PC主机发送唤醒请求。根据USB协议,如果此位在1ms到15ms内保持有效,主机将对USB模块实行唤醒操作。
  uint32_t USB_SIL_Init(void)
  _SetISTR(0); //清除中断标志
  wInterrupt_Mask = IMR_MSK;
  //这组寄存器用于定义USB模块的工作模式,中断的处理,设备的地址和读取当前帧的编号
  _SetCNTR(wInterrupt_Mask); //设置相应的控制寄存器
  #else
  OTG_DEV_Init();
  #endif
  return 0;
  ***************(3)**************
  1.获取设备描述符
  u***_int.c的文件里面
  低优先级中断 在控制 中断 批量传输下使用(在单缓冲模式下使用)
  当一次正确的OUT,SETUP,IN数据传输完成后,硬件会自动设置此位为NAK状态,使应用程序有足够的时间处理完当前传输的数据后,响应下一个数据分组
  void CTR_LP(void)
  __IO uint16_t wEPVal = 0;
  while (((wIstr = _GetISTR()) & ISTR_CTR) != 0)
  EPindex = (uint8_t)(wIstr & ISTR_EP_ID); //读出端点ID
  if (EPindex == 0) //如果是端点0
  SaveRState = _GetENDPOINT(ENDP0); //读取端点0寄存器USB_EP0R
  SaveTState = SaveRState & EPTX_STAT; //保存发送状态位
  SaveRState &= EPRX_STAT; //保存接受状态位
  _SetEPRxTxStatus(ENDP0,EP_RX_NAK,EP_TX_NAK); //端点以NAK分组响应所有的发送和接受请求(解释在上面)
  if ((wIstr & ISTR_DIR) == 0) //IN令牌,数据被取走
  _ClearEP_CTR_TX(ENDP0); //清除正确发送标志位
  In0_Process(); //处理INT事件
  _SetEPRxTxStatus(ENDP0,SaveRState,SaveTState);
  return;
  else
  wEPVal = _GetENDPOINT(ENDP0); //得到端点0寄存器的数据
  if ((wEPVal &EP_SETUP) != 0) //SETUP分组传输完成标志
  _ClearEP_CTR_RX(ENDP0);
  Setup0_Process(); //处理SETUP事件
  //程序会进入到这个函数里面
  return;
  else if ((wEPVal & EP_CTR_RX) != 0)
  Out0_Process(); //处理OUT事件
  return;
  else //如果是除端点0以外的端点
  wEPVal = _GetENDPOINT(EPindex); //得到相应端点寄存器值
  if ((wEPVal & EP_CTR_RX) != 0) //检测正确接收标志 PC-USB OUT int
  _ClearEP_CTR_RX(EPindex); //清除相应的标志
  (*pEpInt_OUT[EPindex-1])(); //调用OUT int服务功能
  if ((wEPVal & EP_CTR_TX) != 0) //检测正确发送标志 USB-PC IN int
  _ClearEP_CTR_TX(EPindex); //清除相应的标志
  (*pEpInt_IN[EPindex-1])(); //调用IN int服务功能
  u***_coer.c的文件里面,主要是得到主机发来的标准请求命令
  uint8_t Setup0_Process(void)
  union
  uint8_t* b;
  uint16_t* w;
  } pBuf;
  #ifdef STM32F10X_CL
  USB_OTG_EP *ep;
  uint16_t offset = 0;
  ep = PCD_GetOutEP(ENDP0);
  pBuf.b = ep-》xfer_buff;
  #else
  uint16_t offset = 1;
  //得到接受缓冲区地址寄存器地址
  pBuf.b = PMAAddr + (uint8_t *)(_GetEPRxAddr(ENDP0) * 2);
  #endif
  if (pInformation-》ControlState != PAUSE)
  pInformation-》USBbmRequestType = *pBuf.b++;
  pInformation-》USBbRequest = *pBuf.b++;
  pBuf.w += offset;
  pInformation-》USBwValue = ByteSwap(*pBuf.w++);
  pBuf.w += offset;
  pInformation-》USBwIndex = ByteSwap(*pBuf.w++);
  pBuf.w += offset;
  pInformation-》USBwLength = *pBuf.w;
  pInformation-》ControlState = SETTING_UP;
  if (pInformation-》USBwLength == 0)
  NoData_Setup0();
  else
  Data_Setup0(); //由于是有数据的传输,所有要进入到这个函数
  return Post0_Process();
  u***_core.c的文件里面,这里只是选取了GET DESCRIPTOR
  的程序部分,其他的部分删除了
  void Data_Setup0(void)
  uint8_t *(*CopyRoutine)(uint16_t);
  RESULT Result;
  uint32_t Request_No = pInformation-》USBbRequest;
  uint32_t Related_Endpoint, Reserved;
  uint32_t wOffset, Status;
  CopyRoutine = NULL;
  wOffset = 0;
  //看标准请求码格式就知道了
  if (Request_No == GET_DESCRIPTOR)
  //pInformation-》USBbmRequestType是下面的两种 标准请求或设备请求
  if (Type_Recipient == (STANDARD_REQUEST | DEVICE_RECIPIENT))
  uint8_t wValue1 = pInformation-》USBwValue1; //高一字节得到描述表种类 一共有5种
  if (wValue1 == DEVICE_DESCRIPTOR) //设备描述
  CopyRoutine = pProperty-》GetDeviceDescriptor;
  else if (wValue1 == CONFIG_DESCRIPTOR)
  CopyRoutine = pProperty-》GetConfigDescriptor; //配置描述
  else if (wValue1 == STRING_DESCRIPTOR)
  CopyRoutine = pProperty-》GetStringDescriptor; //字符串描述
  if (CopyRoutine)
  pInformation-》Ctrl_Info.U***_wOffset = wOffset; //本子程序的wOffset是0
  pInformation-》Ctrl_Info.CopyData = CopyRoutine; //使指针pInformation-》Ctrl_Info.CopyData指向CopyRoutine
  (*CopyRoutine)(0); //第一次执行时Length=0 返回的是有效数据的长度 存储到pInformation-》Ctrl_Info.U***_wLength
  Result = USB_SUCCESS;
  else
  { //如果标准请求不存在 看类 厂商请求中是否有
  Result = (*pProperty-》Class_Data_Setup)(pInformation-》USBbRequest);
  if (Result == USB_NOT_READY)
  pInformation-》ControlState = PAUSE;
  return;
  if (pInformation-》Ctrl_Info.U***_wLength == 0xFFFF) //如果字符的长度是0xffff
  return;
  if ((Result == USB_UNSUPPORT) || (pInformation-》Ctrl_Info.U***_wLength == 0))
  pInformation-》ControlState = STALLED;
  return;
  if (ValBit(pInformation-》USBbmRequestType, 7)) //D7表示数据传输方向 1:设备向主机
  __IO uint32_t wLength = pInformation-》USBwLength;
  //设置使其为USB主机设置的长度 本程序HID 鼠标 pProperty-》MaxPacketSize是0x40
  if (pInformation-》Ctrl_Info.U***_wLength 》 wLength)
  //字符的长度大于主机要求的长度
  pInformation-》Ctrl_Info.U***_wLength = wLength;
  //将其设置为主机要求的
  else if (pInformation-》Ctrl_Info.U***_wLength 《 pInformation-》USBwLength) //字符的长度小于主机要求的
  if (pInformation-》Ctrl_Info.U***_wLength 《 pProperty-》MaxPacketSize) //如果字符的长度长度小于每包数据最大字节数
  Data_Mul_MaxPacketSize = FALSE;
  else if ((pInformation-》Ctrl_Info.U***_wLength % pProperty-》MaxPacketSize) == 0) //如果是其整数倍
  Data_Mul_MaxPacketSize = TRUE;
  pInformation-》Ctrl_Info.PacketSize = pProperty-》MaxPacketSize;
  DataStageIn();
  else //主机向设备
  pInformation-》ControlState = OUT_DATA;
  vSetEPRxStatus(EP_RX_VALID);
  return;
  u***_coer.c的文件里面
  void DataStageIn(void)
  ENDPOINT_INFO *pEPinfo = &pInformation-》Ctrl_Info; //端点信息保存在指针变量中
  uint32_t save_wLength = pEPinfo-》U***_wLength; //得到字符的长度
  uint32_t ControlState = pInformation-》ControlState; //得到当前的状态
  uint8_t *DataBuffer;
  uint32_t Length;
  if ((save_wLength == 0) && (ControlState == LAST_IN_DATA)) //如果字符长度为0 且控制状态是最后输入的数据
  if(Data_Mul_MaxPacketSize == TRUE) //如果字符的长度是数据包的整数倍
  Send0LengthData();
  ControlState = LAST_IN_DATA;
  Data_Mul_MaxPacketSize = FALSE; //这一次发送0字节 状态转为最后输入阶段
  else //字符的长度比数据包要小
  { //数据已经发送完
  ControlState = WAIT_STATUS_OUT;
  #ifdef STM32F10X_CL
  PCD_EP_Read (ENDP0, 0, 0);
  #endif
  vSetEPTxStatus(EP_TX_STALL); //设置端点的发送状态停止
  #endif
  goto Expect_Status_Out;
  Length = pEPinfo-》PacketSize; //得到数据包大小 64字节
  ControlState = (save_wLength 《= Length) ? LAST_IN_DATA : IN_DATA;//比较大小得到是LAST_IN_DATA还是IN_DATA 18字节《64字节 ControlState = LAST_IN_DATA
  if (Length 》 save_wLength)
  Length = save_wLength;
  DataBuffer = (*pEPinfo-》CopyData)(Length); //DataBuffer指向要复制数据的地址 这个地址是随U***_wOffset变化的
  #ifdef STM32F10X_CL
  PCD_EP_Write (ENDP0, DataBuffer, Length);
  #else
  //GetEPTxAddr(ENDP0) 得到发送缓冲区相应端点的地址
  //将DataBuffer中的数据复制到相应的发送缓冲区中
  UserToPMABufferCopy(DataBuffer, GetEPTxAddr(ENDP0), Length);
  #endif
  SetEPTxCount(ENDP0, Length); //设置相应的端点要发送的字节数
  pEPinfo-》U***_wLength -= Length;//等于0
  pEPinfo-》U***_wOffset += Length;//偏移到18
  vSetEPTxStatus(EP_TX_VALID); //使能发送端点 只要主机的IN令牌包一来 SIE就会将描述符返回给主机
  USB_StatusOut();
  //设置接收端点有效 这个实际上使接受也有效,
  Expect_Status_Out:
  pInformation-》ControlState = ControlState; //保存控制状态
  ***************(4)**************
  uint8_t In0_Process(void)
  if ((ControlState == IN_DATA) || (ControlState == LAST_IN_DATA))//进入到这里
  DataStageIn();//第一次取设备描述符只取一次 当前的状态变为WAIT_STATUS_IN表明设备等待状态过程 主机输出0字节
  else if (ControlState == WAIT_STATUS_IN) //设置地址状态阶段进入这个程序
  if ((pInformation-》USBbRequest == SET_ADDRESS) &&
  (Type_Recipient == (STANDARD_REQUEST | DEVICE_RECIPIENT)))
  SetDeviceAddress(pInformation-》USBwValue0); //设置使用新的地址
  pUser_Standard_Requests-》User_SetDeviceAddress();
  (*pProperty-》Process_Status_IN)();
  ControlState = STALLED; //变为这个状态
  else
  uint8_t Out0_Process(void)
  //主机在完成传输前终止传输
  else if ((ControlState == OUT_DATA) || (ControlState == LAST_OUT_DATA))
  DataStageOut();
  else if (ControlState == WAIT_STATUS_OUT) //进入到这个里面
  (*pProperty-》Process_Status_OUT)(); //这个函数其实什么也没做
  ControlState = STALLED; //状态变成了终止发送和接受
  #endif
  else
  ***************(5)**************
  获取设备描述符以后,主机再一次的复位设备,设备又进入初始状态。开始枚举的第二步设置地址。
  void NoData_Setup0(void)
  RESULT Result = USB_UNSUPPORT;
  uint32_t RequestNo = pInformation-》USBbRequest;
  uint32_t ControlState;
  if (Type_Recipient == (STANDARD_REQUEST | DEVICE_RECIPIENT)) //设备请求
  else if (RequestNo == SET_ADDRESS) /设置地址
  if ((pInformation-》USBwValue0 》 127) || (pInformation-》USBwValue1 != 0)
  || (pInformation-》USBwIndex != 0)
  || (pInformation-》Current_Configuration != 0))
  goto exit_NoData_Setup0;
  else
  #ifdef STM32F10X_CL
  #endif
  ControlState = WAIT_STATUS_IN;
  USB_StatusIn();//准备好发送0字节的状态数据包 SetEPTxCount(ENDP0, 0);
  //vSetEPTxStatus(EP_TX_VALID);建立阶段后直接的进入状态阶段
  exit_NoData_Setup0:
  return;
  if ((ControlState == IN_DATA) || (ControlState == LAST_IN_DATA)) //控制状态
  DataStageIn();//第一次取设备描述符只取一次 当前的状态变为WAIT_STATUS_IN 表明设备等待状态过程 主机输出0字节
  ControlState = STALLED; //终止发送和接受
  else
  uint8_t Post0_Process(void)
  #ifdef STM32F10X_CL
  USB_OTG_EP *ep;
  #endif
  SetEPRxCount(ENDP0, Device_Property.MaxPacketSize); //设置端点0 要接受的字节数
  if (pInformation-》ControlState == STALLED) //这种状态下只接受SETUP命令包
  vSetEPRxStatus(EP_RX_STALL); //终止端点0接受
  vSetEPTxStatus(EP_TX_STALL); //终止端点0发送
  return (pInformation-》ControlState == PAUSE);
  ***************(6)*************
  从新地址获取设备描述符
