void ADC_SR_Detect_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
ADC_CommonInitTypeDef ADC_CommonInitStructure;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
/********************使能外设时钟(GPIO、ADC、DMA、TIM)**********************/
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC3, ENABLE); //使能ADC3时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE); //使能DMA2时钟
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE); //使能GPIOA时钟
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //使能TIM3时钟
/**************************ADC GPIO初始化************************************/
GPIO_InitStructure.GPIO_Pin = ADC_SR_PIN; //ADC123_IN1
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; //模拟输入
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; //无上下拉
GPIO_Init(GPIOA, &GPIO_InitStructure);
/**************************ADC DMA NVIC配置**********************************/
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/**************************ADC TIM NVIC配置******************************/
NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //定时器TIM3中断通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=1; //抢占优先级1
NVIC_InitStructure.NVIC_IRQChannelSubPriority =1; //子优先级2
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化NVIC寄存器
/**************************ADC DMA初始化*************************************/
DMA_DeInit(DMA2_Stream1);
while (DMA_GetCmdStatus(DMA2_Stream1) != DISABLE);//等待 DMA可配置
DMA_InitStructure.DMA_Channel = DMA_Channel_2; //DMA2通道2
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC3-》DR; //外设基地址 ADC3_DR
DMA_InitStructure.DMA_Memory0BaseAddr = (u32)&ADCSRData; //内存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory; //DMA搬运模式 外设到内存
DMA_InitStructure.DMA_BufferSize = 2000; //缓存区大小
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //接收一次数据后,设备地址禁止后移
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //接收一次数据后,目标内存地址后移
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //定义外设数据宽度为16位
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //DMA搬移数据尺寸,HalfWord就是为16位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //循环转换模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA优先级高
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable; //打开FIFO模式
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full; //DMA fifo阈值级别FULL
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single; //DMA内存单次传输
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single; //DMA外设单次传输
DMA_Init(DMA2_Stream1, &DMA_InitStructure);
DMA_Cmd(DMA2_Stream1, ENABLE);
DMA_ITConfig(DMA2_Stream1, DMA_IT_TC, ENABLE);
/**************************ADC TIM触发初始化*************************************/
TIM_Cmd(TIM3, DISABLE);
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure); //初始化定时器
TIM_TimeBaseStructure.TIM_Period = 167; //计数值 42MHz*2/1000/168=500Hz
TIM_TimeBaseStructure.TIM_Prescaler = 999; //预分频器1000分频
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //时钟输入1分频
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_ARRPreloadConfig(TIM3, ENABLE); //允许TIM3定时重载
TIM_SelectOutputTrigger(TIM3, TIM_TRGOSource_Update); //选择TIM3的UPDATA事件更新为触发源
/***************************ADC Common Init**********************************/
ADC_DeInit();
ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent; //ADC独立模式
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2; //选择时钟频率 2分频
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled; //禁止 DMA 直接访问模式
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_20Cycles; //采样时间间隔
ADC_CommonInit(&ADC_CommonInitStructure);
/**********************ADC Init 结构体参数初始化******************************/
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b; //分辨率12Bit
ADC_InitStructure.ADC_ScanConvMode = DISABLE; //开启扫描模式
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE; //连续转换
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising; //外部上升沿触发
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T3_TRGO; //外部触发源 TIM3_TRGO
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //数据右对齐
ADC_InitStructure.ADC_NbrOfConversion = 1; //转换通道1个
ADC_Init(ADC3, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC3,ADC_Channel_1,1,ADC_SampleTime_144Cycles); //设置指定 ADC 的规则组通道,设置它们的转化顺序和采样时间
ADC_DMARequestAfterLastTransferCmd(ADC3, ENABLE);
ADC_DMACmd(ADC3, ENABLE); //使能指定的ADC的DMA
ADC_Cmd(ADC3, ENABLE); //使能指定的ADC
TIM_Cmd(TIM3, ENABLE); //使能TIM3
//ADC_SoftwareStartConv(ADC3); //使能指定的 ADC 的软件转换启动功能
ADC_DeInit();
