uint16_t DataBuf[16] = {0};
static __IO uint32_t TimeOut = SPIT_LONG_TIMEOUT;
static void SPI_GPIO_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
//开端口时钟
SPI_GPIO_APBxClkCmd(SPI_GPIO_CLK,ENABLE);
//配置MOSI端口
GPIO_InitStructure.GPIO_Pin = SPI_MOSI_GPIO_PIN;
//GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(SPI_MOSI_GPIO_PORT,&GPIO_InitStructure);
//配置MISO端口
GPIO_InitStructure.GPIO_Pin = SPI_MISO_GPIO_PIN;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//这个错误我能记一辈子!!
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(SPI_MISO_GPIO_PORT,&GPIO_InitStructure);
//配置SCK端口
GPIO_InitStructure.GPIO_Pin = SPI_SCK_GPIO_PIN;
GPIO_Init(SPI_SCK_GPIO_PORT,&GPIO_InitStructure);
//配置CS端口
GPIO_InitStructure.GPIO_Pin = SPI_CS_PIN;
GPIO_Init(SPI_CS_PORT,&GPIO_InitStructure);
static void SPI_Config(void)
SPI_InitTypeDef SPI_InitStructure;
//开SPI时钟
SPI_APBxClkCmd(SPI_CLK,ENABLE);
//配置SPI结构体
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;//从机模式
SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;//能在NSS为高时忽略CLK,杜邦线连接信号不稳定
SPI_Init(SPIX,&SPI_InitStructure);
//开启接收中断
SPI_I2S_ITConfig(SPIX, SPI_I2S_IT_RXNE, ENABLE);
SPI_Cmd(SPIX,ENABLE);
static void SPI_NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
NVIC_InitStructure.NVIC_IRQChannel = SPIX_IRQ;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
//SPI_FLASH初始化函数
void SPI_M_M_Init(void)
SPI_GPIO_Config();
SPI_Config();
SPI_NVIC_Configuration();
//SPI 发送一个字节,接收一个字节
uint8_t SPI_Send_Byte(u16 data)
while(SPI_I2S_GetFlagStatus(SPIX,SPI_I2S_FLAG_TXE) == RESET)
if(TimeOut-- == 0){DEBUG("发送超时");return 0;}
//printf("发送n");
SPI_I2S_SendData(SPIX,data);//把data写入SPIX->DR
return SPI_I2S_ReceiveData(SPIX);
从机的中断服务函数
//SPI中断服务函数
void SPIX_IRQHandler(void)
uint16_t data;
//接收中断
if(SPI_I2S_GetITStatus(SPIX, SPI_I2S_IT_RXNE))
//接收主机发来的数据
data = SPI_I2S_ReceiveData(SPIX);
//打印一下
printf("data = %dn",data);
if(data == 0xff)
return ;
//SPI_I2S_SendData(SPIX,data);
SPIX->DR = data;
//spi_num != -1说明这次发的是数据,写入数据
if(spi_num != -1 && data != 0xff)
if(data >= TmpDataBuf[spi_num]+10 || data <= TmpDataBuf[spi_num]-10)
TmpDataBuf[spi_num] = data;
printf("TmpDataBuf[%d] = %dn",spi_num,data);
}else
printf("data变化太小--%dn",TmpDataBuf[spi_num]-data);
//spi_num == -1,发的是位置,判断是否在0~15之间
if(spi_num == -1 && data <= 15)
spi_num = data;//记录位置
}else
spi_num = -1;
//不用清除中断标志位,读取数据时就清过了
//而且没有办法用软件清除RXNE标志,不信去看手册
从机的main函数
uint16_t TmpDataBuf[16];
void delay(int n)
while(n--);
int main(void)
SPI_M_M_Init();
USART_Config();
printf("开机!!!n");
while(1)
有趣的是虽然我选择的模式叫双线全双工模式,但是
!!!!!从机永远无法主动联系主机!!!!!
唯一的方法是
从机在主机发来数据之前把要发送的数据填入DR,然后在主机发来数据的同时,
从机把之前在DR中的数据通过MOSI发送给主机。
通信永远是
主机发->从机发->主机发->从机发->主机发->…->从机发->主机发->从机发->主机发->从机发
发送缓冲区、接收缓冲区、DR里的东西不同,
比如主机发来了1,从机接收缓冲区里是1,DR里是1,发送缓冲区是0
主机再发东西时,从机同时回复了发送缓冲区中的0,
如果不向DR中进行写操作,发送缓冲区中的内容不变。
应老师的要求,一个STM32只负责数据监测,另一个STM32只负责数据收发,它们之间通过SPI进行通信。
两个STM32之间的SPI通信跟SPI——FLASH还是有极大区别的。
SPI的双机通信我走了不少弯路,犯了很多错误,愣是搞了差不多一星期。
先吐槽一下:
SPI的双向全双工模式是假的全双工,从机还是受主机支配
对于两个双向通行频繁的设备不建议使用SPI,因为无论如何从机都要受到主机的影响,真的是很配 slave 这个称呼
我的程序是主机负责向从机发送数据(num,data),从机收到后在中断中处理
按下主机的按键1,发数据,从机随手回复发来的数据,从机没人权!!!
连线方式
SCK----SCK
MOSI----MOSI
MISO----MISO
NSS----NSS
废话不多说,直接放我的库函数。
主机部分:
bsp_spi.h
#ifndef _BSP_SPI_H_
#define _BSP_SPI_H_
#include "stm32f10x.h"
#include
#define SPI_GPIO_APBxClkCmd RCC_APB2PeriphClockCmd
#define SPI_GPIO_CLK RCC_APB2Periph_GPIOA
#define SPI_MOSI_GPIO_PORT GPIOA
#define SPI_MOSI_GPIO_PIN GPIO_Pin_7
#define SPI_MISO_GPIO_PORT GPIOA
#define SPI_MISO_GPIO_PIN GPIO_Pin_6
#define SPI_SCK_GPIO_PORT GPIOA
#define SPI_SCK_GPIO_PIN GPIO_Pin_5
#define SPI_APBxClkCmd RCC_APB2PeriphClockCmd
#define SPI_CLK RCC_APB2Periph_SPI1
#define SPIX SPI1
#define SPI_CS_PORT GPIOA
#define SPI_CS_PIN GPIO_Pin_4
#define SPIX_IRQ SPI1_IRQn
#define SPIX_IRQHandler SPI1_IRQHandler
//选择flash
#define SPI_CS_HIGH GPIO_SetBits(SPI_CS_PORT,SPI_CS_PIN);
#define SPI_CS_LOW GPIO_ResetBits(SPI_CS_PORT,SPI_CS_PIN);
/*等待超时时间*/
#define SPIT_FLAG_TIMEOUT ((uint32_t)0x1000)
#define SPIT_LONG_TIMEOUT ((uint32_t)(10 * SPIT_FLAG_TIMEOUT))
/*信息输出*/
#define DEBUG_ON 1
#define INFO(fmt,arg...) printf("<<-INFO->> "fmt"n",##arg)
#define ERROR(fmt,arg...) printf("<<-ERROR->> "fmt"n",##arg)
#define DEBUG(fmt,arg...) do{
if(DEBUG_ON)
printf("<<-DEBUG->> [%s][%d]"fmt"n",__FILE__,__LINE__, ##arg);
}while(0)
void SPI_M_M_Init(void);
uint8_t SPI_Send_Byte(u16 data);
uint8_t SPI_Read_Byte(void);
uint8_t SPI_Send_Data(u16 num,u16 data);
#endif // _BSP_SPI_H_
bsp_spi.c
#include "bsp_spi.h"
#include
//开端口时钟
//配置MOSI端口
//配置MISO端口
//GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
//配置SCK端口
//配置CS端口
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
SPI_CS_HIGH;
//开SPI时钟
//配置SPI结构体
SPI_InitStructure.SPI_CRCPolynomial = 0;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;//主机模式
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
//开启接收中断
//SPI_I2S_ITConfig(SPIX, SPI_I2S_IT_RXNE, ENABLE);
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
//SPI_FLASH初始化函数
SPI_GPIO_Config();
SPI_Config();
//SPI 发送一个字节,接收一个字节
//实际上主机不需要等待从机发送,因为只有在主机发送时,从机才会发送 发送缓冲区 中的东西
while(SPI_I2S_GetFlagStatus(SPIX,SPI_I2S_FLAG_TXE) == RESET)//等待发送完毕
while(SPI_I2S_GetFlagStatus(SPIX,SPI_I2S_FLAG_RXNE) == RESET)//等待接收完毕
if(TimeOut-- == 0){DEBUG("接收超时");return 0;}
//这是一个延时函数
void delay(u32 n)
while(n--);
//向另一个mcu发送数据
//num 位置 data 数据
//正常 return 0 异常return 1
uint16_t temp = 0;
printf("发送 num:%d data:%dn",num,data);
SPI_CS_LOW;//拉低CS
SPI_Send_Byte(num);
//加延时是因为从机使用了中断处理数据,相对于SPI来说
//中断太慢了,所以不加延时函数无法让从机及时回复
//不过我让从机回复只是为了证明可以双向通行罢了,如果只是发送,完全可以把延时删掉
delay(0xffff);
temp = SPI_Send_Byte(data);
if(temp != num)
printf("num err :%dn",temp);
SPI_CS_HIGH;//拉高CS
return 1;
delay(0xffff);
temp = SPI_Send_Byte(0xff);
if(temp != data)
printf("data err :%dn",temp);
SPI_CS_HIGH;//拉高CS
return 1;
SPI_CS_HIGH;//拉高CS
return 0;
主机main函数
int main(void)
int i = 0;
int n = 0;
SPI_M_M_Init();
USART_Config();
Key_Configer();
printf("开机!!!n");
while(1)
if(Key_Scan(KEY1_GPIO_PORT,KEY1_GPIO_PIN))
i++;
if(i>3)
i = 0;
if(0 == SPI_Send_Data(i,i+n))
printf("通信正常 %d,%dn",i,i+n);
}else
printf("通信异常n");
n++;
if(Key_Scan(KEY2_GPIO_PORT,KEY2_GPIO_PIN))
printf("(||—_—)n");
从机部分
bsp_spi.h
#ifndef _BSP_SPI_H_
#define _BSP_SPI_H_
#include
#define SPIX SPI1
//选择flash
/*等待超时时间*/
/*信息输出*/
#define DEBUG_ON 1
if(DEBUG_ON)
}while(0)
bsp_spi.c
#include
//开端口时钟
//配置MOSI端口
//配置MISO端口
//配置SCK端口
//配置CS端口
//开SPI时钟
//配置SPI结构体
//开启接收中断
//SPI_FLASH初始化函数
SPI_GPIO_Config();
SPI_Config();
//SPI 发送一个字节,接收一个字节
//printf("发送n");
从机的中断服务函数
//SPI中断服务函数
uint16_t data;
//接收中断
//接收主机发来的数据
//打印一下
if(data == 0xff)
return ;
SPIX->DR = data;
}else
}else
spi_num = -1;
从机的main函数
void delay(int n)
while(n--);
int main(void)
SPI_M_M_Init();
USART_Config();
printf("开机!!!n");
while(1)
唯一的方法是
通信永远是
