设计介绍
这是一个简单的故障设计检测的,使用到模块的有STM32C8T6,LCD1602液晶显示器,显示的检测以及设置的阈值,阈值可以通过设置,当测得的阈值超过阈值时,蜂鸣会报警,以及一个心率传感器需要参考的朋友可以在文章底部点击下载源码和原理图。 main.c中中的代码如下: #include "main.h" #include "stm32f1xx_hal.h" #include "rtc.h" #include "tim.h" #include "usart.h" #include "gpio.h" /* USER CODE BEGIN Includes */ #include "LCD1602.h" #include "MEMORY.h" /* USER CODE END Includes */ /* Private variables ---------------------------------------------------------*/ /* USER CODE BEGIN PV */ /* Private variables ---------------------------------------------------------*/ extern void RTC_CalendarShow(void); void police_dispose(void); void display(void); void key_scan(void); extern unsigned int xinlv; void dis_play(void); extern void Sensor(void); char Read_ADC=0; uint16_t ADC_Dat=0; uint8_t key1_flag = 0,key2_flag = 0,key3_flag = 0; uint8_t sec1=0,sec2=0,memory_flag=0; static uint8_t state=0; uint8_t s0,HH,LL; /* USER CODE END PV */ /* Private function prototypes -----------------------------------------------*/ void SystemClock_Config(void); void Error_Handler(void); /* USER CODE BEGIN PFP */ /* Private function prototypes -----------------------------------------------*/ /* USER CODE END PFP */ /* USER CODE BEGIN 0 */ #define key1 HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_0) #define key2 HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_1) #define key3 HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_10) #define beep_write_0 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_0,GPIO_PIN_RESET) #define beep_write_1 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_0,GPIO_PIN_SET) #define led1_0 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_11,GPIO_PIN_RESET) #define led1_1 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_11,GPIO_PIN_SET) #define led2_0 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_10,GPIO_PIN_RESET) #define led2_1 HAL_GPIO_WritePin(GPIOB,GPIO_PIN_10,GPIO_PIN_SET) /* USER CODE END 0 */ int main(void) { /* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /* MCU Configuration----------------------------------------------------------*/ /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); /* Configure the system clock */ SystemClock_Config(); /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_RTC_Init(); MX_USART1_UART_Init(); MX_TIM3_Init(); MX_TIM2_Init(); /* USER CODE BEGIN 2 */ HAL_Delay(20); LCD1602_cls(); HAL_TIM_Base_Start_IT(&htim3); //启动定时器 //HAL_TIM_Base_Start_IT(&htim2); led2_0; // Write_flsh_byte(0x08009000,153); // Write_flsh_byte(0x0800A000,41); // read_memory();//flash初始化 HH= readFlash(0x08009000); LL= readFlash(0x0800A000); printf("before %d%d",HH,LL); /* USER CODE END 2 */ /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { /* USER CODE END WHILE */ /* USER CODE BEGIN 3 */ police_dispose(); display(); if(memory_flag) { memory_flag=0; Write_flsh_byte(0x08009000,HH); Write_flsh_byte(0x0800A000,LL); } /* USER CODE END 3 */ } } /** System Clock Configuration */ void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct; RCC_ClkInitTypeDef RCC_ClkInitStruct; RCC_PeriphCLKInitTypeDef PeriphClkInit; /**Initializes the CPU, AHB and APB busses clocks */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE |RCC_OSCILLATORTYPE_LSE; RCC_OscInitStruct.HSEState = RCC_HSE_ON; RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1; RCC_OscInitStruct.LSEState = RCC_LSE_ON; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9; if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } /**Initializes the CPU, AHB and APB busses clocks */ RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2; RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK) { Error_Handler(); } PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC; PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSE; if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK) { Error_Handler(); } /**Enables the Clock Security System */ HAL_RCC_EnableCSS(); /**Configure the Systick interrupt time */ HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000); /**Configure the Systick */ HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK); /* SysTick_IRQn interrupt configuration */ HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0); } /* USER CODE BEGIN 4 */ void display(void) { RTC_CalendarShow();// 第一行显示 LCD1602_write(0,0xC0);//第一行显示 if(state==1&&s0) { LCD1602_writebyte((unsigned char *)"High:"); LCD1602_writebyte((unsigned char *)" "); LCD1602_writebyte((unsigned char *)"Low:"); LCD1602_write(1,0x30+LL/100%10); LCD1602_write(1,0x30+LL/10%10); LCD1602_write(1,0x30+LL%10); } else if(state==2&&s0) { LCD1602_writebyte((unsigned char *)"High:"); LCD1602_write(1,0x30+HH/100%10); LCD1602_write(1,0x30+HH/10%10); LCD1602_write(1,0x30+HH%10); LCD1602_writebyte((unsigned char *)" "); LCD1602_writebyte((unsigned char *)"Low:"); LCD1602_writebyte((unsigned char *)" "); } else { LCD1602_writebyte((unsigned char *)"High:"); LCD1602_write(1,0x30+HH/100%10); LCD1602_write(1,0x30+HH/10%10); LCD1602_write(1,0x30+HH%10); LCD1602_writebyte((unsigned char *)" "); LCD1602_writebyte((unsigned char *)"Low:"); LCD1602_write(1,0x30+LL/100%10); LCD1602_write(1,0x30+LL/10%10); LCD1602_write(1,0x30+LL%10); } } void police_dispose(void) { if(xinlv>HH||((xinlv HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_0); HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_11); HAL_Delay(500); } else { led1_1; beep_write_0; } } |
1855 浏览 1 评论
1647 浏览 1 评论
1122 浏览 2 评论
748 浏览 2 评论
1706 浏览 2 评论
1959浏览 9评论
770浏览 4评论
598浏览 3评论
620浏览 3评论
578浏览 3评论
GMT+8, 2025-1-6 06:22 , Processed in 0.733550 second(s), Total 77, Slave 61 queries .
