一、STM32启动文件详细解析
STM32启动文件详细解析(V3.5.0) 以:startup_stm32f10x_hd.s为例
;******************** (C) COPYRIGHT 2011 STMicroelectronics ********************
- ;* 文件名:startup_stm32f10x_hd.s
- ;* 作者:MCD 应用团队
- ;* 版本:V3.5.0
- ;* 日期:2011 年 3 月 11 日
- ;* 说明:STM32F10x 高密度器件 MDK-ARM 向量表
- ;* 工具链。
- ;* 该模块执行:
- ;* - 设置初始 SP
- ;* - 设置初始 PC == Reset_Handler
- ;* - 使用异常 ISR 地址设置向量表条目
- ;* - Configure the clock system and also configure the external
- ;* SRAM mounted on STM3210E-EVAL board to be used as data
- ;* memory (optional, to be enabled by user)
- ;* - Branches to __main in the C library (which eventually
- ;* calls main()).
- ;* After Reset the CortexM3 processor is in Thread mode,
- ;* priority is Privileged, and the Stack is set to Main.
- ;* <<< Use Configuration Wizard in Context Menu >>>
- ; THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
- ; WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
- ; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
- ; INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
- ; CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
- ; INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
- ; Amount of memory (in bytes) allocated for Stack
- ; Tailor this value to your application needs
- ; Stack Configuration ;栈定义
- ; Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
- Stack_Size EQU 0x00000400 ;EQU伪指令,作用是左边的符号名代表右边的表达式
- AREA STACK, NOINIT, READWRITE, ALIGN=3 ;定义栈段:名称为STACK,未初始化,可读写,ELF 的栈段按2^3=8对齐
- Stack_Mem SPACE Stack_Size ;分配一片连续的存储区域并初始化为 0,栈空间:0x400个字节
- __initial_sp ;栈空间顶地址
- ; Heap Configuration ;堆定义
- ; Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
- Heap_Size EQU 0x00000200
- AREA HEAP, NOINIT, READWRITE, ALIGN=3
- __heap_base ;堆空间起始地址
- Heap_Mem SPACE Heap_Size ;堆空间:0x200个字节
- __heap_limit ;堆空间结束地址
- PRESERVE8 ;PRESERVE8 指令指定当前文件保持堆栈八字节对齐
- THUMB ;告诉汇编器下面是32位的Thumb指令,如果需要汇编器将插入位以保证对齐
- ; Vector Table Mapped to Address 0 at Reset ;中断向量表定义
- ;实际上是在CODE区(假设STM32从FLASH启动,则此中断向量表起始地址即为0x8000000)
- AREA RESET, DATA, READONLY ;定义一块数据段,只可读,段名字是RESET
- EXPORT __Vectors ;EXPORT:在程序中声明一个全局的标号__Vectors,该标号可在其他的文件中引用
- EXPORT __Vectors_End ;在程序中声明一个全局的标号__Vectors_End
- EXPORT __Vectors_Size ;在程序中声明一个全局的标号__Vectors_Size
- ;DCD(DCDU)用于分配一片连续的字存储单元并用指定的数据初始化。
- __Vectors DCD __initial_sp ; Top of Stack ;该处物理地址值存储__initial_sp所表示的地址值,即为 __Vetors 标号所表示的值
- DCD Reset_Handler ; Reset Handler
- DCD NMI_Handler ; NMI Handler
- DCD HardFault_Handler ; Hard Fault Handler
- DCD MemManage_Handler ; MPU Fault Handler
- DCD BusFault_Handler ; Bus Fault Handler
- DCD UsageFault_Handler ; Usage Fault Handler
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD SVC_Handler ; SVCall Handler
- DCD DebugMon_Handler ; Debug Monitor Handler
- DCD 0 ; Reserved
- DCD PendSV_Handler ; PendSV Handler
- DCD SysTick_Handler ; SysTick Handler
- ; External Interrupts ;以下为外部中断向量表
- DCD WWDG_IRQHandler ; Window Watchdog
- DCD PVD_IRQHandler ; PVD through EXTI Line detect
- DCD TAMPER_IRQHandler ; Tamper
- DCD RTC_IRQHandler ; RTC
- DCD FLASH_IRQHandler ; Flash
- DCD RCC_IRQHandler ; RCC
- DCD EXTI0_IRQHandler ; EXTI Line 0
- DCD EXTI1_IRQHandler ; EXTI Line 1
- DCD EXTI2_IRQHandler ; EXTI Line 2
- DCD EXTI3_IRQHandler ; EXTI Line 3
- DCD EXTI4_IRQHandler ; EXTI Line 4
- DCD DMA1_Channel1_IRQHandler ; DMA1 Channel 1
- DCD DMA1_Channel2_IRQHandler ; DMA1 Channel 2
- DCD DMA1_Channel3_IRQHandler ; DMA1 Channel 3
- DCD DMA1_Channel4_IRQHandler ; DMA1 Channel 4
- DCD DMA1_Channel5_IRQHandler ; DMA1 Channel 5
- DCD DMA1_Channel6_IRQHandler ; DMA1 Channel 6
- DCD DMA1_Channel7_IRQHandler ; DMA1 Channel 7
- DCD ADC1_2_IRQHandler ; ADC1 & ADC2
- DCD USB_HP_CAN1_TX_IRQHandler ; USB High Priority or CAN1 TX
- DCD USB_LP_CAN1_RX0_IRQHandler ; USB Low Priority or CAN1 RX0
- DCD CAN1_RX1_IRQHandler ; CAN1 RX1
- DCD CAN1_SCE_IRQHandler ; CAN1 SCE
- DCD EXTI9_5_IRQHandler ; EXTI Line 9..5
- DCD TIM1_BRK_IRQHandler ; TIM1 Break
- DCD TIM1_UP_IRQHandler ; TIM1 Update
- DCD TIM1_TRG_COM_IRQHandler ; TIM1 Trigger and Commutation
- DCD TIM1_CC_IRQHandler ; TIM1 Capture Compare
- DCD TIM2_IRQHandler ; TIM2
- DCD TIM3_IRQHandler ; TIM3
- DCD TIM4_IRQHandler ; TIM4
- DCD I2C1_EV_IRQHandler ; I2C1 Event
- DCD I2C1_ER_IRQHandler ; I2C1 Error
- DCD I2C2_EV_IRQHandler ; I2C2 Event
- DCD I2C2_ER_IRQHandler ; I2C2 Error
- DCD SPI1_IRQHandler ; SPI1
- DCD SPI2_IRQHandler ; SPI2
- DCD USART1_IRQHandler ; USART1
- DCD USART2_IRQHandler ; USART2
- DCD USART3_IRQHandler ; USART3
- DCD EXTI15_10_IRQHandler ; EXTI Line 15..10
- DCD RTCAlarm_IRQHandler ; RTC Alarm through EXTI Line
- DCD USBWakeUp_IRQHandler ; USB Wakeup from suspend
- DCD TIM8_BRK_IRQHandler ; TIM8 Break
- DCD TIM8_UP_IRQHandler ; TIM8 Update
- DCD TIM8_TRG_COM_IRQHandler ; TIM8 Trigger and Commutation
- DCD TIM8_CC_IRQHandler ; TIM8 Capture Compare
- DCD ADC3_IRQHandler ; ADC3
- DCD FSMC_IRQHandler ; FSMC
- DCD SDIO_IRQHandler ; SDIO
- DCD TIM5_IRQHandler ; TIM5
- DCD SPI3_IRQHandler ; SPI3
- DCD UART4_IRQHandler ; UART4
- DCD UART5_IRQHandler ; UART5
- DCD TIM6_IRQHandler ; TIM6
- DCD TIM7_IRQHandler ; TIM7
- DCD DMA2_Channel1_IRQHandler ; DMA2 Channel1
- DCD DMA2_Channel2_IRQHandler ; DMA2 Channel2
- DCD DMA2_Channel3_IRQHandler ; DMA2 Channel3
- DCD DMA2_Channel4_5_IRQHandler ; DMA2 Channel4 & Channel5
- __Vectors_End ;Vectors结束
- __Vectors_Size EQU __Vectors_End - __Vectors ;得到向量表的大小,304个字节也就是0x130个字节
- AREA |.text|, CODE, READONLY ;定义一个代码段,可读,段名字是.text
- ;|.text| 用于表示由 C 编译程序产生的代码段,或用于以某种方式与 C 库关联的代码段
- ; Reset handler ;利用PROC、ENDP这一对伪指令标记程序开始、结束,把程序段分为若干个过程,使程序的结构加清晰
- Reset_Handler PROC
- EXPORT Reset_Handler [WEAK];WEAK声明其他的同名标号优先于该标号被引用,就是说如果外面声明了的话,调用外面的对应函数
- IMPORT __main ;IMPORT:伪指令用于通知编译器要使用的标号在其他的源文件中定义
- IMPORT SystemInit
- LDR R0, =SystemInit ;系统初始化
- BLX R0 ;带链接的跳转,切换指令集,跳到SystemInit
- LDR R0, =__main ;__main为运行时库提供的函数;完成堆栈,堆的初始化等工作,会调用下面定义的__user_initial_stackheap
- BX R0 ;切换指令集,main函数不返回跳到__main,进入C的世界
- ENDP
- ; Dummy Exception Handlers (infinite loops which can be modified)
- NMI_Handler PROC
- EXPORT NMI_Handler [WEAK];不可屏蔽中断处理函数
- B .
- ENDP
- HardFault_Handler ;意为换行
- PROC
- EXPORT HardFault_Handler [WEAK];硬件错误处理函数
- B .
- ENDP
- MemManage_Handler
- PROC
- EXPORT MemManage_Handler [WEAK]
- B .
- ENDP
- BusFault_Handler
- PROC
- EXPORT BusFault_Handler [WEAK]
- B .
- ENDP
- UsageFault_Handler
- PROC
- EXPORT UsageFault_Handler [WEAK]
- B .
- ENDP
- SVC_Handler PROC
- EXPORT SVC_Handler [WEAK]
- B .
- ENDP
- DebugMon_Handler
- PROC
- EXPORT DebugMon_Handler [WEAK]
- B .
- ENDP
- PendSV_Handler PROC
- EXPORT PendSV_Handler [WEAK]
- B .
- ENDP
- SysTick_Handler PROC
- EXPORT SysTick_Handler [WEAK]
- B .
- ENDP
- Default_Handler PROC
- ;输出异常向量表标号,方便外部实现异常的具体功能,[WEAK]是弱定义的意思,如果外部定义了,优先执行外部定义,否则下面的函数定义
- EXPORT WWDG_IRQHandler [WEAK]
- EXPORT PVD_IRQHandler [WEAK]
- EXPORT TAMPER_IRQHandler [WEAK]
- EXPORT RTC_IRQHandler [WEAK]
- EXPORT FLASH_IRQHandler [WEAK]
- EXPORT RCC_IRQHandler [WEAK]
- EXPORT EXTI0_IRQHandler [WEAK]
- EXPORT EXTI1_IRQHandler [WEAK]
- EXPORT EXTI2_IRQHandler [WEAK]
- EXPORT EXTI3_IRQHandler [WEAK]
- EXPORT EXTI4_IRQHandler [WEAK]
- EXPORT DMA1_Channel1_IRQHandler [WEAK]
- EXPORT DMA1_Channel2_IRQHandler [WEAK]
- EXPORT DMA1_Channel3_IRQHandler [WEAK]
- EXPORT DMA1_Channel4_IRQHandler [WEAK]
- EXPORT DMA1_Channel5_IRQHandler [WEAK]
- EXPORT DMA1_Channel6_IRQHandler [WEAK]
- EXPORT DMA1_Channel7_IRQHandler [WEAK]
- EXPORT ADC1_2_IRQHandler [WEAK]
- EXPORT USB_HP_CAN1_TX_IRQHandler [WEAK]
- EXPORT USB_LP_CAN1_RX0_IRQHandler [WEAK]
- EXPORT CAN1_RX1_IRQHandler [WEAK]
- EXPORT CAN1_SCE_IRQHandler [WEAK]
- EXPORT EXTI9_5_IRQHandler [WEAK]
- EXPORT TIM1_BRK_IRQHandler [WEAK]
- EXPORT TIM1_UP_IRQHandler [WEAK]
- EXPORT TIM1_TRG_COM_IRQHandler [WEAK]
- EXPORT TIM1_CC_IRQHandler [WEAK]
- EXPORT TIM2_IRQHandler [WEAK]
- EXPORT TIM3_IRQHandler [WEAK]
- EXPORT TIM4_IRQHandler [WEAK]
- EXPORT I2C1_EV_IRQHandler [WEAK]
- EXPORT I2C1_ER_IRQHandler [WEAK]
- EXPORT I2C2_EV_IRQHandler [WEAK]
- EXPORT I2C2_ER_IRQHandler [WEAK]
- EXPORT SPI1_IRQHandler [WEAK]
- EXPORT SPI2_IRQHandler [WEAK]
- EXPORT USART1_IRQHandler [WEAK]
- EXPORT USART2_IRQHandler [WEAK]
- EXPORT USART3_IRQHandler [WEAK]
- EXPORT EXTI15_10_IRQHandler [WEAK]
- EXPORT RTCAlarm_IRQHandler [WEAK]
- EXPORT USBWakeUp_IRQHandler [WEAK]
- EXPORT TIM8_BRK_IRQHandler [WEAK]
- EXPORT TIM8_UP_IRQHandler [WEAK]
- EXPORT TIM8_TRG_COM_IRQHandler [WEAK]
- EXPORT TIM8_CC_IRQHandler [WEAK]
- EXPORT ADC3_IRQHandler [WEAK]
- EXPORT FSMC_IRQHandler [WEAK]
- EXPORT SDIO_IRQHandler [WEAK]
- EXPORT TIM5_IRQHandler [WEAK]
- EXPORT SPI3_IRQHandler [WEAK]
- EXPORT UART4_IRQHandler [WEAK]
- EXPORT UART5_IRQHandler [WEAK]
- EXPORT TIM6_IRQHandler [WEAK]
- EXPORT TIM7_IRQHandler [WEAK]
- EXPORT DMA2_Channel1_IRQHandler [WEAK]
- EXPORT DMA2_Channel2_IRQHandler [WEAK]
- EXPORT DMA2_Channel3_IRQHandler [WEAK]
- EXPORT DMA2_Channel4_5_IRQHandler [WEAK]
- ;如下只是定义一些空函数
- WWDG_IRQHandler
- PVD_IRQHandler
- TAMPER_IRQHandler
- RTC_IRQHandler
- FLASH_IRQHandler
- RCC_IRQHandler
- EXTI0_IRQHandler
- EXTI1_IRQHandler
- EXTI2_IRQHandler
- EXTI3_IRQHandler
- EXTI4_IRQHandler
- DMA1_Channel1_IRQHandler
- DMA1_Channel2_IRQHandler
- DMA1_Channel3_IRQHandler
- DMA1_Channel4_IRQHandler
- DMA1_Channel5_IRQHandler
- DMA1_Channel6_IRQHandler
- DMA1_Channel7_IRQHandler
- ADC1_2_IRQHandler
- USB_HP_CAN1_TX_IRQHandler
- USB_LP_CAN1_RX0_IRQHandler
- CAN1_RX1_IRQHandler
- CAN1_SCE_IRQHandler
- EXTI9_5_IRQHandler
- TIM1_BRK_IRQHandler
- TIM1_UP_IRQHandler
- TIM1_TRG_COM_IRQHandler
- TIM1_CC_IRQHandler
- TIM2_IRQHandler
- TIM3_IRQHandler
- TIM4_IRQHandler
- I2C1_EV_IRQHandler
- I2C1_ER_IRQHandler
- I2C2_EV_IRQHandler
- I2C2_ER_IRQHandler
- SPI1_IRQHandler
- SPI2_IRQHandler
- USART1_IRQHandler
- USART2_IRQHandler
- USART3_IRQHandler
- EXTI15_10_IRQHandler
- RTCAlarm_IRQHandler
- USBWakeUp_IRQHandler
- TIM8_BRK_IRQHandler
- TIM8_UP_IRQHandler
- TIM8_TRG_COM_IRQHandler
- TIM8_CC_IRQHandler
- ADC3_IRQHandler
- FSMC_IRQHandler
- SDIO_IRQHandler
- TIM5_IRQHandler
- SPI3_IRQHandler
- UART4_IRQHandler
- UART5_IRQHandler
- TIM6_IRQHandler
- TIM7_IRQHandler
- DMA2_Channel1_IRQHandler
- DMA2_Channel2_IRQHandler
- DMA2_Channel3_IRQHandler
- DMA2_Channel4_5_IRQHandler
- B .
- ENDP
- ALIGN ;默认是字对齐方式,也说明了代码是4字节对齐的
- ; User Stack and Heap initialization 用户堆栈初始化
- IF :DEF:__MICROLIB ;判断是否使用DEF:__MICROLIB(micro lib),如果勾选了micro lib
- EXPORT __initial_sp ;将栈顶地址、堆起始地址、堆结束地址赋予全局属性,使外部程序可用
- EXPORT __heap_base
- EXPORT __heap_limit
- ELSE ;如果没有勾选micro lib
- IMPORT __use_two_region_memory ;两区堆栈空间,堆和栈有各自的空间地址
- EXPORT __user_initial_stackheap
- __user_initial_stackheap ;标号__user_initial_stackheap,表示用户堆栈初始化程序入口
- ;此处是初始化两区的堆栈空间,堆是从由低到高的增长,栈是由高向低生长的,两个是互相独立的数据段,并不能交叉使用。
- LDR R0, = Heap_Mem ;保存堆起始地址
- LDR R1, =(Stack_Mem + Stack_Size) ;保存栈结束地址
- LDR R2, = (Heap_Mem + Heap_Size) ;保存堆结束地址
- LDR R3, = StackMem ;保存栈地址_
- BX LR
- 对齐
- 万一
- END ;END命令指示器,已到达一个源文件的导出
- ;******************* (C) COPYRIGHT 2011 STMicroelectronics *****文件结束*****
二、STM32中断向量表的位置、用户
知道怎么跳到主函数了,那么中断发生后,又是跑到中断入口地址的呢?
从stm32f10x.s可以看到,已经定义好了堆栈的中断响应函数,这就是中断中断表,标号__向量,表示中断中断表入口地址,例如:
AREA RESET, DATA, READONLY ; 定义只读数据段,实际上是在CODE区(虚拟STM32从FLASH启动,则此中断表地址即为0x8000000)
[cpp] view plain copy
- 出口 __Vectors
- OS_CPU_SysTickHandler
- 导入 OS_CPU_PendSVHandler
- rs DCD __initial_sp; 栈顶
表的写是有特色的,跟硬件一对应不能乱写的,CPU找入口地址就靠边了,bin文件开头就是靠他们的地址,参考手册RM0008的10.1.2节可以排列出现。
我们CORTEX-M3的特性,他上电后根据,结合启动来决定PC位置,例如启动设置为flash启动则启动后PC跳到0x08000000。此时CPU会先取2个地址,第一个是栈顶地址,第二个是复位异常地址,所以上面的写法,这样就跳到reset_handler。
那么这个reset_handler的具体地址是多少。?下面的例子Nmi_handler地址又是怎么发生的?怎么跑到这个地址呢?下面挨个讲解。
1、我们可以通过我们来了解这些入口地址,查看工程下了的地图文件就可以看到这个,地址跟keil里面设置的target->flash浏览地址息息相关,实际上我们不太需要关心,让编译器分配,中断向量表放的就是他们的地址。
2,对比ARM7 / ARM9内核,Cortex-M3的内核则是固定了中断向量表的位置而起始地址是可变化的。
如图3所示,进到ç语言后会先配置NVIC,NVIC_SetVectorTable()里面可以配置中断向量表的起始地址和偏移,主要是告诉CPU该向量表是位于闪存还是拉姆,偏移是
4、发生中断后,CPU找到中断表地址,然后根据偏移定位了。(对号入座)再找到中断地址,这样就跳过去了。
我们截一个图说明一下,地图文件:对应
的bin文件,看是不是放的上面地址:
各,200039c0就是栈顶地址,08006F21就是reset_handler地址!
如何定位?以设置0x20000001
、keil设置ram为0x200000100,我们在0x200000000~0x200000~0x200000100程序中断用
,、 NVIC_SetVectorTable(NVIC_VectTab_FLASH,0);
3、跳到C时把中断动画复制到0x20000000
一、STM32启动文件详细解析
- ;* 作者:MCD 应用团队
- ;* 版本:V3.5.0
- ;* 工具链。
- ;* 该模块执行:
- ;* - 设置初始 SP
- ;* calls main()).
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- DCD 0 ; Reserved
- IMPORT SystemInit
- ENDP
- NMI_Handler PROC
- B .
- ENDP
- PROC
- B .
- ENDP
- MemManage_Handler
- PROC
- B .
- ENDP
- BusFault_Handler
- PROC
- B .
- ENDP
- PROC
- B .
- ENDP
- SVC_Handler PROC
- B .
- ENDP
- DebugMon_Handler
- PROC
- B .
- ENDP
- B .
- ENDP
- B .
- ENDP
- ;如下只是定义一些空函数
- WWDG_IRQHandler
- PVD_IRQHandler
- TAMPER_IRQHandler
- RTC_IRQHandler
- FLASH_IRQHandler
- RCC_IRQHandler
- EXTI0_IRQHandler
- EXTI1_IRQHandler
- EXTI2_IRQHandler
- EXTI3_IRQHandler
- EXTI4_IRQHandler
- ADC1_2_IRQHandler
- TIM2_IRQHandler
- TIM3_IRQHandler
- TIM4_IRQHandler
- SPI1_IRQHandler
- SPI2_IRQHandler
- USART1_IRQHandler
- USART2_IRQHandler
- USART3_IRQHandler
- ADC3_IRQHandler
- FSMC_IRQHandler
- SDIO_IRQHandler
- TIM5_IRQHandler
- SPI3_IRQHandler
- UART4_IRQHandler
- UART5_IRQHandler
- TIM6_IRQHandler
- TIM7_IRQHandler
- B .
- ENDP
- BX LR
- 对齐
- 万一
二、STM32中断向量表的位置、用户
- 出口 __Vectors
我们截一个图说明一下,地图文件:对应
的bin文件,看是不是放的上面地址:
如何定位?以设置0x20000001
