STM32程序 参考上一篇 Ubuntu16之STM32开发–点灯和串口通信, 主要代码节选如下: uint8_t count = 0; while (1) { ++count; HAL_GPIO_TogglePin(LD2_GPIO_Port, LD2_Pin); printf("Hello, %3drn", count); HAL_Delay(100); } 每100ms串口发送给上位机 “Hello, %3drn” 的字符, 串口识别为 /dev/ttyACM0. ROS程序 mkdir -p ~/catkin_ws/src cd ~/catkin_ws/src catkin_create_pkg serial_communication roscpp std_msgs cd serial_communication/src touch serial_communication.cpp gedit serial_communication.cpp # code serial_communication.cpp ~/catkin_ws/src/serial_communication/src/serial_communication.cpp 内容: //reference: https://www.cnblogs.com/li-yao7758258/p/5794005.html #include #include #include #include #include "std_msgs/String.h" //ros定义的String数据类型 using namespace std; using namespace boost::asio; //定义一个命名空间,用于后面的读写操作 unsigned char buf[12]; //定义字符串长度 int main(int argc, char **argv) { ros::init(argc, argv, "serial_communication"); //初始化节点 ros::NodeHandle n; ros::Publisher chatter_pub = n.advertise ros::Rate loop_rate(10); io_service iosev; serial_port sp(iosev, "/dev/ttyACM0"); //定义传输的串口 sp.set_option(serial_port::baud_rate(115200)); sp.set_option(serial_port::flow_control()); sp.set_option(serial_port::parity()); sp.set_option(serial_port::stop_bits()); sp.set_option(serial_port::character_size(8)); while (ros::ok()) { //write(sp, buffer(buf1, 6)); //write the speed for cmd_val //write(sp, buffer("Hellq world", 12)); read(sp, buffer(buf)); string str(&buf[0], &buf[11]); //将数组转化为字符串 //if (buf[10] == 'n') { std_msgs::String msg; std::stringstream ss; ss << str; msg.data = ss.str(); ROS_INFO("%s", msg.data.c_str()); //打印接受到的字符串 chatter_pub.publish(msg); //发布消息 ros::spinOnce(); loop_rate.sleep(); } } iosev.run(); return 0; } 保存后, 打开 ~/catkin_ws/src/serial_communication/CMakeLists.txt, 最后面加上: add_executable(serial_communication src/serial_communication.cpp) target_link_libraries(serial_communication ${catkin_LIBRARIES}) 保存. # 第一个终端 roscore # 第二个终端 cd ~/catkin_ws catkin_make source devel/setup.bash chmod 777 /dev/ttyACM0 # 如果之前 CuteCom 已经打开, 记得关了, 免得USB虚拟串口占用. rosrun serial_communication serial_communication 然后就会看到ROS中打印出如下信息: lz@lz-pc:~/catkin_ws$ rosrun serial_communication serial_communication [ INFO] [1542939474.069999764]: Hello, 74 [ INFO] [1542939474.169567482]: Hello, 75 [ INFO] [1542939474.269443664]: Hello, 76 [ INFO] [1542939474.369511941]: Hello, 77 [ INFO] [1542939474.469562788]: Hello, 78 [ INFO] [1542939474.569548019]: Hello, 79 [ INFO] [1542939474.669471010]: Hello, 80 [ INFO] [1542939474.769552072]: Hello, 81 [ INFO] [1542939474.869545703]: Hello, 82 [ INFO] [1542939474.969443991]: Hello, 83 |
1845 浏览 1 评论
1647 浏览 1 评论
1116 浏览 2 评论
745 浏览 2 评论
1700 浏览 2 评论
1958浏览 9评论
766浏览 4评论
595浏览 3评论
618浏览 3评论
578浏览 3评论
GMT+8, 2025-1-4 07:54 , Processed in 0.613418 second(s), Total 46, Slave 40 queries .
