STM32
shawon
12年用户 622经验值
stm32串口1和RS485通信的串口2的配置过程是怎样的?
STM32串口1和RS485通信的串口2的配置过程是怎样的?
回帖(1)
苏天兰
2021-12-8 10:00:43
stm32串口1的配置
#if EN_USART1_RX   //如果使能了接收
//串口1中断服务程序
//注意,读取USARTx->SR能避免莫名其妙的错误
u8 USART_RX_BUF[USART_REC_LEN];     //接收缓冲,最大USART_REC_LEN个字节.
//接收状态
//bit15,    接收完成标志
//bit14,    接收到0x0d
//bit13~0,    接收到的有效字节数目
u16 USART_RX_STA=0;       //接收状态标记
void uart_init(u32 bound){
  //GPIO端口设置
  GPIO_InitTypeDef GPIO_InitStructure;
    USART_InitTypeDef USART_InitStructure;
    NVIC_InitTypeDef NVIC_InitStructure;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE);    //使能USART1,GPIOA时钟
    //USART1_TX   GPIOA.9
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;    //复用推挽输出
  GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9
  //USART1_RX      GPIOA.10初始化
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
  GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
  //Usart1 NVIC 配置
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;        //子优先级3
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;            //IRQ通道使能
    NVIC_Init(&NVIC_InitStructure);    //根据指定的参数初始化VIC寄存器
   //USART 初始化设置
    USART_InitStructure.USART_BaudRate = bound;//串口波特率
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
    USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
    USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;    //收发模式
  USART_Init(USART1, &USART_InitStructure); //初始化串口1
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启串口接受中断
  USART_Cmd(USART1, ENABLE);                    //使能串口1
void USART1_IRQHandler(void)                    //串口1中断服务程序
    u8 Res;
#if SYSTEM_SUPPORT_OS         //如果SYSTEM_SUPPORT_OS为真,则需要支持OS.
    OSIntEnter();
#endif
    if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)  //接收中断(接收到的数据必须是0x0d 0x0a结尾)
        Res =USART_ReceiveData(USART1);    //读取接收到的数据
        if((USART_RX_STA&0x8000)==0)//接收未完成
            if(USART_RX_STA&0x4000)//接收到了0x0d
                if(Res!=0x0a)USART_RX_STA=0;//接收错误,重新开始
                else USART_RX_STA|=0x8000;    //接收完成了
            else //还没收到0X0D
                if(Res==0x0d)USART_RX_STA|=0x4000;
                else
                    USART_RX_BUF[USART_RX_STA&0X3FFF]=Res ;
                    USART_RX_STA++;
                    if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//接收数据错误,重新开始接收
rs485通信串口2的配置
#ifdef EN_USART2_RX       //如果使能了接收
//接收缓存区
u8 RS485_RX_BUF[64];      //接收缓冲,最大64个字节.
//接收到的数据长度
u8 RS485_RX_CNT=0;
void USART2_IRQHandler(void)
    u8 res;
     if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET) //接收到数据
        res =USART_ReceiveData(USART2);     //读取接收到的数据
        if(RS485_RX_CNT<64)
            RS485_RX_BUF[RS485_RX_CNT]=res;        //记录接收到的值
            RS485_RX_CNT++;                        //接收数据增加1
#endif
//初始化IO 串口2
//pclk1:PCLK1时钟频率(Mhz)
//bound:波特率
void RS485_Init(u32 bound)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD, ENABLE);//使能GPIOA,D时钟
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);//使能USART2时钟
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;                 //PD7端口配置
     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;          //推挽输出
     GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;    //PA2
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//PA3
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入
    RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2,ENABLE);//复位串口2
    RCC_APB1PeriphResetCmd(RCC_APB1Periph_USART2,DISABLE);//停止复位
    USART_InitStructure.USART_BaudRate = bound;//波特率设置
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//8位数据长度
    USART_InitStructure.USART_Parity = USART_Parity_No;///奇偶校验位
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//收发模式
  USART_Init(USART2, &USART_InitStructure); ; //初始化串口
    NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; //使能串口2中断
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3; //先占优先级2级
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //从优先级2级
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能外部中断通道
    NVIC_Init(&NVIC_InitStructure); //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
  USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//开启中断
  USART_Cmd(USART2, ENABLE);                    //使能串口
#endif
  RS485_TX_EN=0;            //默认为接收模式
//RS485发送len个字节.
//buf:发送区首地址
//len:发送的字节数(为了和本代码的接收匹配,这里建议不要超过64个字节)
void RS485_Send_Data(u8 *buf,u8 len)
    u8 t;
    RS485_TX_EN=1;            //设置为发送模式
      for(t=0;t
        while(USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET);
        USART_SendData(USART2,buf[t]);
    RS485_RX_CNT=0;
    RS485_TX_EN=0;                //设置为接收模式
//RS485查询接收到的数据
//buf:接收缓存首地址
//len:读到的数据长度
void RS485_Receive_Data(u8 *buf,u8 *len)
    u8 rxlen=RS485_RX_CNT;
    u8 i=0;
    *len=0;                //默认为0
    delay_ms(10);        //等待10ms,连续超过10ms没有接收到一个数据,则认为接收结束
    if(rxlen==RS485_RX_CNT&&rxlen)//接收到了数据,且接收完成了
        for(i=0;i
            buf=RS485_RX_BUF;
        *len=RS485_RX_CNT;    //记录本次数据长度
        RS485_RX_CNT=0;        //清零
由以上的两段代码可以清晰明了的学习STM32的chan串口的配置
