uint8_t UART4_Rx_buffer[512],UART4_Rx_num;
void UART4_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
// NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0); //选择NVIC优先级分组0
RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE);
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
//串口4所使用管脚输出输入定义
//定义UART4 Tx (PC.10)脚为复用推挽输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //IO口的第2脚
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //IO口复用推挽输出
GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化串口1输出IO口
//定义 UART4 Rx (PC.11)为悬空输入
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //IO口的第3脚
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//IO口悬空输入
GPIO_Init(GPIOC, &GPIO_InitStructure); //初始化串口1输入IO口
//串口4参数初始化定义部分,串口1参数为9600 , 8 ,1 ,N 接收中断方式
USART_InitStructure.USART_BaudRate = 9600; //设定传输速率
USART_InitStructure.USART_WordLength = USART_WordLength_8b; //设定传输数据位数
USART_InitStructure.USART_StopBits = USART_StopBits_1; //设定停止位个数
USART_InitStructure.USART_Parity = USART_Parity_No ; //不用校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//不用流量控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //使用接收和发送功能
USART_Init(UART4, &USART_InitStructure); //初始化串口4
USART_ITConfig(UART4, USART_IT_IDLE,ENABLE); //使能串口4接收中断
USART_Cmd(UART4, ENABLE); //使能串口4
USART_ClearFlag(UART4, USART_FLAG_TC); // 清标志(后增加)
DMA_DeInit(DMA2_Channel3); //重置DMA 2通道配置
DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40004C04; //外设地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)UART4_Rx_buffer; //内存地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //外设作为数据目的地
DMA_InitStructure.DMA_BufferSize = 512; //DMA缓存大小:BufferSize
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte; //外设数据宽度为8位
DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Byte; //内存数据宽度为8位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在正常缓存模式
DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh; //设置DMA通道优先级为高
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //禁止DMA通道设置为内存至内存传输
DMA_Init(DMA2_Channel3, &DMA_InitStructure); //初始化
DMA_ITConfig(DMA2_Channel3, DMA_IT_TC, ENABLE);
DMA_ITConfig(DMA2_Channel3, DMA_IT_TE, ENABLE);
USART_DMACmd(UART4, USART_DMAReq_Rx, ENABLE);
DMA_Cmd(DMA2_Channel3, ENABLE);
//使能串口4中断
NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Channel3_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
void UART4_IRQHandler(void)
uint16_t i;
uint16_t Data_Len;
if(USART_GetITStatus(UART4, USART_IT_IDLE) != RESET) //如果为中断
DMA_Cmd(DMA2_Channel3, DISABLE);
Data_Len=512-DMA_GetCurrDataCounter(DMA2_Channel3);
USART_PutStr(USART1,UART4_Rx_buffer,Data_Len);
UART4_Rx_num=0;
DMA_ClearFlag(DMA2_FLAG_GL3 | DMA2_FLAG_TC3 | DMA2_FLAG_TE3 | DMA2_FLAG_HT3); //清标志
DMA2_Channel3->CNDTR = 512; //重装填
DMA_Cmd(DMA2_Channel3, ENABLE); //处理完,重开DMA
//读SR后读DR清除IDLE
i = UART4->SR;
i = UART4->DR;
if(i) i=0;
if(Data_Len) Data_Len=0;
if(USART_GetITStatus(UART4, USART_IT_PE | USART_IT_FE | USART_IT_NE) != RESET)
{ //出错
USART_ClearITPendingBit(UART4, USART_IT_PE | USART_IT_FE | USART_IT_NE);
USART_ClearITPendingBit(UART4, USART_IT_TC);
USART_ClearITPendingBit(UART4, USART_IT_IDLE);
void DMA2_Channel3_IRQHandler(void)
USART_PutStr(USART1," DMA23:rn",9);
DMA_ClearITPendingBit(DMA2_IT_TC3);
DMA_ClearITPendingBit(DMA2_IT_TE3);
DMA_Cmd(DMA2_Channel3, DISABLE); //关闭DMA,防止处理其间有数据
//串口4所使用管脚输出输入定义
//使能串口4中断
uint16_t i;
uint16_t Data_Len;
UART4_Rx_num=0;
//读SR后读DR清除IDLE
i = UART4->SR;
i = UART4->DR;
if(i) i=0;
{ //出错
