STM32
h1654155275.5741
7年用户 1012经验值
如何对STM32F103 UART4的DMA接收进行调试呢
如何对STM32F103 UART4的DMA接收进行调试呢?
回帖(1)
卢鉴冰
2021-12-13 15:12:08
//网上找了老半天也找不到UART4-DMA的程序,自己调试成功了,特地分享一下
uint8_t UART4_Rx_buffer[512],UART4_Rx_num;
void UART4_Config(void)
        GPIO_InitTypeDef GPIO_InitStructure;
        USART_InitTypeDef USART_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        DMA_InitTypeDef DMA_InitStructure;         //定义DMA初始化结构体DMA_InitStructure
//        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);          //选择NVIC优先级分组0
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA2, ENABLE);
        //串口4所使用管脚输出输入定义
        //定义UART4 Tx (PC.10)脚为复用推挽输出
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;         //IO口的第2脚
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;   //IO口复用推挽输出
        GPIO_Init(GPIOC, &GPIO_InitStructure);            //初始化串口1输出IO口
        //定义 UART4 Rx (PC.11)为悬空输入
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;           //IO口的第3脚
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//IO口悬空输入
        GPIO_Init(GPIOC, &GPIO_InitStructure);               //初始化串口1输入IO口
        //串口4参数初始化定义部分,串口1参数为9600 , 8 ,1 ,N  接收中断方式
        USART_InitStructure.USART_BaudRate = 9600;                  //设定传输速率
        USART_InitStructure.USART_WordLength = USART_WordLength_8b; //设定传输数据位数
        USART_InitStructure.USART_StopBits = USART_StopBits_1;      //设定停止位个数
        USART_InitStructure.USART_Parity = USART_Parity_No ;        //不用校验位
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//不用流量控制
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;                //使用接收和发送功能
        USART_Init(UART4, &USART_InitStructure);      //初始化串口4
        USART_ITConfig(UART4, USART_IT_IDLE,ENABLE);  //使能串口4接收中断
        USART_Cmd(UART4, ENABLE);                     //使能串口4
        USART_ClearFlag(UART4, USART_FLAG_TC);        // 清标志(后增加)
        DMA_DeInit(DMA2_Channel3);         //重置DMA 2通道配置
        DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40004C04;         //外设地址
        DMA_InitStructure.DMA_MemoryBaseAddr = (u32)UART4_Rx_buffer;         //内存地址
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;         //外设作为数据目的地
        DMA_InitStructure.DMA_BufferSize = 512;         //DMA缓存大小:BufferSize
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;         //外设地址寄存器不递增
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;                   //内存地址寄存器递增
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;         //外设数据宽度为8位
        DMA_InitStructure.DMA_MemoryDataSize = DMA_PeripheralDataSize_Byte;         //内存数据宽度为8位
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;         //工作在正常缓存模式
        DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;         //设置DMA通道优先级为高
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;         //禁止DMA通道设置为内存至内存传输
        DMA_Init(DMA2_Channel3, &DMA_InitStructure);         //初始化
        DMA_ITConfig(DMA2_Channel3, DMA_IT_TC, ENABLE);
        DMA_ITConfig(DMA2_Channel3, DMA_IT_TE, ENABLE);
        USART_DMACmd(UART4, USART_DMAReq_Rx, ENABLE);
        DMA_Cmd(DMA2_Channel3, ENABLE);
        //使能串口4中断
        NVIC_InitStructure.NVIC_IRQChannel = UART4_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = DMA2_Channel3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
void UART4_IRQHandler(void)
        uint16_t i;
        uint16_t Data_Len;
        if(USART_GetITStatus(UART4, USART_IT_IDLE) != RESET)    //如果为中断
                DMA_Cmd(DMA2_Channel3, DISABLE);
                Data_Len=512-DMA_GetCurrDataCounter(DMA2_Channel3);
                USART_PutStr(USART1,UART4_Rx_buffer,Data_Len);
                UART4_Rx_num=0;
                DMA_ClearFlag(DMA2_FLAG_GL3 | DMA2_FLAG_TC3 | DMA2_FLAG_TE3 | DMA2_FLAG_HT3); //清标志
                DMA2_Channel3->CNDTR = 512;                //重装填
                DMA_Cmd(DMA2_Channel3, ENABLE);            //处理完,重开DMA
                //读SR后读DR清除IDLE
                i = UART4->SR;
                i = UART4->DR;
                if(i)                        i=0;
                if(Data_Len)        Data_Len=0;
        if(USART_GetITStatus(UART4, USART_IT_PE | USART_IT_FE | USART_IT_NE) != RESET){    //出错
                USART_ClearITPendingBit(UART4, USART_IT_PE | USART_IT_FE | USART_IT_NE);
        USART_ClearITPendingBit(UART4, USART_IT_TC);
        USART_ClearITPendingBit(UART4, USART_IT_IDLE);
void DMA2_Channel3_IRQHandler(void)
        USART_PutStr(USART1," DMA23:rn",9);
        DMA_ClearITPendingBit(DMA2_IT_TC3);
        DMA_ClearITPendingBit(DMA2_IT_TE3);
        DMA_Cmd(DMA2_Channel3, DISABLE);         //关闭DMA,防止处理其间有数据
        //串口4所使用管脚输出输入定义
        //使能串口4中断
        uint16_t i;
        uint16_t Data_Len;
                UART4_Rx_num=0;
                //读SR后读DR清除IDLE
                i = UART4->SR;
                i = UART4->DR;
                if(i)                        i=0;
相关问答
登录/注册
