元件管脚的缩写列表
名称 | 缩写 | 名称 | 缩写 | 名称 | 缩写 | |
Speaker | SPK | Thermal Shutdowm | TS | Virtual | VIRT | |
Spindle | SPN | Threshold | THR | Voltage | VOLT | |
Square | SQ | time Constant | TC | Voltage Regulator | VREG | |
Square Wave | SQW | Timing | TIM | Volume | VOL | |
Squelch | SQEL | Timing Capacitor | CT | |||
Stailized | STAB | Timing Ressistor | RT | Watch Dog | WDG | |
Stack | STK | Toggle | TG | Watch Dog Input | WDI | |
Stage | STG | Tolerance | TOL | Watch Dog Output | WDO | |
Standard | STD | Torqur | TRQ | Waveshape | WVSH | |
Standby | SBY | Transceiver | XCVR | Word | WD | |
Start | STA | Transient | TRAN | Word Select | WS | |
Status | STAT | Transmission | TRANS | Write | WR | |
Stereo | ST | Transmit | TX | Write Control | WC | |
Streaming | STR | Transmit Clock | TXC | Write Enable | WE | |
Stretch | STRCH | Transmit Data | TXD | |||
Strobe | STB | Transmit Sync | TSYNC | Zener | ZEN | |
Summing | SUB | Transmitter Enable | TEN | Zero Adjust | ZADJ | |
Summing Junction | SJ | Transparent | TRN | Zero Current | ZC | |
Supply | VS | Treble | TR | Zero Detect | ZD | |
Supply Voltage | VS | Triangle | TRI | |||
Sustaining | SUS | Trigger | TRIG | |||
Switch | SW | Triggering | TRIG | |||
Ssitched | SW | True Complement | R/C | |||
Switching | SW | Tuner | TUN | |||
Syllabic | SYL | Tunnig | TUN | |||
Synchro | SYNC | Twisted Pair | TWP | |||
Synchronization | SYNC | Typical | TYP | |||
Synchronize | SYNC | |||||
Synchronous | SYNC | ALTIUM根据许多制造商常用的 | ||||
Synchronous Prese-Enable | SPE | Undervoltage | UV | 缩写和<逻辑威廉希尔官方网站 图IEEE标准> | ||
Synthesizer | SYN | Up/Down | U/D | ANSI/IEEE Std991-1986, | ||
System | SYS | Upper Byte | U/B | 编制了 包含600多个名称的缩写语表 | ||
System Clock | SYSSCLK | Utility | UTIL | |||
Temperatrue | TEMP | |||||
Terminal | TERM | Valid | VLD | |||
Terminate | TERM | Varactor | VARAC | |||
Termination | TERM | Vari Cap | VCAP | |||
Terminations | TERM | Variable | VARAC | |||
Test | TST | Vboot | BOOT | |||
Test Point | TP | Vertical | VERT | |||
Thermal | THERM | Video | VID |
谢谢楼主
推荐一些常用资料查询网站:
www.datasheetic.com ic datasheet
www.datasheetic.cn datasheet查询网
www.pdfic.com IC pdf
www.pdfic.cn ic pdf资料查询网
www.17ic.com 电子元器件交易网
