前言
STM32下NRF24L01实现无线传输
一、原理图
1.STM32F103C8T6
2.NRF24L01
NRF24L01是 nordic 的无线通信芯片,它具有以下特点:
1) 2.4G 全球开放的 ISM 频段(2.400 - 2.4835GHz),免许可证使用;
2)最高工作速率 2Mbps,高校的 GFSK 调制,抗干扰能力强;
3) 125 个可选的频道,满足多点通信和调频通信的需要;
4)内置 CRC 检错和点对多点的通信地址控制;
5)低工作电压(1.9~3.6V),待机模式下状态为 26uA;掉电模式下为 900nA;
6)可设置自动应答,确保数据可靠传输;
7)工作于EnhancedShockBurst 具有Automatic packet handling,Auto packet transaction handling ,可以实现点对点或是 1 对 6 的无线通信,速度可以达到 2M(bps),具有可选的内置包应答机制,极大的降低丢包率。
8)通过 SPI 总线与单片机进行交互,最大通信速率为10Mbps;
二、Keil代码
1.SPI_NRF2401.C
#include "Struct.h"
宏定义
#define NRF_CE_GPIO GPIOC
#define NRF_CE_Pin GPIO_Pin_14
#define NRF_CSN_GPIO GPIOC
#define NRF_CSN_Pin GPIO_Pin_13
#define NRF_IRQ_GPIO GPIOC
#define NRF_IRQ_Pin GPIO_Pin_15
#define NRF_CE_H NRF_CE_GPIO ->BSRR = NRF_CE_Pin //CE高电平
#define NRF_CE_L NRF_CE_GPIO ->BRR = NRF_CE_Pin //CE低电平
#define NRF_CSN_H NRF_CSN_GPIO->BSRR = NRF_CSN_Pin //CSN高电平
#define NRF_CSN_L NRF_CSN_GPIO->BRR = NRF_CSN_Pin //CSN高电平
#define NRF_IRQ_Read NRF_IRQ_GPIO->IDR & NRF_IRQ_Pin //IRQ读数据
变量定义
uint8_t NRF24L01_RXDATA[32];//nrf24l01接收到的数据
uint8_t NRF24L01_TXDATA[32];//nrf24l01需要发送的数据
static uint8_t TX_ADDRESS[5]= {0x1A,0x2A,0x3A,0x4A,0x5A};//本地地址
static uint8_t RX_ADDRESS[5]= {0x1A,0x2A,0x3A,0x4A,0x5A};//接收地址
static uint16_t Nrf_Erro=0;
函数原型: void SPI2_Init(void)
功 能: 初始化SPI总线
SPI_InitTypeDef SPI_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
EXTI_InitTypeDef EXTI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
//配置SCK,MISO,MOSI引脚
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用功能
GPIO_Init(GPIOB, &GPIO_InitStructure);
//配置CE引脚
GPIO_InitStructure.GPIO_Pin = NRF_CE_Pin;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_Init(NRF_CE_GPIO, &GPIO_InitStructure);
//配置CSN引脚
GPIO_InitStructure.GPIO_Pin = NRF_CSN_Pin;
GPIO_Init(NRF_CSN_GPIO, &GPIO_InitStructure);
//配置IRQ引脚
GPIO_InitStructure.GPIO_Pin = NRF_IRQ_Pin;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入
GPIO_Init(NRF_IRQ_GPIO, &GPIO_InitStructure);
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC,GPIO_PinSource15);
EXTI_InitStructure.EXTI_Line=EXTI_Line15;
EXTI_InitStructure.EXTI_Mode=EXTI_Mode_Interrupt;//外部中断
EXTI_InitStructure.EXTI_Trigger=EXTI_Trigger_Falling;//下降沿触发
EXTI_InitStructure.EXTI_LineCmd=ENABLE;
EXTI_Init(&EXTI_InitStructure);
NRF_CSN_H; //禁止NRF器件
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //双线全双工
SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //主模式
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //数据大小8位
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //时钟极性,空闲时为低
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //第1个边沿有效,上升沿为采样时刻
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由软件产生
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_8; //8分频,9MHz
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //高位在前
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &SPI_InitStructure);
SPI_Cmd(SPI2, ENABLE);//使能 SPI1
// PrintString("rn SPI2 初始化完成!");
函数原型: uint8_t SPI_RW(uint8_t data)
功 能: SPI总线读写
返 回 值: 返回SPI总线读取数据
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);//当SPI发送缓冲器非空时等待
SPI_I2S_SendData(SPI2, data);//通过SPI总线发送一字节数据
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);//当SPI接收缓冲器为空时等待
return SPI_I2S_ReceiveData(SPI2);
函数原型: uint8_t NRF_Write_Reg(uint8_t reg, uint8_t value)
功 能: NRF写寄存器
返 回 值: NRF写寄存器返回值
uint8_t status;
NRF_CSN_L; //选通NRF器件
status = SPI_RW(reg);//写寄存器地址
SPI_RW(value); //写数据
return status;
函数原型: uint8_t NRF_Read_Reg(uint8_t reg)
功 能: NRF读寄存器
返 回 值: 寄存器数据
uint8_t reg_val;
SPI_RW(reg); //写寄存器地址
reg_val = SPI_RW(0);//读取该寄存器返回数据
return reg_val;
函数原型: uint8_t NRF_Write_Buf(uint8_t reg, uint8_t *pBuf, uint8_t uchars)
功 能: NRF写缓冲区
返 回 值: NRF写缓冲区返回值
uint8_t i;
uint8_t status;
for(i=0; i
SPI_RW(pBuf
);//写数据
return status;
函数原型: uint8_t NRF_Read_Buff(uint8_t reg, uint8_t *pBuf, uint8_t uchars)
功 能: NRF读缓冲区
返 回 值: 缓冲区数据
uint8_t i;
uint8_t status;
for(i=0; i
pBuf = SPI_RW(0);//读取返回数据
return status;
函数原型: void NRF24L01_Check(void)
功 能: 检查NRF器件是否正常
uint8_t buf[5];
uint8_t i;
//写入5个字节的地址
NRF_Write_Buf(NRF_WRITE_REG+TX_ADDR,TX_ADDRESS,5);
//读出写入的地址
NRF_Read_Buff(TX_ADDR,buf,5);
//比较
for(i=0;i<5;i++)
if(buf!=TX_ADDRESS)
break;
// if(i==5)
// PrintString("rn NRF24L01 初始化成功!");
// else
// PrintString("rn NRF24L01 初始化失败!");
函数原型: static void NRF24L01_Set_TX(void)
功 能: 将NRF24L01设置为发送模式
NRF_CE_L;
NRF_Write_Reg(NRF_WRITE_REG + CONFIG,0x0E);//发送
NRF_CE_H;
函数原型: static void NRF24L01_Set_RX(void)
功 能: 将NRF24L01设置为接收模式
NRF_CE_L;
NRF_Write_Reg(NRF_WRITE_REG + CONFIG,0x0F);//接收
NRF_CE_H;
函数原型: void NRF_Send_TX(uint8_t * tx_buf, uint8_t len)
功 能: NRF2401发送数据包
NRF24L01_Set_TX();
NRF_CE_L;//进入待机模式1
NRF_Write_Buf(WR_TX_PLOAD, tx_buf, len);//装载数据
NRF_CE_H;//设置CE为高,启动发射。CE高电平持续时间最小为10us
函数原型: void NRF24L01_Init(uint8_t Chanal,uint8_t Mode)
功 能: NRF24L01初始化
参 数: Chanal,RF通道
NRF_CE_L;
NRF_Write_Reg(FLUSH_TX,0xff);//清空发送缓冲区
NRF_Write_Reg(FLUSH_RX,0xff);//清空接收缓冲区
NRF_Write_Buf(NRF_WRITE_REG + TX_ADDR, TX_ADDRESS,5); //写TX节点地址
NRF_Write_Buf(NRF_WRITE_REG + RX_ADDR_P0,RX_ADDRESS,5); //写RX节点地址
NRF_Write_Reg(NRF_WRITE_REG + EN_AA, 0x01); //使能通道0的自动应答
NRF_Write_Reg(NRF_WRITE_REG + EN_RXADDR, 0x01); //使能通道0的接收地址
NRF_Write_Reg(NRF_WRITE_REG + SETUP_RETR,0x1a); //设置自动重发间隔时间:500us;最大自动重发次数:10次
NRF_Write_Reg(NRF_WRITE_REG + RF_CH, Chanal); //设置RF通道为CHANAL
NRF_Write_Reg(NRF_WRITE_REG + RX_PW_P0, 32); //设置通道0的有效数据宽度
NRF_Write_Reg(NRF_WRITE_REG + RF_SETUP, 0x0f); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启
if(Mode==TX)
else if(Mode==RX)
NRF_CE_H;
前言
一、原理图
1.STM32F103C8T6
2.NRF24L01
6)可设置自动应答,确保数据可靠传输;
二、Keil代码
1.SPI_NRF2401.C
#include "Struct.h"
宏定义
变量定义
功 能: 初始化SPI总线
//配置SCK,MISO,MOSI引脚
//配置CE引脚
//配置CSN引脚
//配置IRQ引脚
功 能: SPI总线读写
返 回 值: 返回SPI总线读取数据
功 能: NRF写寄存器
返 回 值: NRF写寄存器返回值
uint8_t status;
return status;
功 能: NRF读寄存器
返 回 值: 寄存器数据
uint8_t reg_val;
return reg_val;
功 能: NRF写缓冲区
返 回 值: NRF写缓冲区返回值
uint8_t i;
uint8_t status;
for(i=0; i
SPI_RW(pBuf
);//写数据
return status;
功 能: NRF读缓冲区
返 回 值: 缓冲区数据
uint8_t i;
uint8_t status;
for(i=0; i
return status;
功 能: 检查NRF器件是否正常
uint8_t buf[5];
uint8_t i;
//写入5个字节的地址
//读出写入的地址
//比较
for(i=0;i<5;i++)
if(buf!=TX_ADDRESS)
break;
// if(i==5)
// else
NRF_CE_L;
NRF_CE_H;
NRF_CE_L;
NRF_CE_H;
功 能: NRF2401发送数据包
NRF24L01_Set_TX();
NRF_CE_L;//进入待机模式1
功 能: NRF24L01初始化
参 数: Chanal,RF通道
NRF_CE_L;
if(Mode==TX)
else if(Mode==RX)
NRF_CE_H;
