酷酷的24l01的相关资料了,已经有点模糊了,今天下午感觉有点了解,在板上调试成功了,但是还没有进行通讯测试。stm32和arduino进行通信没有成功,:(
先把stm32的NRF24L01配置的过程说一下吧(这是我跟着代码写的,有点简单,可能还有差错):
1.首先初始化相关的端口和SPI等
void SPI2_NRF24L01_init(void)
SPI_InitTypeDef SPI_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
/* Enable SPI2 GPIOB clocks */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2 ,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE);
/* Configure SPI2 pins: SCK, MISO and MOSI */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;//GPIO_Mode_Out_PP; //
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOC,&GPIO_InitStructure);
/* Configure PB.11 as Output push-pull, used as Flash Chip select */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //NRF24L01 MODE-CE
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* Deselect the FLASH: Chip Select high */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //NRF24L01 IRQ
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
GPIO_SetBits(GPIOB, GPIO_Pin_8); //On
NotSelect_SDR();
/* SPI2 configuration */
SPI_Cmd(SPI2,DISABLE);
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI2,&SPI_InitStructure);
/* Enable SPI2 */
SPI_Cmd(SPI2,ENABLE);
2. 这是我的个人连接
然后开始初始化 NRF 模块
01 . spi的读、写数据方法:
u8 Spi_RW(u8 dat)
2 {
3 /* 当 SPI发送缓冲器非空时等待 */
4 while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
5 /* 通过 SPI2发送一字节数据 */
6 SPI_I2S_SendData(SPI2, dat);
7 /* 当SPI接收缓冲器为空时等待 */
8 while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET);
9 /* Return the byte read from the SPI bus */
10 return SPI_I2S_ReceiveData(SPI2);
11 }
模块的读、写方法:
1 uint8_t NRF_Read_Reg(uint8_t reg)
2 {
3 uint8_t reg_val;
4 SPI_CSN_L(); /* 选通器件 */
5 Spi_RW(reg); /* 写寄存器地址 */
6 reg_val = Spi_RW(0); /* 读取该寄存器返回数据 #define NRF_READ_REG 0x00 // 读寄存器指令 */
7 SPI_CSN_H(); /* 禁止该器件 */
8 return reg_val;
9 }
10
11 uint8_t NRF_Write_Reg(uint8_t reg, uint8_t value)
12 {
13 uint8_t status;
14 SPI_CSN_L(); /* 先选通器件 */
15 status = Spi_RW(reg); /* 写寄存器地址,同时也可以读出该寄存器 */
16 Spi_RW(value); /* 然后就向该地址的寄存器写数据 */
17 SPI_CSN_H(); /* 最后禁止该器件 */
18 return status;
19 }
02 . 然后就是按照模块的指令说明来向相应的指令里写入数据来设置:
1 NRF_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,RX_ADDRESS,RX_ADR_WIDTH); //写RX节点地址
2 NRF_Write_Buf(NRF_WRITE_REG+TX_ADDR,TX_ADDRESS,TX_ADR_WIDTH); //写TX节点地址
3 NRF_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答
4 NRF_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
5 NRF_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x1a); //设置自动重发间隔时间:500us;最大自动重发次数:10次
6 NRF_Write_Reg(NRF_WRITE_REG+RF_CH,40); //设置RF通道为CHANAL
7 NRF_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启
这些数据定义的地址NRF24L01.h内部中宏:
1 //***************************************NRF24L01寄存器指令*******************************************************
2 #define NRF_READ_REG 0x00 // 读寄存器指令
3 #define NRF_WRITE_REG 0x20 // 写寄存器指令
4 #define R_RX_PL_WID 0x60
5 #define RD_RX_PLOAD 0x61 // 读取接收数据指令
6 #define WR_TX_PLOAD 0xA0 // 写待发数据指令
7 #define FLUSH_TX 0xE1 // 冲洗发送 FIFO指令
8 #define FLUSH_RX 0xE2 // 冲洗接收 FIFO指令
9 #define REUSE_TX_PL 0xE3 // 定义重复装载数据指令
10 #define NOP 0xFF // 保留
11 //*************************************SPI(nRF24L01)寄存器地址****************************************************
12 #define CONFIG 0x00 // 配置收发状态,CRC校验模式以及收发状态响应方式
13 #define EN_AA 0x01 // 自动应答功能设置
14 #define EN_RXADDR 0x02 // 可用信道设置
15 #define SETUP_AW 0x03 // 收发地址宽度设置
16 #define SETUP_RETR 0x04 // 自动重发功能设置
17 #define RF_CH 0x05 // 工作频率设置
18 #define RF_SETUP 0x06 // 发射速率、功耗功能设置
19 #define NRFRegSTATUS 0x07 // 状态寄存器
20 #define OBSERVE_TX 0x08 // 发送监测功能
21 #define CD 0x09 // 地址检测
22 #define RX_ADDR_P0 0x0A // 频道0接收数据地址
23 #define RX_ADDR_P1 0x0B // 频道1接收数据地址
24 #define RX_ADDR_P2 0x0C // 频道2接收数据地址
25 #define RX_ADDR_P3 0x0D // 频道3接收数据地址
26 #define RX_ADDR_P4 0x0E // 频道4接收数据地址
27 #define RX_ADDR_P5 0x0F // 频道5接收数据地址
28 #define TX_ADDR 0x10 // 发送地址寄存器
29 #define RX_PW_P0 0x11 // 接收频道0接收数据长度
30 #define RX_PW_P1 0x12 // 接收频道1接收数据长度
31 #define RX_PW_P2 0x13 // 接收频道2接收数据长度
32 #define RX_PW_P3 0x14 // 接收频道3接收数据长度
33 #define RX_PW_P4 0x15 // 接收频道4接收数据长度
34 #define RX_PW_P5 0x16 // 接收频道5接收数据长度
35 #define FIFO_STATUS 0x17 // FIFO栈入栈出状态寄存器设置
36 //**************************************************************************************
37 //*********************************************NRF24L01*************************************
38 #define RX_DR 6 //中断标志
39 #define TX_DS 5
40 #define MAX_RT 4
41
42 #define MODEL_RX 1 //普通接收
43 #define MODEL_TX 2 //普通发送
44 #define MODEL_RX2 3 //接收模式2,用于双向传输
45 #define MODEL_TX2 4 //发送模式2,用于双向传输
46
47 #define RX_PLOAD_WIDTH 32
48 #define TX_PLOAD_WIDTH 32
49 #define TX_ADR_WIDTH 5
50 #define RX_ADR_WIDTH 5
03 . 基本都设置好了,另外设置一下发送模式
1 NRF_Write_Reg(NRF_WRITE_REG + CONFIG, 0x0e); // IRQ收发完成中断开启,16位CRC,主发送
2 NRF_Write_Reg(FLUSH_TX,0xff);
3 NRF_Write_Reg(FLUSH_RX,0xff);
4
5 Spi_RW(0x50);
6 Spi_RW(0x73);
7 NRF_Write_Reg(NRF_WRITE_REG+0x1c,0x01);
8 NRF_Write_Reg(NRF_WRITE_REG+0x1d,0x07);
04 . 最后检查一下模块和STM32是否连接成功:
1 u8 Nrf24l01_Check(void)
2 {
3 u8 buf1[5];
4 u8 i;
5 /*写入5个字节的地址. */
6 NRF_Write_Buf(NRF_WRITE_REG+TX_ADDR,TX_ADDRESS,5);
7 /*读出写入的地址 */
8 NRF_Read_Buf(TX_ADDR,buf1,5);
9 /*比较*/
10 for(i=0;i<5;i++)
11 {
12 if(buf1
!=TX_ADDRESS)
13 break;
14 }
15 if(i==5)
16 return SUCCESS ; //MCU与NRF成功连接
17 else
18 return ERROR ; //MCU与NRF不正常连接
19 }
3 . NRF24L01 发送数据方式:
先拉低CE,然后将数据写入TX_FIFO,拉高CE,10us以上,数据会无线发送出去。
1.首先初始化相关的端口和SPI等
NotSelect_SDR();
/* Enable SPI2 */
2. 这是我的个人连接
然后开始初始化 NRF 模块
01 . spi的读、写数据方法:
u8 Spi_RW(u8 dat)
2 {
11 }
模块的读、写方法:
2 {
3 uint8_t reg_val;
8 return reg_val;
9 }
10
12 {
13 uint8_t status;
18 return status;
19 }
39 #define TX_DS 5
40 #define MAX_RT 4
41
46
4
5 Spi_RW(0x50);
6 Spi_RW(0x73);
2 {
3 u8 buf1[5];
4 u8 i;
5 /*写入5个字节的地址. */
7 /*读出写入的地址 */
9 /*比较*/
10 for(i=0;i<5;i++)
11 {
12 if(buf1
!=TX_ADDRESS)
13 break;
14 }
15 if(i==5)
17 else
19 }
