目录
STM32F4
Libraries and projects
Here are listed all libraries for STM32F4 devices.Libraries are designed to work with STM32F4xx series of MCU. Every project hereis created with Keil uVision, but tested with GCC compiler too (Coocox). Eachproject includes 4 targets:
STM32F429-Discovery board (STM32F429ZI, 180MHz)
STM32F4-Discovery board (STM32F407VG, 168MHz)
STM32F401-Discovery (STM32F401, 84MHz)
STM32F411C-Discovery (STM32F411, 100MHz)
Nucleo F411-RE (STM32F411RE, 100MHz)
Nucleo F401-RE (STM32F401RE, 84MHz)
STM32F446xx (180MHz)
STM32439-Eval (STM32F439NI, 180MHz)
When you download repository and open project, you haveto set correct your target, for device you use. If you use other device in yourproject, then set your project and copy settings there from target options.
More information below http://stm32f4-discovery.com
First time with Discovery board? http://stm32f4-discovery.com
Current librarires:
All libraries listed at one place for easy editing them from one place and use them for all projects
Two default projects are included
Default Keil project, with CMSIS files v.1.5.0 included
Default Keil project, with CMSIS files v.1.5.0 included and clock for STM32F429-Discovery/STM32F446 slowed down to 168MHz and for Nucleo F411 down to 96MHz for USB communication
LED_BUTTON - Project example for STM32F4/29 Discovery
DELAY - Delay library for STM32F4/29
USART - USART library for STM32F4/29
SPI - SPI library for STM32F4/29
ADC - ADC library for STM32F4/29
DAC - DAC library for STM32F4/29
ILI9341 LCD - STM32F429 Discovery ILI9341 LCD library
I2C - I2C library for STM32F4/29
STMPE811 touch driver for STM32F4/29 Discovery board
ILI9341 Button - Button library for ILI9341 LCD and STMPE811 Touch driver on STM32F429
ONEWIRE - OneWire library for STM32F4/29
DS18B20 - DS18B20 OneWire temperature sensor library for STM32F4/29
SDRAM - ISSI 8MByte SDRAM on STM32F429 Discovery board
DS1307 - DS1307 RTC modeule for STM32F429 Discovery
HD44780 - HD44780 Alpha numeric LCD driver for STM32F429 discovery
NRF24L01+ - NRF24L01+ 2.4 GHz transceiver library
ILI8341 LTDC - ILI9341 LCD with LTDC hardware only for STM32F429
Internal RTC - Library for internal RTC on STM32F4xx devices
Independent watchdog - Library for watchdog on STM32F4xx devices
FATFS - Read SDcard with STM32F4xx using SDIO or SPI communication
RNG - Use of True random number generator peripheral on STM32F4xx devices
MFRC522 - Read RFID Cards with STM32F4xx devices
USB VCP - Use STM32F4xx as USB VCP device (Virtual COM Port)
AM2301 - AM2301 (DHT21) temperature and humidity sensor
ROTARY ENCODER - Connect Rotary Encoder to STM32F4xx device
GPS - Read GPS data on STM32F4xx devices
L3GD20 - Measure rotation of all 3 axis with L3GD20 gyro sensor
USB MSC HOST - Read USB flash drive with STM32F4xx
HC-SR04 - Measure distance with ultrasonic sensor on STM32F4xx
USB HID HOST - Read USB mouse and keyboard on STM32F4xx
4x4 KEYPAD - Read matrix keypad up to 4x4 with STM32F4xx
PWM - Use PWM on all possible timers for STM32F4xx device
USB HID Device - Turn STM32F4 into USB HID Device
LIS302DL/LIS3DSH - Accelerometers on STM32F4-Discovery board. Also can be used with any STM32F4 device
DAC SIGNAL - Output predefined signals with STM32F4 using DAC, DMA and TIM
BMP180 - Read atmosferic pressure on STM32F4 device
EXTI - Use external interrupts with STM32F4
LOW POWER - Power consumption modes for STM32F4
MCO OUTPUT - Output different clocks from STM32F4
STDIO - Use printf and fprintf/vfprintf on STM32F4
SERVO - Control RC servo with STM32F4
MPU-6050 - Read accelerometer and gyroscope data with STM32F4
Identification - Read identification bytes and 96-bits long UNIQUE ID from STM32F4
BKPSRAM - Interface backup SRAM on STM32F4
SWO DEBUG - Debug STM32F4 using SWO output
CRC - STM32F4 CRC Hardware module
PWM IN - Measure input PWM signal on STM32F4
OTP - One-time programmable memory on STM32F4
STemWin - STemWin implementation for STM32F429-Discovery
DMA2D GRAPHIC- Chrom-ART Accelerator on STM32F429-Discovery board
ETHERNET - Connect ethernet to STM32F4xx
GPIO - GPIO pins on STM32F4
GENERAL - General library for STM32F4
USART DMA - Extend USART with DMA TX functionality
SPI DMA - Extend SPI with DMA functionality
BUTTON - Use buttons with STM32F4xx
STRING - Dynamic string allocation for STM32F4xx
RCC - Dynamic PLL settings for STM32F4xx
CPU LOAD - CPU load monitoring for STM32F4xx
SSD1306 - Use OLED LCD with STM32F4
FFT - FFT Library for STM32F4xx devices
DMA - DMA library for STM32F4xx
PCD8544 LCD (Nokia 5110/3310) - Library for LCD
来看看真正的东西吧~~~激动
随意show两个代码:
(IIC)
(GPIO)
老外写的很是完善,英文的注释就连小编这种英语渣渣都能简单易懂,能直接用,不用怎么配置了,当然可以改装成为我们自己习惯的库。
虽然st的库很完善,但是以后我们写代码都可以有自己的库,拿来即用,很是方便。
目录
STM32F4
Current librarires:
来看看真正的东西吧~~~激动
随意show两个代码:
(IIC)
(GPIO)
