MARS-STM32遥控器元件清单 | |||||||||
Comment | Description | _Value | _Degree | Designator | Footprint | Pins | Quantity | LibRef | Message |
CAPN | 瓷片电容 | 0.1uF | >10V | C2, C4, C6, C7, C8, C10, C12, C13, C14, C15, C16, C17, C19, C20, C21 | FY-0603_C | 2 | 15 | CAPN | |
CAPN | 瓷片电容 | 12pF | >10V | C9, C11 | FY-0603_C | 2 | 2 | CAPN | |
CAPN | 瓷片电容 | 2.2nF | >10V | C5 | FY-0603_C | 2 | 1 | CAPN | |
Inductor | 电感 | 10uH | L1 | FY-0603_L | 2 | 1 | Inductor | 电感可以用0-10R电阻替代 | |
LED_R | LED_R | D2 | FY-0603_LED_R | 2 | 1 | LED_R | |||
RES | 电阻 | 1.5K | 5% | R8, R9 | FY-0603_R | 2 | 2 | RES | |
RES | 电阻 | 100K | 1% | R24, R25 | FY-0603_R | 2 | 2 | RES | |
RES | 电阻 | 100R | 5% | R3 | FY-0603_R | 2 | 1 | RES | |
RES | 电阻 | 10K | 1% | R4, R5, R10, R11, R12, R13 | FY-0603_R | 2 | 6 | RES | |
RES | 电阻 | 10K | 5% | R6, R15, R18, R19, R21 | FY-0603_R | 2 | 5 | RES | |
RES | 电阻 | 10R | 1% | R32, R33 | FY-0603_R | 2 | 2 | RES | |
RES | 电阻 | 1K | 5% | R7 | FY-0603_R | 2 | 1 | RES | |
RES | 电阻 | 1M | 5% | R20 | FY-0603_R | 2 | 1 | RES | |
RES | 电阻 | 22K | 1% | R22, R23 | FY-0603_R | 2 | 2 | RES | |
RES | 电阻 | 22R | 5% | R14, R16 | FY-0603_R | 2 | 2 | RES | |
RES | 电阻 | 24K | 1% | R28, R29 | FY-0603_R | 2 | 2 | RES | |
RES | 电阻 | 4.7K | 5% | R1, R2, R17 | FY-0603_R | 2 | 3 | RES | |
RES | 电阻 | 51K | 1% | R26, R27 | FY-0603_R | 2 | 2 | RES | |
RES | 电阻 | 9.1K | 1% | R30, R31 | FY-0603_R | 2 | 2 | RES | |
CAPN | 瓷片电容 | 10uF | >10V | C18 | FY-0805_C | 2 | 1 | CAPN | |
CAPN | 瓷片电容 | 47uF | >10V | C1, C3 | FY-1206_C | 2 | 2 | CAPN | 使用10UF 0805电容可以替代 |
BELL | 蜂鸣器 | 3V | 9mm | LS1 | FY-BELL_9MM | 2 | 1 | BELL | |
CR1220 | 电子座 | 3V | CR1220 | BT1 | FY-CR1220 | 2 | 1 | CR1220 | |
1N4148 | 二极管 | D4, D5 | FY-D_MELF_1206 | 2 | 2 | DIODE | |||
H4X1 | H4X1 | P4 | FY-H1.25-1X4A | 4 | 1 | H4X1 | |||
H4X1 | H4X1 | P3, P5 | FY-H1.25-1X4W | 4 | 2 | H4X1 | |||
JOYSTICK | 摇杆 | R34, R35 | FY-JOYSTICK | 6 | 2 | JOYSTICK | |||
KEY6-5-10*10 | KEY6-5-10*10 | KEY1, KEY2 | FY-KEY5-SMD-10*10*9 | 6 | 2 | KEY6-5-10*10 | |||
LED_RGB[5050]-4 | LED | D3 | FY-LED_RGB[5050]-4 | 4 | 1 | LED_RGB[5050]-4 | |||
STM32F103C8T6 | 单片机 | U5 | FY-LQFP-48 | 48 | 1 | STM32F103C8T6 | |||
NRF24L01_MODULE | 射频模块 | U7 | FY-NRF24L01_MODULE1 | 8 | 1 | NRF24L01_MODULE | |||
OLED_MODULE | OLED_IIC模块 | P2 | FY-OLED_IIC | 4 | 1 | OLED_IIC | |||
PH2X1 | PH2X1 | PH1 | FY-PH2.0_2AW | 2 | 1 | PH2X1 | |||
POT | 电位器 | 10K | 20% | RP1, RP2 | FY-POT-BKP2 | 3 | 2 | POT | |
MPU6050 | 陀螺仪芯片 | U3 | FY-QFN24 4*4 | 24 | 1 | MPU6050 | |||
SS14 | 二极管 | D1 | FY-SMA | 2 | 1 | DIODE | 使用0-10R电阻可以替代 | ||
W25X16 | 存储芯片 | U6 | FY-SO-8W_5*5 | 8 | 1 | W25Q16BV | |||
HT7133 | 电源芯片 | U1 | FY-SOT89M | 3 | 1 | HT7133 | 电源芯片二选一,优先选择662K | ||
ME6206A33M3G | 电源芯片 | U2 | FY-SOT-23-3 | 3 | 1 | ME6206A33M3G | |||
SS8050 | 三极管 | 1.5A | Q1 | FY-SOT-23-3 | 3 | 1 | SS8050 | ||
LTC4054 | 充电芯片 | U4 | FY-SOT-23-5 | 5 | 1 | LTC4054 | |||
SW_2 | SW_2 | S1, S3 | FY-SW-SMD6 | 6 | 2 | SW_2 | |||
SW3-8 | SW3-8 | S2 | FY-SW-SMD8 | 8 | 1 | SW3-8 | |||
USB_MICRO | USB_MICRO | P1 | FY-USB_MIC_V2 | 5 | 1 | USB_MICRO | |||
XTAL | 晶振体 | 8M | 20ppm | Y1 | FY-XTAL_CT3P | 2 | 1 | XTAL | |
XTAL | 晶振体 | 32.768K | Y2 | FY-XTAL_YZ2*6 | 2 | 1 | XTAL |
