// Motor instance
BLDCMotor motor = BLDCMotor(9, 5, 6, 11, 8);
void setup() {
sensor.sda_pin = 14; // change i2c data pin - OPTIONAL
sensor.scl_pin = 15; // change i2c clock pin - OPTIONAL
// initialise magnetic sensor hardware
sensor.init();
// link the motor to the sensor
motor.linkSensor(&sensor);
// initialize motor
motor.init();
// align encoder and start FOC
motor.initFOC();
// set the initial target value
motor.target = 2;
_delay(1000);
void loop() {
// iterative setting FOC phase voltage
motor.loopFOC();
// iterative function setting the outer loop target
// velocity, position or voltage
// if target not set in parameter uses motor.target variable
motor.move();
// Motor instance
void setup() {
sensor.init();
// initialize motor
motor.init();
motor.initFOC();
motor.target = 2;
_delay(1000);
void loop() {
motor.loopFOC();
motor.move();
