登录
吴凡
10年用户
948经验值
擅长:48674
私信
关注
请问OKA40i-C qt-everywhere-opensource-src-5.9.0怎么配置?
开启该帖子的消息推送
MQTT
我是自己搭建的环境,自己编译的官方提供代码,可以正常开机,有开机logo没有UI,按照官方提供的文档使用新的sysroot.tar.gz文件,从新编译qt,但是官方提供的代码QT是configure过了,prefix路径都指定了。我编译很多error。
/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/qtbase/bin/qmake -o Makefile qt.pro -- -opensource -confirm-license -extprefix /root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/Qt-5.9.0 -R /usr/lib -no-strip -c++std c++11 -shared -nomake examples -accessibility -no-sql-db2 -no-sql-ibase -no-sql-mysql -no-sql-oci -no-sql-odbc -no-sql-psql -no-sql-sqlite2 -no-sql-tds -no-sql-sqlite -plugin-sql-sqlite -no-qml-debug -no-sse2 -no-sse3 -no-ssse3 -no-sse4.1 -no-sse4.2 -no-avx -no-avx2 -no-mips_dsp -no-mips_dspr2 -qt-zlib -no-journald -qt-libpng -qt-libjpeg -qt-freetype -qt-harfbuzz -no-openssl -no-xinput2 -no-xcb-xlib -no-glib -no-pulseaudio -alsa -gui -widgets -v -op
ti
mized-qmake -no-cups -no-iconv -evdev -no-icu -no-fontconfig -no-strip -pch -dbus -no-use-gold-linker -xplatform linux-arm-gnueabi-g++ -no-directfb -eglfs -qpa eglfs -linuxfb -no-kms -sysroot /root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/../../..//out/sun8iw11p1/linux/common/buildroot/host/usr/arm-buildroot-linux-gnueabihf/sysroot -opengl es2 -no-system-proxies -no-slog2 -no-pps -no-imf -no-lgmon -tslib -device-option CROSS_COMPILE=/root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/../../..//out/sun8iw11p1/linux/common/buildroot/host/opt/ext-toolchain/bin//arm-linux-gnueabihf-
make: execvp: /root/workspace/allwinner/A40i/bsp/lichee/buildroot-201611/dl/qt-everywhere-opensource-src-5.9.0/qtbase/bin/qmake: Permission denied
Makefile:1427: recipe for target 'Makefile' failed
make: *** [Makefile] Error 127
我知道肯定"./configure --prefix"等相关的错误,不知道怎么配置啊?等官方给个恢复啊……
高倩
2022-1-5 10:05:40
A40i编译虚拟键盘时,为啥老提示opengl..h 未定义,可是opengl库已编译了啊
王竹
2022-1-5 10:05:44
可能是程序有问题,再排查一下吧
可能是程序有问题,再排查一下吧
尚文清
2022-1-5 10:05:51
我之前修改了qt.conf文件里面的[path]目录就不会报路径问题了
rotate(-90deg);
回复
相关问答
MQTT
请问
解压后没有
Qt-5.9.0
文件夹怎么办?
2022-01-05
714
如何解决
QT
编译问题?
2022-01-04
3577
Qt
编译并未生成库是为什么?
2022-01-05
927
按手册操作,
QT
目录没有正确生成是为什么?
2022-01-04
857
按手册操作
QT
目录没有正确生成是为什么?
2022-01-13
854
OKA40i-C
QT
程序运行后最大化了且标题栏被隐藏是为什么?
2022-01-13
630
oka40i
的
qt
程序无法继续
配置
该怎么办呢
2022-01-04
1972
请问
OKA40i-C
开发板SPI NorFlash和IIC 24
C
02存储器怎么使用呢?
2022-01-13
547
OKA40i-C
开发板有没有安装NFS服务呢
2022-01-05
841
【Rico Board试用体验】之编译并移植
qt
问题
2016-12-28
10834
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
英国威廉希尔公司网站
william hill官网 版块
小组
免费开发板试用
ebook
直播
搜索
登录
