stm32f401 EXTI
EXTI就是External interrupt/event controller, 外部事件和中断控制器, 包含21条边沿检测线. 每条线可以独立设置触发事件(上升沿, 下降沿或两者同时). 一个等待寄存器维护中断请求的状态.
当动作发生(例如按键按下)时, 如果电平状态由低变高, 会在输入线产生一个上升沿信号, 这个信号到达边沿检测威廉希尔官方网站
后, 会被上升沿触发选择寄存器(EXTI_RTSR)检测并触发, 输出有效信号, 否则输出无效信号0. 反之如果电平由高变低, 则会被下降沿触发选择寄存器(EXTI_FTSR)检测触发.
EXTI可以在外部连线上检测到比内部APB2时钟周期更短的脉冲. stm32f4系列最多有81个GPIO可以连接到16个外部中断线. IO口和中断线的映射是多对一的, 例如EXTI0, 可以对应PA0, PB0, PC0等, 实际用到某个I/O引脚时, 通过配置决定具体哪个引脚对应EXTI0.
在stm32f4xx_exti.h中定义了0 - 23的中断线
#define EXTI_Line0 ((uint32_t)0x00001) /*!< External interrupt line 0 */
#define EXTI_Line1 ((uint32_t)0x00002) /*!< External interrupt line 1 */
#define EXTI_Line2 ((uint32_t)0x00004) /*!< External interrupt line 2 */
#define EXTI_Line3 ((uint32_t)0x00008) /*!< External interrupt line 3 */
#define EXTI_Line4 ((uint32_t)0x00010) /*!< External interrupt line 4 */
#define EXTI_Line5 ((uint32_t)0x00020) /*!< External interrupt line 5 */
#define EXTI_Line6 ((uint32_t)0x00040) /*!< External interrupt line 6 */
#define EXTI_Line7 ((uint32_t)0x00080) /*!< External interrupt line 7 */
#define EXTI_Line8 ((uint32_t)0x00100) /*!< External interrupt line 8 */
#define EXTI_Line9 ((uint32_t)0x00200) /*!< External interrupt line 9 */
#define EXTI_Line10 ((uint32_t)0x00400) /*!< External interrupt line 10 */
#define EXTI_Line11 ((uint32_t)0x00800) /*!< External interrupt line 11 */
#define EXTI_Line12 ((uint32_t)0x01000) /*!< External interrupt line 12 */
#define EXTI_Line13 ((uint32_t)0x02000) /*!< External interrupt line 13 */
#define EXTI_Line14 ((uint32_t)0x04000) /*!< External interrupt line 14 */
#define EXTI_Line15 ((uint32_t)0x08000) /*!< External interrupt line 15 */
#define EXTI_Line16 ((uint32_t)0x10000) /*!< External interrupt line 16 Connected to the PVD Output */
#define EXTI_Line17 ((uint32_t)0x20000) /*!< External interrupt line 17 Connected to the RTC Alarm event */
#define EXTI_Line18 ((uint32_t)0x40000) /*!< External interrupt line 18 Connected to the USB OTG FS Wakeup from suspend event */
#define EXTI_Line19 ((uint32_t)0x80000) /*!< External interrupt line 19 Connected to the Ethernet Wakeup event */
#define EXTI_Line20 ((uint32_t)0x00100000) /*!< External interrupt line 20 Connected to the USB OTG HS (configured in FS) Wakeup event */
#define EXTI_Line21 ((uint32_t)0x00200000) /*!< External interrupt line 21 Connected to the RTC Tamper and Time Stamp events */
#define EXTI_Line22 ((uint32_t)0x00400000) /*!< External interrupt line 22 Connected to the RTC Wakeup event */
#define EXTI_Line23 ((uint32_t)0x00800000) /*!< External interrupt line 23 Connected to the LPTIM Wakeup event */
在stm32f4xx.h中, 有这些中断的常量, 注意: Line虽然是各自独立的, 但是IRQn不是, Handler也不是
EXTI0_IRQn = 6, /*!< EXTI Line0 Interrupt */
EXTI1_IRQn = 7, /*!< EXTI Line1 Interrupt */
EXTI2_IRQn = 8, /*!< EXTI Line2 Interrupt */
EXTI3_IRQn = 9, /*!< EXTI Line3 Interrupt */
EXTI4_IRQn = 10, /*!< EXTI Line4 Interrupt */
EXTI9_5_IRQn = 23, /*!< External Line[9:5] Interrupts */
EXTI15_10_IRQn = 40, /*!< External Line[15:10] Interrupts */
可以看到, 对于EXTI0到EXTI4(Line0到Line4), 都是单独的常量, 而Line5到Line9, Line10到Line15都是合用的.
对应的, 有以下的中断处理方法, 通过这些方法将自己的中断逻辑关联到对应的中断事件上去
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
EXTI9_5_IRQHandler
EXTI15_10_IRQHandler
初始化的步骤
- 使能I/O口时钟, 初始化I/O口为输入
- 使能SYSCFG时钟, 设置I/O口与中断线的映射关系
- 初始化中断线(EXTI线编号, 中断模式是中断还是事件, 触发方式是下降沿触发、上升沿触发还是任意电平触发, 是否使能中断线)
- 配置嵌套中断向量控制器NVIC
- 编写中断服务函数 对应各个中断线分别有EXTI0_IRQHandler(), EXTI1_IRQHandler(), ... EXTI9_5_IRQHandler(), EXTI15_10_IRQHandler().
官方的代码例子
- This example shows how to configure external interrupt lines.
- In this example, 2 EXTI lines (EXTI Line0 and Line15) are configured to generate an interrupt on each rising and falling edge, respectively.
- In the interrupt routine a LED connected to a specific GPIO pin is toggled.
static void EXTILine0_Config(void);
static void EXTILine13_15_Config(void);
/* Private functions ---------------------------------------------------------*/
* @brief Main program
* @param None
* @retval None
int main(void)
/* Initialize LEDs mounted on EVAL board */
STM_EVAL_LEDInit(LED1);
STM_EVAL_LEDInit(LED2);
/* Configure EXTI Line0 (connected to PA0 pin) in interrupt mode */
EXTILine0_Config();
/* Configure EXTI Line13/15 (connected to PG13/15 pin) in interrupt mode
according to EVAL used */
EXTILine13_15_Config();
/* Generate software interrupt: simulate a falling edge applied on EXTI0 line */
EXTI_GenerateSWInterrupt(EXTI_Line0);
while (1)
* @brief Configures EXTI Line0 (connected to PA0 pin) in interrupt mode
* @param None
* @retval None
EXTI_InitTypeDef EXTI_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
/* Enable GPIOA clock */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
/* Enable SYSCFG clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
/* Configure PA0 pin as input floating */
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Connect EXTI Line0 to PA0 pin */
SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource0);
/* Configure EXTI Line0 */
EXTI_InitStructure.EXTI_Line = EXTI_Line0;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
/* Enable and set EXTI Line0 Interrupt to the lowest priority */
NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
* @brief Configures EXTI Line15 (connected to PG15 pin) in interrupt mode
* @param None
* @retval None
#ifdef USE_STM324x9I_EVAL
/* Enable GPIOC clock */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
#else
/* Enable GPIOG clock */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOG, ENABLE);
#endif /* USE_STM324x9I_EVAL */
/* Configure PG15 pin as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
GPIO_Init(GPIOC, &GPIO_InitStructure);
#else
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
GPIO_Init(GPIOG, &GPIO_InitStructure);
/* Connect EXTI Line15 to PG15 pin */
SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOC, EXTI_PinSource13);
#else
SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOG, EXTI_PinSource15);
/* Configure EXTI Line15 */
EXTI_InitStructure.EXTI_Line = EXTI_Line13;
#else
EXTI_InitStructure.EXTI_Line = EXTI_Line15;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
/* Enable and set EXTI15_10 Interrupt to the lowest priority */
NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
处理中断的例子
中断处理, 涉及的就是三步: 1)消抖(如果是按键触发), 2)确认中断源, 3)清除中断标志位
// 1
void EXTI4_IRQHandler( void )
delay_ms( 10 ); /* 消抖 */
if ( GPIO_ReadInputDataBit( GPIOE, GPIO_Pin_4 ) == 0 ) {
GPIO_ResetBits(GPIOF,GPIO_Pin_9);//输出低电平,灯亮
/* 清除LINE4上的中断标志位 */
EXTI_ClearITPendingBit( EXTI_Line4 );
// 2
void EXTI0_IRQHandler(void)
if(EXTI_GetITStatus(EXTI_Line0) != RESET) {} // 确保产生了EXTI0线中断
LED_TOGGLE; // LED灯状态切换
EXTI_ClearITPendingBit(EXTI_Line0);// 清除中断标志位
// 3
/* Set interrupt handlers */
/* Handle PB12 interrupt */
void EXTI15_10_IRQHandler(void) {
/* Make sure that interrupt flag is set */
if (EXTI_GetITStatus(EXTI_Line12) != RESET) {
/* Do your stuff when PB12 is changed */
/* Clear interrupt flag */
EXTI_ClearITPendingBit(EXTI_Line12);
stm32f401 EXTI
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
EXTI9_5_IRQHandler
初始化的步骤
- 配置嵌套中断向量控制器NVIC
官方的代码例子
* @param None
* @retval None
int main(void)
EXTILine0_Config();
while (1)
* @param None
* @retval None
* @param None
* @retval None
#else
#else
#else
#else
处理中断的例子
// 1
// 2
// 3
