1. RK3399 CPU arm64
2. Firefly内核git: 内核配置 [lake@lake-aliyun -sh-china linux-stable]$ ls -l arch/arm64/configs/rk* -rw-r--r-- 1 Lake sys 10958 Mar 29 09:35 arch/arm64/configs/rk1808_linux_defconfig -rw-r- -r-- 1 湖系统 6025 Mar 29 09:35 arch/arm64/configs/rk1808_x4_linux_defconfig -rw-r--r-- 1 湖系统 7622 3 月 29 日 09:35 arch/arm64/configs/rk3308_linux_defconfig -rw-r--r-- 1 湖系统 11418 3 月 29 日 09:35 arch/arm64/configs/rk3326_linux_defconfig -rw-r--r-- 1 lake sys 9174 Mar 29 09:35 arch/arm64/configs/rk3326_linux_robot_defconfig -rw-r--r-- 1 lake sys 4490 Mar 29 09:35 arch/arm64/configs/rk3399pro_npu_defconfig -rw-r--r-- 1 Lake sys 11134 Mar 29 09:35 arch/arm64/configs/rk3399pro_npu_pcie_defconfig [lake@lake-aliyun-sh-china linux-stable]$ ls -l arch/arm64/configs/firefly * -rw-r--r-- 1 湖系统 16336 3 月 29 日 09:35 arch/arm64/configs/firefly_linux_defconfig -rw-r--r-- 1 湖系统 14966 3 月 29 日 09:35 arch/arm64/configs/萤火虫-roc-rk3328-pc_defconfig -rw-r--r-- 1 Lake sys 15859 Mar 29 09:35 arch/arm64/configs/firefly_roc-rk3399-pc_defconfig 3. 构建工具 3.1 CROSS_COMPILE gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux- gnu [lake@lake-aliyun-sh-china linux-stable]$ echo $PATH /home/lake/opt/gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux-gnu/bin:/usr/local/bin :/usr/bin:/usr/local/***in:/usr/***in:/home/lake/.local/bin:/home/lake/bin 3.2 : 内核构建工具 sudo yum install openssl-devel sudo yum install lz4 4. Build 4.1 build kernel make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- firefly_linux_defconfig 4.2 build dtb ### ### kernel with rk3399-firefly dtb make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- rk3399-firefly-linux.img ### kernel with rk3399-firefly-aioc dtb make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- rk3399-firefly-aioc.img [ lake@lake-aliyun-sh-china linux-stable]$ make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- rk3399-firefly-linux.img CHK scripts/mod/devicetable-offsets.h CHK include/config/kernel.发布 CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h CHK include/generated/bounds.h CHK include/generated/timeconst.h CHK include/generated/asm-offsets.h CALL scripts/检查系统调用.sh make[1]: `include/generated/vdso-offsets.h' 是最新的。 CHK include/generated/compile.h LZ4C arch/arm64/boot/Image.lz4 镜像:kernel.img 准备好了 CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/ utsrelease.h CHK include/generated/bounds.h CHK include/generated/timeconst.h CHK include/generated/asm- offsets.h CALL scripts/checksyscalls.sh make[2]: `include/generated/vdso-offsets.h ' 已是最新。 CHK scripts/mod/devicetable-offsets.h 构建模块,第 2 阶段 。MODPOST 1 模块 CC drivers/net/wireless/rockchip_wlan/rtl8188eu/8188eu.mod.o LD [M] drivers/net/wireless/rockchip_wlan/rtl8188eu/8188eu.ko DTC arch/arm64/boot/dts/rockchip/rk3399-firefly-linux。 dtb 打包到resource.img 成功! 图片:resource.img(带有 rk3399-firefly-linux.dtb logo.bmp)已准备好 图片:boot.img(带有 Image resource.img)已准备好 图片:zboot.img(带有 Image.lz4 resource.img)已准备好 [lake@lake-aliyun-sh-china linux-stable]$ ls -l *.img -rw-r--r-- 1 Lake sys 22702080 Mar 29 14:38 boot.img -rw-r--r- - 1 湖系统 22466580 3 月 29 日 14:37 kernel.img -rw-r--r-- 1 湖系统 230912 3 月 29 日 14:38 resource.img -rw-r--r-- 1 湖系统 11249664 14 年 3 月 29 日:38 zboot.img 注:boot.img = kernel.img + resource.img (DTB) For rk3399-firefly-aioc/EC-A3399C [lake@ lake- aliyun-sh-china linux-stable]$ make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- rk3399-firefly-aioc.img CHK scripts/mod/devicetable-offsets.h CHK include/config/kernel.release CHK include/ generated/uapi/linux/version.h CHK include/generated/utsrelease.h CHK include/generated/bounds.h CHK include/generated/timeconst.h CHK include/generated/asm- offsets.h CALL scripts/checksyscalls.sh make [1]: `include/generated/vdso-offsets.h' 是最新的。 CHK include/generated/compile.h make[1]: `arch/arm64/boot/Image.lz4' 是最新的。 图片:kernel.img 已准备好 CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h CHK include/generated/utsrelease.h CHK include/generated/bounds.h CHK include/generated/timeconst。 h CHK include/generated/asm- offsets.h CALL scripts/checksyscalls.sh make[2]: `include/generated/vdso-offsets.h' 是最新的。 CHK scripts/mod/devicetable-offsets.h 构建模块,阶段 2. MODPOST 0 modules DTC arch/arm64/boot/dts/rockchip/rk3399-firefly-aioc.dtb 打包到resource.img 成功! 图片:resource.img(带有 rk3399-firefly-aioc.dtb logo.bmp)已准备好 图片:boot.img(带有图片 resource.img)已准备好 图片:zboot.img(带有 Image.lz4 资源.img)已准备好 5.下载 官方解压/AIO-3399C-UBUNTU18.04-GPT-20190304-1225.img AndroidTool_Release_v2.54OutputAndroidImage参数 FIRMWARE_VER: 8.1 MACHINE_MODEL: RK3399 MACHINE_ID: 007 MANUFACTURER: RK3399 MAGIC: 0x50452 : 0x00200800 机器:3399 CHECK_MASK:0x80 PWR_HLD:0,0,A,0,1 类型:GPT cmdline:mtdparts = rk29xxnand:0x00002000 @ 0x00004000(Uboot),0x00002000 @ 0x00006000(trust),0x00010000 @ 0x0000a000(boot),0x00010000 @ 0x0002a000(备份), - @ 0x0005a000(rootfs:grow) uuid:rootfs = 614e0000-0000- 4b53-8000-1d28000054a9 ### 远程 ssh/dd/下载新的 boot.img => mmcblk0p3 firefly@firefly:~$ partx /dev/mmcblk0 partx: 无法打开 /dev/mmcblk0: Permission denied firefly@firefly:~$ sudo partx的/ dev / mmcblk0 NR START END SECTORS尺寸名称UUID 1 16384 24575 8192 4M的uboot 80690000-0000-4568-8000-5dea000057bf 2 24576 32767 8192 4M信任cd3a0000-0000-4c5e-8000-6be60000034f 3 40960 106495 65536 32M引导9f6a0000- 0000-4e20-8000-6722000046d3 4点172032 237567 65536 32M备份5f590000-0000-4116-8000-0c0500007733 5 368640 30535646 30167007 14.4克的rootfs 614e0000-0000-4b53-8000-1d28000054a9 萤火虫萤火虫@:〜$ LS 桌面文档下载音乐图片公共模板影片的boot.img来源.list firefly@firefly:~$ dd if=./boot.img of=/dev/mmcblk0 mmcblk0 mmcblk0boot1 mmcblk0p2 mmcblk0p4 mmcblk0rpmb mmcblk0boot0 mmcblk0p1 mmcblk0p3 mmcblk0p5 firefly@firefly:~$ dd if=./boot.img of=/dev/ mmcblk0p3 dd: 无法打开 '/dev/mmcblk0p3': Permission denied firefly@firefly:~$ sudo dd if=./boot.img of=/dev/mmcblk0p3 44340+0 records in 44340+0 records out 复制了 22702080 字节(23 MB,22 MiB),1.78948 秒,12.7 MB/秒 firefly@firefly:~$ |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1774 浏览 0 评论
2349 浏览 1 评论
2014 浏览 1 评论
3352 浏览 1 评论
4118 浏览 1 评论
GMT+8, 2025-1-14 19:09 , Processed in 0.631309 second(s), Total 70, Slave 54 queries .
