问题:在使用 K210 时使用官方介绍使用的八位通信,发送的数据为中需要十六位的数据,因为数据可能百位。
解决方法:将数据打包后发送。
一下为打包函数:
def sending_data(cx,cy,ch):
global uart;
#frame=[0x2C,18,cx%0xff,int(cx/0xff),cy%0xff,int(cy/0xff),0x5B];
#data = bytearray(frame)
data = ustruct.pack("
0x2C, #帧头1
0x12, #帧头2
int(cx), # up sample by 4 #数据1
int(cy), # up sample by 4 #数据2
int(ch),
0x5B)
uart = UART(UART.UART1, 115200, 8, 1, 0, timeout=1000, read_buf_len=4096)
uart.write(data); #必须要传入一个字节数组
MAIX BIT K210端完整代码
# object detector boot.py
# generated by maixhub.com
import sensor, image, lcd, time
import KPU as kpu
import gc, sys
import ustruct
#LED
from fpioa_manager import fm
from Maix import GPIO
io_led_red = 13
io_led_bule = 14
io_led_green = 12
fm.register(io_led_red, fm.fpioa.GPIO0)
fm.register(io_led_bule, fm.fpioa.GPIO1)
fm.register(io_led_green, fm.fpioa.GPIO2)
led_r=GPIO(GPIO.GPIO0, GPIO.OUT)
led_b=GPIO(GPIO.GPIO1, GPIO.OUT)
led_g=GPIO(GPIO.GPIO2, GPIO.OUT)
#串口
from machine import UART
# need your connect hardware IO 10/11 to loopback
fm.register(10, fm.fpioa.UART1_TX, force=True)
fm.register(9, fm.fpioa.UART1_RX, force=True)
global uart;
0x2C, #帧头1
0x12, #帧头2
int(ch),
0x5B)
def lcd_show_except(e):
import uio
err_str = uio.StringIO()
sys.print_exception(e, err_str)
err_str = err_str.getvalue()
img = image.Image(size=(224,224))
img.draw_string(0, 10, err_str, scale=1, color=(0xff,0x00,0x00))
lcd.display(img)
def main(anchors, labels = None, model_addr="/sd/m.kmodel", sensor_window=(240, 240), lcd_rotation=0, sensor_hmirror=False, sensor_vflip=False):
sensor.reset()
sensor.set_pixformat(sensor.RGB565)
sensor.set_framesize(sensor.QVGA)
sensor.set_windowing(sensor_window)
sensor.set_hmirror(sensor_hmirror)
sensor.set_vflip(sensor_vflip)
sensor.run(1)
lcd.init(type=1)
lcd.rotation(lcd_rotation)
lcd.clear(lcd.WHITE)
#uart = UART(UART.UART1, 500000, 8, 1, 0, timeout=1000, read_buf_len=4096)
#白灯开机指示
led_r.value(0)
led_b.value(0)
led_g.value(0)
if not labels:
with open('labels.txt','r') as f:
exec(f.read())
if not labels:
print("no labels.txt")
img = image.Image(size=(320, 240))
img.draw_string(90, 110, "no labels.txt", color=(255, 0, 0), scale=2)
lcd.display(img)
return 1
try:
img = image.Image("startup.jpg")
lcd.display(img)
except Exception:
img.draw_string(90, 110, "loading model...", color=(255, 255, 255), scale=2)
lcd.display(img)
try:
task = None
task = kpu.load(model_addr)
kpu.init_yolo2(task, 0.5, 0.3, 5, anchors) # threshold:[0,1], nms_value: [0, 1]
while(True):
img = sensor.snapshot()
t = time.ticks_ms()
objects = kpu.run_yolo2(task, img)
t = time.ticks_ms() - t
if objects:
for obj in objects:
pos = obj.rect()
img.draw_rectangle(pos)
img.draw_string(pos[0], pos[1], "%s : %.2f" %(labels[obj.classid()], obj.value()), scale=2, color=(255, 0, 0))
#串口发送数据
objx = (obj.x()+obj.w())/2
objy = (obj.y()+obj.h())/2
#uart.write("AB%sD%dE%dF" %(labels[obj.classid()], objx, objy))
#print("AB%sD%dE%dF" %(labels[obj.classid()], objx, objy))
if labels[obj.classid()] == "WWW":
sending_data(1,objx,objy)
led_r.value(0)
if labels[obj.classid()] == "CAR":
sending_data(2,objx,objy)
led_b.value(0)
if labels[obj.classid()] == "HHH":
sending_data(3,objx,objy)
led_g.value(0)
else:
sending_data(0,0,0)
led_r.value(1)
led_b.value(1)
led_g.value(1)
#print(00000)
img.draw_string(0, 200, "t:%dms" %(t), scale=2, color=(255, 0, 0))
lcd.display(img)
except Exception as e:
raise e
finally:
if not task is None:
kpu.deinit(task)
if __name__ == "__main__":
try:
labels = ["CAR", "WWW", "HHH"]
anchors = [5.5, 6.90625, 5.0, 5.0, 4.1875, 4.125, 6.875, 5.25, 10.5, 9.9375]
# main(anchors = anchors, labels=labels, model_addr=0x300000, lcd_rotation=0)
main(anchors = anchors, labels=labels, model_addr="/sd/m.kmodel")
sys.print_exception(e)
lcd_show_except(e)
finally:
gc.collect()
单片机端的数据处理代码
//Maix字节处理
void Maix_Byte_Get(u8 bytedata){
static u8 rec_sta;
//u8 check_val=0;
maix_buf[rec_sta] = bytedata;
if(rec_sta==0)
if(bytedata==0x2C)
rec_sta=1;
else
rec_sta=0;
else if(rec_sta==1)
if(bytedata==0x12)
rec_sta=2;
else
rec_sta=0;
else if(rec_sta==2)
rec_sta=3;
else if(rec_sta == 3)
maix.clas = maix_buf[3]<<8|maix_buf[2];
rec_sta=4;
else if(rec_sta ==4)
rec_sta=5;
else if(rec_sta == 5)
maix.pos_x = maix_buf[5]<<8|maix_buf[4];
rec_sta=6;
else if(rec_sta == 6)
rec_sta=7;
else if(rec_sta == 7)
maix.pos_y = maix_buf[7]<<8|maix_buf[6];
rec_sta = 8;
else if(rec_sta == 8)
rec_sta = 9;
else if(rec_sta ==9)
rec_sta = 0;
解决方法:将数据打包后发送。
一下为打包函数:
global uart;
0x2C, #帧头1
0x12, #帧头2
int(ch),
0x5B)
MAIX BIT K210端完整代码
import KPU as kpu
import gc, sys
import ustruct
#LED
io_led_red = 13
io_led_bule = 14
io_led_green = 12
#串口
global uart;
0x2C, #帧头1
0x12, #帧头2
int(ch),
0x5B)
import uio
lcd.display(img)
sensor.reset()
sensor.run(1)
lcd.init(type=1)
#白灯开机指示
led_r.value(0)
led_b.value(0)
led_g.value(0)
if not labels:
exec(f.read())
if not labels:
lcd.display(img)
return 1
try:
lcd.display(img)
except Exception:
lcd.display(img)
try:
task = None
while(True):
t = time.ticks_ms()
if objects:
for obj in objects:
pos = obj.rect()
#串口发送数据
led_r.value(0)
led_b.value(0)
led_g.value(0)
else:
sending_data(0,0,0)
led_r.value(1)
led_b.value(1)
led_g.value(1)
#print(00000)
lcd.display(img)
raise e
finally:
kpu.deinit(task)
try:
lcd_show_except(e)
finally:
gc.collect()
单片机端的数据处理代码
//Maix字节处理
static u8 rec_sta;
//u8 check_val=0;
if(rec_sta==0)
if(bytedata==0x2C)
rec_sta=1;
else
rec_sta=0;
else if(rec_sta==1)
if(bytedata==0x12)
rec_sta=2;
else
rec_sta=0;
else if(rec_sta==2)
rec_sta=3;
rec_sta=4;
rec_sta=5;
rec_sta=6;
rec_sta=7;
rec_sta = 8;
rec_sta = 9;
rec_sta = 0;
