#include
***it L1 = P0^0; ***it L8 = P0^7; unsigned char count = 0; //计数 void Select_HC138(unsigned char n) { switch(n) { case 4: P2 = (P2 & 0x1f) | 0x80; break; case 5: P2 = (P2 & 0x1f) | 0xa0; break; } } void Init_timer0() //定时器0初始化(中断初始化) { TMOD = 0x01; //选择定时器0(16位定时器),定时50ms(间隔50000个脉冲) TH0 = (65535 - 50000) / 256; //取高八位(3c)给TH0寄存器 TL0 = (65535 - 50000) % 256; //取低八位(af)给TL0寄存器 EA = 1; //打开总中断 ET0 = 1; //打开定时器0的中断 TR0 = 1; //启动定时器 } void Service_timer0() interrupt 1 //定时器0中断服务函数 { TH0 = (65535 - 50000) / 256; TL0 = (65535 - 50000) % 256; //一次计时完后需要给TH0和TL0赋初值 count++; if(count % 10 == 0) //定时0.5s { L1 = ~L1; //每隔0.5s点亮L1且L1亮0.5s } if(count == 100) //定时5s { L8 = ~L8; //每隔5s点亮L8且L8亮5s count = 0; } } void main() { Init_timer0(); //中断初始化 Select_HC138(5); P0 = 0x00; //关闭蜂鸣器和继电器 Select_HC138(4); P0 = 0xff; while(1) { } } |
1739 浏览 0 评论
3339 浏览 9 评论
3017 浏览 16 评论
3508 浏览 1 评论
9106 浏览 16 评论
1223浏览 3评论
632浏览 2评论
621浏览 2评论
2363浏览 2评论
1928浏览 2评论
GMT+8, 2025-1-14 08:33 , Processed in 1.858180 second(s), Total 77, Slave 58 queries .
