#include
#include"IIC.h"
***it S4 = P3^3; //定义独立按键
unsigned char dat_Rd1 = 0; //存放Rd1数据
unsigned char dat_Rb2 = 0; //存放Rb2数据
unsigned char state = 0; //标志位
unsigned char code SEG_code[18] =
{0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,
0xbf,0x7f}; //定义共阳数码管段码内容:0~F,—,.
void Select_HC138(unsigned char n)
switch(n)
case 5:
P2 = (P2 & 0x1f) | 0xa0;
break;
case 6:
P2 = (P2 & 0x1f) | 0xc0;
break;
case 7:
P2 = (P2 & 0x1f) | 0xe0;
break;
void Delay_tube(unsigned char t) //数码管延时函数
while(t--);
void Show_tube(unsigned char position,unsigned char value)
Select_HC138(7);
P0 = 0xff;
Select_HC138(6);
P0 = 0x01 << position;
Select_HC138(7);
P0 = value;
void Show_all()
Select_HC138(7);
P0 = 0xff;
Select_HC138(6);
P0 = 0xff;
void Display_tube(unsigned char channel,unsigned char dat)
Show_tube(0,SEG_code[16]);
Delay_tube(100);
Show_tube(1,SEG_code[channel]); //显示通道
Delay_tube(100);
Show_tube(2,SEG_code[16]);
Delay_tube(100);
Show_tube(5,SEG_code[dat/100]); //显示电压的百位
Delay_tube(100);
Show_tube(6,SEG_code[(dat/10)%10]); //显示电压的十位
Delay_tube(100);
Show_tube(7,SEG_code[dat%10]); //显示电压的个位
Delay_tube(100);
Show_all();
void Delay_keys() //按键延时函数
unsigned char i,j;
i = 108;
j = 145;
do
while(--j);
}while(--i);
void Press_keys()
if(S4 == 0)
Delay_keys();
if(S4 == 0)
if(state == 0)
state = 1; //显示Rb2
else if(state == 1)
state = 0; //显示Rd1
while(S4 == 0);
void Read_Rd1() //采样光敏电阻Rd1的电压
IIC_Start(); //IIC总线起始信号
IIC_SendByte(0x90); //写设备地址
IIC_WaitAck(); //等待从机应答
IIC_SendByte(0x01); //写控制字
IIC_Stop(); //IIC总线停止信号
IIC_SendByte(0x91); //读设备地址
dat_Rd1 = IIC_RecByte(); //读取PCF8591通道1的数据
IIC_Ack(0); //产生非应答信号
void Read_Rb2() //采样电位器Rb2的电压
IIC_Start();
IIC_SendByte(0x90);
IIC_WaitAck();
IIC_SendByte(0x03);
IIC_WaitAck();
IIC_Stop();
IIC_Start();
IIC_SendByte(0x91);
IIC_WaitAck();
dat_Rb2 = IIC_RecByte();
IIC_Ack(0);
IIC_Stop();
void main()
Select_HC138(5);
P0 = 0x00; //关闭蜂鸣器和继电器
while(1)
Press_keys();
switch(state)
case 0:
Read_Rd1();
Display_tube(1,dat_Rd1);
break;
case 1:
Read_Rb2();
Display_tube(3,dat_Rb2);
break;
#include
#include"IIC.h"
switch(n)
case 5:
break;
case 6:
break;
case 7:
break;
while(t--);
Select_HC138(7);
P0 = 0xff;
Select_HC138(6);
Select_HC138(7);
P0 = value;
void Show_all()
Select_HC138(7);
P0 = 0xff;
Select_HC138(6);
P0 = 0xff;
Delay_tube(100);
Delay_tube(100);
Delay_tube(100);
Delay_tube(100);
Delay_tube(100);
Delay_tube(100);
Show_all();
unsigned char i,j;
i = 108;
j = 145;
do
while(--j);
}while(--i);
void Press_keys()
if(S4 == 0)
Delay_keys();
if(S4 == 0)
if(state == 0)
state = 1; //显示Rb2
else if(state == 1)
state = 0; //显示Rd1
while(S4 == 0);
IIC_Start();
IIC_SendByte(0x90);
IIC_WaitAck();
IIC_SendByte(0x03);
IIC_WaitAck();
IIC_Stop();
IIC_Start();
IIC_SendByte(0x91);
IIC_WaitAck();
IIC_Ack(0);
IIC_Stop();
void main()
Select_HC138(5);
while(1)
Press_keys();
switch(state)
case 0:
Read_Rd1();
break;
case 1:
Read_Rb2();
break;
