RK3036
回帖(1)
2022-3-2 17:40:31
Platform: Rockchip
OS: Android 6.0
Kernel: 3.10.92
diff --git a/arch/arm/boot/dts/rk3288-b.dts b/arch/arm/boot/dts/rk3288-b.dts
index ad3bc1a..f000e29 100644
--- a/arch/arm/boot/dts/rk3288-b.dts
+++ b/arch/arm/boot/dts/rk3288-b.dts
@@ -353,7 +353,7 @@
&fb {
rockchip,disp-mode = ;
- rockchip,uboot-logo-on = <1>;
+ rockchip,uboot-logo-on = <0>;
在移除了uboot logo之后还是会显示kernel logo(kerne自带而并非rk显示logo机制),所有需要关闭.
diff --git a/arch/arm/configs/rockchip_b_defconfig b/arch/arm/configs/rockchip_b_defconfig
index 092dc3c..b699f96 100644
--- a/arch/arm/configs/rockchip_b_defconfig
+++ b/arch/arm/configs/rockchip_b_defconfig
@@ -439,7 +439,7 @@ CONFIG_RK1000_TVOUT_CVBS=y
CONFIG_RK3036_TV_ENCODER=y
CONFIG_ROCKCHIP_RGA=y
CONFIG_ROCKCHIP_RGA2=y
-CONFIG_LOGO=y
+#CONFIG_LOGO=y
CONFIG_SOUND=y
CONFIG_SND=y
# CONFIG_SND_SUPPORT_OLD_API is not set
uboot logo显示可参考:
http://blog.csdn.net/kris_fei/article/details/52584903
kernel logo是根据是否开启了uboot logo display来决定是否要显示的,在函数rk_fb_register()中,
并且kernel logo的图片大小要和uboot一直,否则就无法显示。
#if !defined(CONFIG_FRAMEBUFFER_CONSOLE)
if (dev_drv->prop == PRMRY) {
u16 xact, yact;
int format;
u32 dsp_addr;
struct fb_info *main_fbi = rk_fb->fb[0];
main_fbi->fbops->fb_open(main_fbi, 1);
main_fbi->var.pixclock = dev_drv->pixclock;
if (dev_drv->iommu_enabled) {
if (dev_drv->mmu_dev)
rockchip_iovmm_set_fault_handler(dev_drv->dev,
rk_fb_sysmmu_fault_handler);
rk_fb_alloc_buffer(main_fbi);/* only alloc memory for main fb */
dev_drv->uboot_logo = support_uboot_display(); //是否支持uboot logo display
if (dev_drv->uboot_logo &&
uboot_logo_offset && uboot_logo_base) {
int width, height, bits, xvir;
phys_addr_t start = uboot_logo_base + uboot_logo_offset;
unsigned int size = uboot_logo_size - uboot_logo_offset;
unsigned int nr_pages;
int ymirror = 0;
struct page **pages;
char *vaddr;
int i = 0;
if (dev_drv->ops->get_dspbuf_info)
dev_drv->ops->get_dspbuf_info(dev_drv, &xact,
&yact, &format,&dsp_addr, &ymirror);
nr_pages = size >> PAGE_SHIFT;
pages = kzalloc(sizeof(struct page) * nr_pages,
GFP_KERNEL);
while (i < nr_pages) {
pages = phys_to_page(start);
start += PAGE_SIZE;
i++;
vaddr = vmap(pages, nr_pages, VM_MAP,
pgprot_writecombine(PAGE_KERNEL));
if (!vaddr) {
pr_err("failed to vmap phy addr 0x%lxn",
(long)(uboot_logo_base +
uboot_logo_offset));
return -1;
//bmp图片解压
if (bmpdecoder(vaddr, main_fbi->screen_base, &width,
&height, &bits)) {
kfree(pages);
vunmap(vaddr);
return 0;
kfree(pages);
vunmap(vaddr);
(width != xact || height != yact)) {
pr_err("can't support uboot kernel logo use different size [%dx%d] != [%dx%d]n",
xact, yact, width, height);
return 0;
xvir = ALIGN(width * bits, 1 << 5) >> 5;
ymirror = 0;
local_irq_save(flags);
if (dev_drv->ops->wait_frame_start)
dev_drv->ops->wait_frame_start(dev_drv, 0);
if (dev_drv->ops->post_dspbuf) {
dev_drv->ops->post_dspbuf(dev_drv,
main_fbi->fix.smem_start,
rk_fb_data_fmt(0, bits),
width, height, xvir,
ymirror);
rk_fb_poll_wait_frame_complete();
if (dev_drv->ops->mmu_en)
dev_drv->ops->mmu_en(dev_drv);
freed_index = 0;
local_irq_restore(flags);
return 0;
} else if (dev_drv->uboot_logo && uboot_logo_base) {
u32 start = uboot_logo_base;
int logo_len, i = 0;
int y_mirror = 0;
char *vaddr;
int align = 0, xvir;
&yact, &format,
&start,
&y_mirror);
logo_len = rk_fb_pixel_width(format) * xact * yact >> 3;
if (logo_len > uboot_logo_size ||
logo_len > main_fbi->fix.smem_len) {
pr_err("logo size > uboot reserve buffer sizen");
return -1;
if (y_mirror)
start -= logo_len;
align = start % PAGE_SIZE;
start -= align;
nr_pages = PAGE_ALIGN(logo_len + align) >> PAGE_SHIFT;
GFP_KERNEL);
start += PAGE_SIZE;
i++;
if (!vaddr) {
pr_err("failed to vmap phy addr 0x%xn",
start);
return -1;
memcpy(main_fbi->screen_base, vaddr + align, logo_len);
kfree(pages);
vunmap(vaddr);
xvir = ALIGN(xact * rk_fb_pixel_width(format),
1 << 5) >> 5;
main_fbi->fix.smem_start +
(y_mirror ? logo_len : 0),
format,xact, yact,
xvir,
y_mirror);
freed_index = 0;
return 0;
} else {
freed_index = 0;
#if defined(CONFIG_LOGO)
main_fbi->fbops->fb_set_par(main_fbi);
#if defined(CONFIG_LOGO_LINUX_BMP)
if (fb_prewine_bmp_logo(main_fbi, FB_ROTATE_UR)) {
fb_set_cmap(&main_fbi->cmap, main_fbi);
fb_show_bmp_logo(main_fbi, FB_ROTATE_UR);
#else
if (fb_prepare_logo(main_fbi, FB_ROTATE_UR)) {
fb_show_logo(main_fbi, FB_ROTATE_UR);
#endif
main_fbi->fbops->fb_pan_display(&main_fbi->var, main_fbi);
#endif
} else {
struct fb_info *extend_fbi = rk_fb->fb[dev_drv->fb_index_base];
extend_fbi->var.pixclock = rk_fb->fb[0]->var.pixclock;
extend_fbi->fbops->fb_open(extend_fbi, 1);
rk_fb_alloc_buffer(extend_fbi);
#endif
Platform: Rockchip
OS: Android 6.0
Kernel: 3.10.92
@@ -353,7 +353,7 @@
&fb {
-CONFIG_LOGO=y
+#CONFIG_LOGO=y
CONFIG_SOUND=y
CONFIG_SND=y
uboot logo显示可参考:
u16 xact, yact;
int format;
u32 dsp_addr;
int ymirror = 0;
char *vaddr;
int i = 0;
GFP_KERNEL);
start += PAGE_SIZE;
i++;
if (!vaddr) {
return -1;
//bmp图片解压
&height, &bits)) {
kfree(pages);
vunmap(vaddr);
return 0;
kfree(pages);
vunmap(vaddr);
return 0;
ymirror = 0;
ymirror);
freed_index = 0;
return 0;
int y_mirror = 0;
char *vaddr;
&yact, &format,
&start,
&y_mirror);
return -1;
if (y_mirror)
start -= logo_len;
start -= align;
GFP_KERNEL);
start += PAGE_SIZE;
i++;
if (!vaddr) {
start);
return -1;
kfree(pages);
vunmap(vaddr);
1 << 5) >> 5;
format,xact, yact,
xvir,
y_mirror);
freed_index = 0;
return 0;
} else {
freed_index = 0;
#else
#endif
#endif
} else {
#endif
