登录
陈博
13年用户
591经验值
擅长:12268
私信
关注
RK3568J edp屏幕点亮时序调试过程是怎样的?
开启该帖子的消息推送
RK3568
张玉兰
2022-3-2 17:55:33
硬件资源:
开发板:天启RK3568J
屏幕:杭州立煌 产品型号:GV101WXM‑N81
一、编译相关:
1、设备树dts 介绍:
linux DTS 介绍
2、设备树dts 入门总结:
linux 源码中包含多个 dts 文件和 dtsi 文件。(dts文件目录:kernel/arch/arm64/boot/dts/rockchip/)
一次编译只会编译一个 板级 dts文件,这个dts 会递归包含 多个dtsi 文件,最后生成 dtb文件。
我们基本上只需要修改这个板级dts文件即可
3、设备树dts 编译:
1、指定要编译的dts 文件:device/rockchip/.BoardConfig.mk(以 rk3568-firefly-aioj-edp-M156X40为 例)
1 #!/bin/bash
2
3 CMD=`realpath $BASH_SOURCE`
4 CUR_DIR=`dirname $CMD`
5
6 source $CUR_DIR/firefly-rk3568_buildroot.mk
7
8 # Kernel dts
9 ++ #export RK_KERNEL_DTS=rk3568-firefly-aioj
10++ export RK_KERNEL_DTS=rk3568-firefly-aioj-edp-M156X40
2、添加编译文件:kernel/arch/arm64/boot/dts/rockchip/Makefile
110 dtb-$(CONFIG_ARCH_ROCKCHIP) += rk3568-nvr-demo-v12-linux.dtb
111 dtb-$(CONFIG_ARCH_ROCKCHIP) += rk3568-nvr-demo-v12-linux-spi-nand.dtb
112 ++ dtb-$(CONFIG_ARCH_ROCKCHIP) += rk3568-firefly-aioj-edp-M156X40.dtb
二、edp 屏幕时序调试:
AIO-3568J的SDK有EDP的DTS文件:kernel/arch/arm64/boot/dts/rockchip/rk3568-firefly-aioj-edp_M156X40.dts
1、引脚配置(根据 datasheet 调整):
a、lcd 使能:
[tr]NAMEGPIOGPIO_ACTIVE[/tr][tr]vcc3v3_lcd_edp (LCD_EN)GPIO1_B1GPIO_ACTIVE_HIGH[/tr]
vcc3v3_lcd_edp: vcc3v3-lcd-edp {
compatible = "regulator-fixed";
gpio = <&gpio1 RK_PB1 GPIO_ACTIVE_HIGH>;
enable-active-high;
regulator-name = "vcc3v3_lcd_edp";
regulator-boot-on;
regulator-state-mem {
regulator-off-in-suspend;
b、背光 使能:
[tr]NAMEGPIOGPIO_ACTIVE[/tr][tr]enable-gpios(BL_EN)GPIO1_A4GPIO_ACTIVE_HIGH[/tr]
edp_panel: edp-panel {
compatible = "simple-panel";
status = "okay";
power-supply = <&vcc3v3_lcd_edp>;
enable-gpios = <&gpio1 RK_PA4 GPIO_ACTIVE_LOW>;
//bus-format =
backlight = <&backlight>;
ports {
panel_in_edp: endpoint {
remote-endpoint = <&edp_out_panel>;
c、EDP_HPD 使能:
[tr]NAMEGPIOGPIO_ACTIVE[/tr][tr]hpd-gpios(EDP_HPD)GPIO0_C2GPIO_ACTIVE_HIGH[/tr]
&edp {
status = "okay";
hpd-gpios = <&gpio0 RK_PC2 GPIO_ACTIVE_HIGH>;
force-hpd;
ports {
edp_out: port@1 {
reg = <1>;
#address-cells = <1>;
#size-cells = <0>;
edp_out_panel: endpoint@0 {
reg = <0>;
remote-endpoint = <&panel_in_edp>;
2、背光配置:
backlight: backlight {
status = "okay";
compatible = "pwm-backlight";
pwms = <&pwm14 0 2000 1>;//pwm4:PWM number 0 2000:PWM period in nanoseconds 1:polarity(如有问题可调试0|1)
brightness-levels = <
0 1 2 3 4 5 6 7
8 9 10 11 12 13 14 15
16 17 18 19 20 21 22 23
24 25 26 27 28 29 30 31
32 33 34 35 36 37 38 39
40 41 42 43 44 45 46 47
48 49 50 51 52 53 54 55
56 57 58 59 60 61 62 63
64 65 66 67 68 69 70 71
72 73 74 75 76 77 78 79
80 81 82 83 84 85 86 87
88 89 90 91 92 93 94 95
96 97 98 99 100 101 102 103
104 105 106 107 108 109 110 111
112 113 114 115 116 117 118 119
120 121 122 123 124 125 126 127
128 129 130 131 132 133 134 135
136 137 138 139 140 141 142 143
144 145 146 147 148 149 150 151
152 153 154 155 156 157 158 159
160 161 162 163 164 165 166 167
168 169 170 171 172 173 174 175
176 177 178 179 180 181 182 183
184 185 186 187 188 189 190 191
192 193 194 195 196 197 198 199
200 201 202 203 204 205 206 207
208 209 210 211 212 213 214 215
216 217 218 219 220 221 222 223
224 225 226 227 228 229 230 231
232 233 234 235 236 237 238 239
240 241 242 243 244 245 246 247
248 249 250 251 252 253 254 255>;
default-brightness-level = <200>;
enable-gpios:背光使能脚,高电平有效。
pwms属性:配置PWM,范例里面默认使用pwm14,2000ns是周期(2 KHz),pwm为负极性。
brightness-levels属性:配置背光亮度数组,一般以值 255 为一个 scale,当 PWM 设置为正极性时,从 0~255 表示背光为正极,占空比从 0%~100% 变化,255~0 为负极性,占空比从 100%~0% 变化;当 PWM 设置为负极性时,反之。
default-brightness-level属性:开机时默认背光亮度,范围为0-255。
3、显示时序配置:(主要看 timing0 节点)
图片:屏参包括屏的格式、dclk、时序等。
根据文档数据可得:
时钟频率: clock-frequency =80MHZ(屏参写的是450Mbps但是通过调试发现80Mhz有效)
水平有效像素:Hactive=1280
垂直有效像素:Vactive=800
水平总周期 =1516
hback-porch/hfront-porch/hsync-len:水平同步信号
vback-porch/vfront-porch/vsync-len:垂直同步信号
根据公式水平总周期 = hback-porch + hfront-porch + hsync-len+Hactive
知道hback-porch + hfront-porch + hsync-len=水平总周期 - Hactive=236
垂直总周期=831
根据公式垂直总周期 = vback-porch + vfront-porch + vsync-len+Vactive
知道vback-porch + vfront-porch + vsync-len=垂直总周期 - Vactive=31
status = "okay";
enable-gpios = <&gpio1 RK_PA4 GPIO_ACTIVE_HIGH>;
prepare-delay-ms = <201>;
enable-delay-ms = <201>;
display-timings {
native-mode = <&timing0>;
timing0: timing0 {
clock-frequency = <80000000>;
hactive = <1280>;
vactive = <800>;
hfront-porch = <110>;/只需保证hback-porch + hfront-porch + hsync-len=236
hsync-len = <10>;
hback-porch = <116>;
vfront-porch = <13>;//只需保证vback-porch + vfront-porch + vsync-len=31
vsync-len = <4>;
vback-porch = <14>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
pixelclk-active = <0>;
ports {
三、调试遇到的问题
1、背光不亮
主要修改:pwms 属性,包括 “周期” 和 “pwm正负极性”。
2、没有画面
调整clock-frequency 周期
缩小hsync-len 和 vsync-len
3、开机闪屏
不需要指定:bus-format属性
四、完整代码如下:
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
* Copyright (c) 2020 Rockchip Electronics Co., Ltd.
/dts-v1/;
#include "rk3568-firefly-aioj.dtsi"
model = "AIO-3568J HDMI (Linux)";
compatible = "rockchip,rk3568-firefly-aioj", "rockchip,rk3568";
enable-active-high;
regulator-boot-on;
status = "okay";
display-timings {
timing0: timing0 {
hactive = <1280>;
vactive = <800>;
hsync-len = <10>;
vsync-len = <4>;
vback-porch = <14>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
ports {
status = "okay";
0 1 2 3 4 5 6 7
&pwm14 {
status = "okay";
&edp {
status = "okay";
force-hpd;
ports {
edp_out: port@1 {
reg = <1>;
#size-cells = <0>;
reg = <0>;
&route_edp {
status = "okay";
connect = <&vp0_out_edp>;
&edp_phy {
status = "okay";
&edp_in_vp0 {
status = "okay";
&edp_in_vp1 {
status = "okay";
#size-cells = <0>;
reg = <0>;
&route_edp {
status = "okay";
&edp_phy {
status = "okay";
&edp_in_vp0 {
status = "okay";
&edp_in_vp1 {
status = "okay";
硬件资源:
开发板:天启RK3568J
一、编译相关:
1、设备树dts 介绍:
linux DTS 介绍
2、设备树dts 入门总结:
3、设备树dts 编译:
1 #!/bin/bash
2
5
7
8 # Kernel dts
二、edp 屏幕时序调试:
a、lcd 使能:
enable-active-high;
regulator-boot-on;
b、背光 使能:
status = "okay";
//bus-format =
ports {
c、EDP_HPD 使能:
&edp {
status = "okay";
force-hpd;
ports {
edp_out: port@1 {
reg = <1>;
#size-cells = <0>;
reg = <0>;
2、背光配置:
status = "okay";
0 1 2 3 4 5 6 7
根据文档数据可得:
水平有效像素:Hactive=1280
垂直有效像素:Vactive=800
水平总周期 =1516
垂直总周期=831
status = "okay";
display-timings {
timing0: timing0 {
hactive = <1280>;
vactive = <800>;
hsync-len = <10>;
vsync-len = <4>;
vback-porch = <14>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
ports {
三、调试遇到的问题
1、背光不亮
2、没有画面
3、开机闪屏
不需要指定:bus-format属性
四、完整代码如下:
/dts-v1/;
enable-active-high;
regulator-boot-on;
status = "okay";
display-timings {
timing0: timing0 {
hactive = <1280>;
vactive = <800>;
hsync-len = <10>;
vsync-len = <4>;
vback-porch = <14>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
ports {
status = "okay";
0 1 2 3 4 5 6 7
&pwm14 {
status = "okay";
&edp {
status = "okay";
force-hpd;
ports {
edp_out: port@1 {
reg = <1>;
#size-cells = <0>;
reg = <0>;
&route_edp {
status = "okay";
&edp_phy {
status = "okay";
&edp_in_vp0 {
status = "okay";
&edp_in_vp1 {
status = "okay";
#size-cells = <0>;
reg = <0>;
&route_edp {
status = "okay";
&edp_phy {
status = "okay";
&edp_in_vp0 {
status = "okay";
&edp_in_vp1 {
status = "okay";
rotate(-90deg);
回复
相关问答
RK3568
RK3568J
配置
EDP
没有设备接点
屏幕
也无输出是何原因
2022-11-09
2450
致远电子的
RK3568J
开发板可以烧录其他的固件吗
2024-02-01
10501
请教一下
RK3568
是如何将
EDP
转成VGA-out的
2022-03-02
910
如何对
RK3568
-ANDROID11 PWM背光和红外威廉希尔官方网站 进行
调试
呢
2022-03-02
1270
RK3568
的软件环境具有哪些功能呢
2022-03-02
1860
如何对
RK3568
环境上的AOSP源码进行
调试
呢
2022-03-02
1391
主板
rk3568
,有LVDS30pin,
edp
20pin,mipi40pin接口,
屏幕
是京东方TV101WUM-LZ4,接口应该是0.3mm 51pin,如何进行连接。
2023-08-08
3528
ROC-
RK3568
-PC开发板
调试
串口无法输入是何原因?
2023-02-07
1713
怎样
对
RK3568
Debian10 AP6275S Bluetooth进行
调试
呢
2022-03-02
1762
怎样
去解决
RK3568
-ANDROID11系统LOGO-kernel之后卡住的问题
2022-03-02
3651
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
英国威廉希尔公司网站
william hill官网 版块
小组
免费开发板试用
ebook
直播
搜索
登录
