adevicerockchipcommonBoardConfig.mk
+++ bdevicerockchipcommonBoardConfig.mk
#for 3G/4G modem dongle support
-BOARD_HAVE_DONGLE := false
+BOARD_HAVE_DONGLE := true
然后编译报错
PLATFORM_VERSION_CODENAME=REL
PLATFORM_VERSION= 11
TARGET_PRODUCT = rk3568_r
TARGET_BUILD_VARIANT = userdebug
TARGET_BUILD_TYPE =释放
TARGET_ARCH = arm64
TARGET_ARCH_VARIANT = armv8-一个
TARGET_CPU_VARIANT =皮质-A55
TARGET_2ND_ARCH =手臂
TARGET_2ND_ARCH_VARIANT = armv8-2a
TARGET_2ND_CPU_VARIANT =皮质-A55
HOST_ARCH = x86_64的
HOST_2ND_ARCH = 86
HOST_OS = Linux的
HOST_OS_EXTRA=Linux-5.4.0-91-generic-x86_64-Ubuntu-18.04.6-LTS
HOST_CROSS_OS=windows
HOST_CROSS_ARCH=x86
HOST_CROSS_2ND_ARCH=x86_64
HOST_BUILD_TYPE=发布
BUILD_ID=RQ3A.210705.001
OUT_DIR=out
[ 30% 283/935] 目标 C++: u***_dongle <= external/ u***_modeswitch/u***_dongle/Misc.cpp
失败:out/target/product/rk3568_r/obj/EXECUTABLES/u***_dongle_intermediates/Misc.o
/bin/bash -c "(prebuilts/clang/host/linux-x86/clang-r383902b1/bin/clang-tidy -warnings-as-errors=clang-analyzer-security*,cert-* -quiet -extra-arg -before=-fno-caret-diagnostics -extra-arg-before=-D__clang_analyzer__ -extra-arg-before=-Xclang -extra-arg-before=-analyzer-config -extra-arg-before=-Xclang -extra- arg-before=c++-temp-dtor-inlining=false -checks=-*,clang-diagnostic-unused-command-line-argument,google*,-google-build-using-namespace,-google-default-arguments, -google-explicit-constructor,-google-readability*,-google-runtime-int,-google-runtime-references,-*,clang-analyzer-security*,cert-*,-cert-err34-c,-cert -err58-cpp,-cert-env33-c 外部/u***_modeswitch/u***_dongle/Misc。cpp -- -I external/u***_modeswitch/u***_dongle -I out/target/product/rk3568_r/obj/EXECUTABLES/u***_dongle_intermediates -I out/target/product/rk3568_r/gen/EXECUTABLES/u***_dongle_intermediates -Isystem/core/libsysutils/include -Isystem /core/libsysutils/include -Iframeworks/native/libs/binder/include -Isystem/core/base/include -Isystem/core/libcutils/include_vndk -Isystem/core/libutils/include -Isystem/core/libbacktrace/include -Isystem /core/liblog/include_vndk -Isystem/core/libsystem/include -Isystem/core/libprocessgroup/include -Iout/soong/.intermediates/frameworks/native/libs/binder/libbinder/android_vendor。30_arm64_armv8-a_cortex-a55_shared/gen/aidl -Isystem/core/libcutils/include_vndk -Isystem/core/libprocessgroup/include -Isystem/core/libcutils/include -Isystem/core/liblog/include_vndk -Iexternal/selinux/libselinux/include - Isystem/core/libutils/include -Isystem/core/libbacktrace/include -Isystem/core/liblog/include_vndk -Isystem/core/libsystem/include -Isystem/core/libcutils/include_vndk -Isystem/core/libprocessgroup/include -Isystem/ core/base/include -Iexternal/fmtlib/include -Isystem/libhwbinder/include -Isystem/libhwbinder/include -Iexternal/libcxx/include -Iexternal/libcxxabi/include -isystem out/soong/.intermediates/bionic/libc/libc。 llndk/android_vendor。30_arm64_armv8-a_cortex-a55_shared/gen/include -isystem bionic/libc/kernel/android/scsi -isystem bionic/libc/kernel/android/uapi -isystem bionic/libc/kernel/uapi -isystem bionic/libc/kernel/uapi/ asm-arm64 -Iexternal/libcxxabi/include -isystem out/target/product/rk3568_r/obj/include -c -Werror=implicit-function-declaration -DANDROID -fmessage-length=0 -W -Wall -Wno-unused -Winit -self -Wpointer-arith -no-canonical-prefixes -DNDEBUG -UDEBUG -fno-exceptions -Wno-multichar -O2 -g -fno-strict-aliasing -Werror=date-time -Werror=pragma-pack -Werror=pragma -pack-suspicious-include -fdebug-prefix-map=/proc/self/cwd= -D__compiler_offsetof=__builtin_offsetof -faddrsig -Werror=int-conversion -fexperimental-new-pass-manager -Wno-reserved-id-macro -Wno -unused-command-line-argument -fcolor-diagnostics -Wno-sign-compare -Wno-defaulted-function-deleted-Wno-inconsistent-missing-override -Wno-c99-designator -ftrivial-auto-var-init=zero -enable-trivial-auto-var-init-zero-knowing-it-will-be-removed-from-clang -ffunction-sections -fdata-sections -fno-short-enums -funwind-tables -fstack-protector-strong -Wa,--noexecstack -D_FORTIFY_SOURCE=2 -Wstrict-aliasing=2 -Werror=return-type -Werror=non -virtual-dtor -Werror=address -Werror=sequence-point -Werror=format-security -nostdlibinc -march=armv8-a -mcpu=cortex-a55 -Bprebuilts/gcc/linux-x86/aarch64/aarch64-linux-android -4。9/aarch64-linux-android/bin -Wsign-promo -Wimplicit-fallthrough -D_LIBCPP_ENABLE_THREAD_SAFETY_ANNOTATIONS -Wno-gnu-include-next -fvisibility-inlines-hidden -std=gnu++17 -fno-rtti -Werror -Wall -Wno -missing-field-initializers -Wno-unused-variable -Wno-unused-parameter -Werror=format -DUSE_USB_MODE_SWITCH -D__ANDROID_VNDK__ -fPIE -Wno-enum-compare -Wno-enum-compare-switch -Wno-null-pointer-arithmetic -Wno-null-dereference -Wno-pointer-compare -Wno-xor-used-as-pow -Wno-final-dtor-non-final-class -target aarch64-linux-android30 -Werror=int-to-pointer- cast -Werror=pointer-to-int-cast -Werror=fortify-source -Werror=临时地址 -Werror=return-type -Wno-tautological-constant-compare -Wno-tautological-type-limit-compare - Wno-reorder-init-list -Wno-implicit-int-float-conversion -Wno-int-in-bool-context -Wno-sizeof-array-div-Wno-tautological-overlap-compare -Wno-deprecated-copy -Wno-range-loop-construct -Wno-misleading-indentation -Wno-zero-as-null-pointer-constant -Wno-deprecated-anon-enum-enum -conversion -Wno-deprecated-enum-enum-conversion -Wno-string-compare -Wno-enum-enum-conversion -Wno-enum-float-conversion -Wno-pessimizing-move) &&(PWD=/proc/self/cwd prebuilts/clang/host/linux-x86/clang-r383902b1/bin/clang++ -I external/u***_modeswitch/u***_dongle -I out/target/product/rk3568_r/obj/EXECUTABLES/u***_dongle_intermediates -I out/target/product/rk3568_r/gen/EXECUTABLES/u***_dongle_intermediates -Isystem/core/libsysutils/include -Isystem/core/libsysutils/include -Iframeworks/native/libs/binder/include -Isystem/core/base/include -Isystem/核心/libcutils/include_vndk -Isystem/core/libutils/include -Isystem/core/libbacktrace/include -Isystem/core/liblog/include_vndk -Isystem/core/libsystem/include -Isystem/core/libprocessgroup/include -Iout/soong/ .intermediates/frameworks/native/libs/binder/libbinder/android_vendor。30_arm64_armv8-a_cortex-a55_shared/gen/aidl -Isystem/core/libcutils/include_vndk -Isystem/core/libprocessgroup/include -Isystem/core/libcutils/include -Isystem/core/liblog/include_vndk -Iexternal/selinux/libselinux/include - Isystem/core/libutils/include -Isystem/core/libbacktrace/include -Isystem/core/liblog/include_vndk -Isystem/core/libsystem/include -Isystem/core/libcutils/include_vndk -Isystem/core/libprocessgroup/include -Isystem/ core/base/include -Iexternal/fmtlib/include -Isystem/libhwbinder/include -Isystem/libhwbinder/include -Iexternal/libcxx/include -Iexternal/libcxxabi/include -isystem out/soong/.intermediates/bionic/libc/libc。 llndk/android_vendor。30_arm64_armv8-a_cortex-a55_shared/gen/include -isystem bionic/libc/kernel/android/scsi -isystem bionic/libc/kernel/android/uapi -isystem bionic/libc/kernel/uapi -isystem bionic/libc/kernel/uapi/ asm-arm64 -Iexternal/libcxxabi/include -isystem out/target/product/rk3568_r/obj/include -c -Werror=implicit-function-declaration -DANDROID -fmessage-length=0 -W -Wall -Wno-unused -Winit -self -Wpointer-arith -no-canonical-prefixes -DNDEBUG -UDEBUG -fno-exceptions -Wno-multichar -O2 -g -fno-strict-aliasing -Werror=date-time -Werror=pragma-pack -Werror=pragma -pack-suspicious-include -fdebug-prefix-map=/proc/self/cwd= -D__compiler_offsetof=__builtin_offsetof -faddrsig -Werror=int-conversion -fexperimental-new-pass-manager -Wno-reserved-id-macro -Wno -unused-command-line-argument -fcolor-diagnostics -Wno-sign-compare -Wno-defaulted-function-deleted-Wno-inconsistent-missing-override -Wno-c99-designator -ftrivial-auto-var-init=zero -enable-trivial-auto-var-init-zero-knowing-it-will-be-removed-from-clang -ffunction-sections -fdata-sections -fno-short-enums -funwind-tables -fstack-protector-strong -Wa,--noexecstack -D_FORTIFY_SOURCE=2 -Wstrict-aliasing=2 -Werror=return-type -Werror=non -virtual-dtor -Werror=address -Werror=sequence-point -Werror=format-security -nostdlibinc -march=armv8-a -mcpu=cortex-a55 -Bprebuilts/gcc/linux-x86/aarch64/aarch64-linux-android -4。9/aarch64-linux-android/bin -Wsign-promo -Wimplicit-fallthrough -D_LIBCPP_ENABLE_THREAD_SAFETY_ANNOTATIONS -Wno-gnu-include-next -fvisibility-inlines-hidden -std=gnu++17 -fno-rtti -Werror -Wall -Wno -missing-field-initializers -Wno-unused-variable -Wno-unused-parameter -Werror=format -DUSE_USB_MODE_SWITCH -D__ANDROID_VNDK__ -fPIE -Wno-enum-compare -Wno-enum-compare-switch -Wno-null-pointer-arithmetic -Wno-null-dereference -Wno-pointer-compare -Wno-xor-used-as-pow -Wno-final-dtor-non-final-class -target aarch64-linux-android30 -Werror=int-to-pointer- cast -Werror=pointer-to-int-cast -Werror=fortify-source -Werror=临时地址 -Werror=return-type -Wno-tautological-constant-compare -Wno-tautological-type-limit-compare - Wno-reorder-init-list -Wno-implicit-int-float-conversion -Wno-int-in-bool-context -Wno-sizeof-array-div-Wno-tautological-overlap-compare -Wno-deprecated-copy -Wno-range-loop-construct -Wno-misleading-indentation -Wno-zero-as-null-pointer-constant -Wno-deprecated-anon-enum-enum -conversion -Wno-deprecated-enum-enum-conversion -Wno-string-compare -Wno-enum-enum-conversion -Wno-enum-float-conversion -Wno-pessimizing-move -MD -MF out/target/product/ rk3568_r/obj/EXECUTABLES/u***_dongle_intermediates/Misc.d -o out/target/product/rk3568_r/obj/EXECUTABLES/u***_dongle_intermediates/Misc.o external/u***_modeswitch/u***_dongle/Misc.cpp)"
错误:声明使用标识符“_FORTIFY_SOURCE”,这是一个保留标识符 [cert-dcl37-c,-warnings-as-errors]
错误:声明使用标识符“_LIBCPP_ENABLE_THREAD_SAFETY_ANNOTATIONS”,这是一个保留标识符 [cert-dcl37-c,- warnings-as-errors]
注意:此修复将不会应用,因为它与另一个修复
错误重叠:声明使用标识符“__ANDROID_VNDK__”,这是一个保留标识符 [cert-dcl37-c,-warnings-as-errors]
错误重叠:声明使用标识符“__clang_analyzer__”,这是一个保留标识符 [cert-dcl37-c,-warnings-as-errors]
注意:此修复将不会应用,因为它与另一个修复重叠
错误:声明使用标识符“__compiler_offsetof”,这是一个保留标识符 [cert-dcl37-c,-warnings-as-errors]
错误:声明使用标识符“_FORTIFY_SOURCE” ,这是一个保留标识符 [cert-dcl51-cpp,-warnings-as-errors]
错误:声明使用标识符 '_LIBCPP_ENABLE_THREAD_SAFETY_ANNOTATIONS',这是一个保留标识符 [cert-dcl51-cpp,-warnings-as-errors]
错误重叠:声明使用标识符“__ANDROID_VNDK__”,这是一个保留标识符 [cert-dcl51-cpp,-warnings-as-errors]
错误:声明使用标识符“__clang_analyzer__”,这是一个保留标识符 [cert-dcl51-cpp,-warnings-as-errors]
错误:声明使用标识符“__compiler_offsetof” ,这是一个保留标识符 [cert-dcl51-cpp,-warnings-as-errors]
注意:此修复将不会被应用,因为它与另一个修复重叠
错误:声明使用标识符“_LIBCPP_ENABLE_THREAD_SAFETY_ANNOTATIONS”,这是一个保留标识符 [cert-dcl37-c,-warnings- as-errors]
错误:声明使用标识符“__ANDROID_VNDK__”,这是一个保留标识符 [cert-dcl37-c,-warnings-as-errors]
错误:声明使用标识符“__clang_analyzer__” ,这是一个保留标识符 [cert-dcl37-c,-warnings-as-errors]
错误重叠:声明使用标识符'__compiler_offsetof',这是一个保留标识符 [cert -dcl37-c,-warnings-as-errors]
错误重叠:声明使用标识符“_FORTIFY_SOURCE”,这是一个保留标识符 [cert-dcl51-cpp,-warnings-作为错误]
错误:声明使用标识符“_LIBCPP_ENABLE_THREAD_SAFETY_ANNOTATIONS”,这是一个保留标识符 [cert-dcl51-cpp,-warnings-as-errors]
错误:声明使用标识符“__ANDROID_VNDK__” ,这是一个保留标识符 [cert-dcl51-cpp,-warnings-as-errors]
错误重叠:声明使用标识符 '__clang_analyzer__',这是一个保留标识符 [cert -dcl51-cpp,-warnings-as-errors]
错误重叠:声明使用标识符“__compiler_offsetof”,这是一个保留标识符 [cert-dcl51-cpp,-warnings-作为错误]
15:58:06 ninja failed with: exit status 1
#### failed to build some targets (01:38 (mm:ss)) ####
修改:externalu***_modeswitchu***_dongleAndroid.mk
LOCAL_PATH:= $(call my-dir)
common_src_files :=
NetlinkManager.cpp
NetlinkHandler.cpp
MiscManager.cpp
Misc.cpp
G3Dev.cpp
common_shared_libraries :=
libsysutils
libbinder
libcutils
liblog
libselinux
libutils
libbase
libhwbinder
common_cflags := -Werror -Wall -Wno-missing-field-initializers -Wno-unused-variable -Wno-unused-parameter
-common_local_tidy_flags := -warnings-as-errors=clang-analyzer-security*,cert-*
+ # common_local_tidy_flags := -warnings-as-errors=clang-analyzer-security*,cert-*
common_local_tidy_checks := -*,clang-analyzer-security*,cert-*,-cert-err34-c,-cert-err58-cpp
common_local_tidy_checks += ,-cert-env33-c
包括 $(CLEAR_VARS)
LOCAL_ADDITIONAL_DEPENDENCIES := $(LOCAL_PATH)/Android.mk LOCAL_MODULE
:= u***_dongle
LOCAL_PROPRIETARY_MODULE := true
LOCAL_CLANG := true
LOCAL_TIDY := true
LOCAL_TIDY_FLAGS_flaGS_gSDYs) $(
:= $(common_local_tidy_checks)
LOCAL_SRC_FILES :=
main.cpp
$(common_src_files)
LOCAL_INIT_RC := u***_dongle.rc
LOCAL_CFLAGS := $(common_cflags)
LOCAL_CFLAGS += -Werror=format
LOCAL_CFLAGS += -DUSE_USB_MODE_SWITCH
LOCAL_SHARED_LIBRARIES := $( common_shared_ex_libraries
common_local_flags 这一个
就可以掉编译通过了。
然后编译报错
TARGET_ARCH = arm64
TARGET_2ND_ARCH =手臂
HOST_ARCH = x86_64的
HOST_2ND_ARCH = 86
HOST_OS = Linux的
HOST_CROSS_ARCH=x86
HOST_BUILD_TYPE=发布
OUT_DIR=out
common_src_files :=
NetlinkManager.cpp
NetlinkHandler.cpp
MiscManager.cpp
Misc.cpp
G3Dev.cpp
libsysutils
libbinder
libcutils
liblog
libselinux
libutils
libbase
libhwbinder
包括 $(CLEAR_VARS)
:= u***_dongle
LOCAL_CLANG := true
LOCAL_TIDY := true
LOCAL_SRC_FILES :=
main.cpp
$(common_src_files)
就可以掉编译通过了。
