李鑫
7年用户 1340经验值
怎样在RK3568开发板上去实现一种双以太网的设计
怎样在RK3568开发板上去实现一种双以太网的设计?
回帖(1)
张西子
2022-3-2 16:22:39
RK3568kernelarcharm64bootdtsrockchiprk3568-evb1-ddr4-v10.dtsi
//重点是复位RESET
&gmac0 {
        phy-mode = "rgmii";
        clock_in_out = "output";
        snps,reset-gpio = <&gpio1 RK_PB0 GPIO_ACTIVE_LOW>;
        snps,reset-active-low;
        /* Reset time is 20ms, 100ms for rtl8211f */
        snps,reset-delays-us = <0 20000 100000>;
        assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>;
        assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&cru CLK_MAC0_2TOP>;
        assigned-clock-rates = <0>, <125000000>;
        pinctrl-names = "default";
        pinctrl-0 = <&gmac0_miim
                     &gmac0_tx_bus2
                     &gmac0_rx_bus2
                     &gmac0_rgmii_clk
                     &gmac0_rgmii_bus>;
        tx_delay = <0x3c>;
        rx_delay = <0x2f>;
        phy-handle = <&rgmii_phy0>;
        status = "okay";
&mdio0 {
        rgmii_phy0: phy@0 {
                compatible = "ethernet-phy-ieee802.3-c22";
                reg = <0x0>;
&gmac1 {
        phy-mode = "rgmii";
        snps,reset-gpio = <&gpio1 RK_PB1 GPIO_ACTIVE_LOW>;
        assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>;
        assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru CLK_MAC1_2TOP>;
        pinctrl-0 = <&gmac1m1_miim
                     &gmac1m1_tx_bus2
                     &gmac1m1_rx_bus2
                     &gmac1m1_rgmii_clk
                     &gmac1m1_rgmii_bus>;
        tx_delay = <0x4f>;
        rx_delay = <0x26>;
        phy-handle = <&rgmii_phy1>;
        status = "okay";
&mdio1 {
        rgmii_phy1: phy@0 {
                reg = <0x0>;
详细参考:rk3568RKDocscommonGMAC
Rockchip_Developer_Guide_Ethernet_CN.pdf
Rockchip_Developer_Guide_Linux_GMAC_CN.pdf
Rockchip_Developer_Guide_Linux_GMAC_Mode_Configuration_CN.pdf
Rockchip_Developer_Guide_Linux_GMAC_RGMII_Delayline_CN.pdf
Rockchip_Developer_Guide_Linux_GMAC_RGMII_Delayline_EN.pdf
