登录
ningkui
12年用户
831经验值
擅长:电源/新能源
私信
关注
如何去实现GM8775 MIPI转LVDS屛的设计呢
开启该帖子的消息推送
MIPI
如何去实现GM8775 MIPI转LVDS屛的设计呢?有哪些步骤?
褚毕赋
2022-3-2 14:58:24
平台:RK3566 Android11
GM8775 MIPI转LVDS
屏:LVDS 1920x1200 分辨率
1.先看屏规格书,计算后将屏分辨率及前后肩填入PC端工具进行转换
根据屏规格书把屏参写入工具生成一段初始化参数
注意检查:1.硬件使用的外部晶振还是MIPI时钟
2.硬件使用的是用的IIC还是command
2.将工具生成的屏参写入平台所使用的dts文件
IC是通过mipi转LVDS,在dts中配置成mipi通道
2.1 dts配置如下:
&dsi0 {
status = "okay";
panel@0 {
status = "okay";
reg = <0>;
backlight = <&backlight>;
//power-supply=<&vcc_3v3>;
enable-gpios = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>;
prepare-delay-ms = <100>;
reset-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_HIGH>;
reset-delay-ms = <100>;
init-delay-ms = <100>;
enable-delay-ms = <100>;
pinctrl-names = "default";
pinctrl-0 = <&lcd_enable_gpio>, <&lcd_rst_gpio>;
dsi,flags = <(MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_BURST |
MIPI_DSI_MODE_LPM | MIPI_DSI_MODE_EOT_PACKET)>;
dsi,format =
dsi,lanes = <4>;
panel-init-sequence = [
23 00 02 27 AA
23 00 02 48 02
23 00 02 B6 20
23 00 02 01 80
23 00 02 02 B0
23 00 02 03 47
23 00 02 04 46
23 00 02 05 14
23 00 02 06 46
23 00 02 07 00
23 00 02 08 0A
23 00 02 09 0F
23 00 02 0A 0A
23 00 02 0B 82
23 00 02 0C 13
23 00 02 0D 01
23 00 02 0E 80
23 00 02 0F 20
23 00 02 10 20
23 00 02 11 03
23 00 02 12 1B
23 00 02 13 63
23 00 02 14 01
23 00 02 15 23
23 00 02 16 40
23 00 02 17 00
23 00 02 18 01
23 00 02 19 23
23 00 02 1A 40
23 00 02 1B 00
23 00 02 1E 46
23 00 02 51 30
23 00 02 1F 10
23 00 02 2A 01 //如上为工具生成的初始化代码
//如下为SSR展频,不加可能点不亮
23 00 02 6A 08
23 00 02 6C 9E
23 00 02 6D 07
23 00 02 6E 00
23 00 02 6F 8A
23 00 02 70 19
23 64 02 71 00
disp_timings1: display-timings {
native-mode = <&timing2>;
timing2: timing2 {
clock-frequency = <144250000>;
hactive = <1920>;
vactive = <1200>;
hback-porch = <70>;
hsync-len = <20>;
hfront-porch = <70>;
vback-porch = <10>;
vfront-porch = <10>;
vsync-len = <15>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
pixelclk-active = <0>;
修改后编译烧录看看效果
FAQ:
1.GM8775C拥有自测模式,不需要MIPI数据就能显示,初步调试可优先进入彩条模式,排除后端问题 将 23 00 02 2A 01 修改为 23 00 02 2A 4D
2.GM8775C的data di必须是0x23 ,发送完后示波器测量:CLK/DATA 是否有输出
3.颜色显示异常,可在屏规格书上查找屏支持的LVDS数据格式是JEIDA或是VESA
4.双路LVDS出现显示重影,请排除LVDS奇偶是不是反了,可对调下ODD/EVEN试下
平台:RK3566 Android11
GM8775 MIPI转LVDS
2.1 dts配置如下:
&dsi0 {
status = "okay";
panel@0 {
status = "okay";
reg = <0>;
dsi,format =
dsi,lanes = <4>;
23 00 02 27 AA
23 00 02 48 02
23 00 02 B6 20
23 00 02 01 80
23 00 02 02 B0
23 00 02 03 47
23 00 02 04 46
23 00 02 05 14
23 00 02 06 46
23 00 02 07 00
23 00 02 08 0A
23 00 02 09 0F
23 00 02 0A 0A
23 00 02 0B 82
23 00 02 0C 13
23 00 02 0D 01
23 00 02 0E 80
23 00 02 0F 20
23 00 02 10 20
23 00 02 11 03
23 00 02 12 1B
23 00 02 13 63
23 00 02 14 01
23 00 02 15 23
23 00 02 16 40
23 00 02 17 00
23 00 02 18 01
23 00 02 19 23
23 00 02 1A 40
23 00 02 1B 00
23 00 02 1E 46
23 00 02 51 30
23 00 02 1F 10
//如下为SSR展频,不加可能点不亮
23 00 02 6A 08
23 00 02 6C 9E
23 00 02 6D 07
23 00 02 6E 00
23 00 02 6F 8A
23 00 02 70 19
23 64 02 71 00
timing2: timing2 {
hactive = <1920>;
vactive = <1200>;
hback-porch = <70>;
hsync-len = <20>;
vback-porch = <10>;
vsync-len = <15>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <0>;
修改后编译烧录看看效果
FAQ:
rotate(-90deg);
回复
相关问答
MIPI
RK3588
mipi
接口使用
GM8775
C
转
lvds
屏如何
实现
呢
2023-02-20
1845
如何
去
实现
RK3288与
LVDS
屛
的适配设计
呢
2022-03-04
1069
如何
去
实现
edp主屏与
lvds
副
屛
的同显设计
呢
2022-03-03
1621
怎样通过IC转换将
MIPI
转换成
LVDS
呢
2022-03-07
866
求
LVDS
转
mipi
dsi的芯片
2015-11-03
8804
如何
去
实现
RK3288系统
MIPI
转
EDP的设计
呢
2022-03-03
1182
怎样
去
设置LCD
屛
的设备树
呢
2022-02-11
1743
在RK3288平台上如何采用裸机
实现
LVDS
和
MIPI
接口的LCD显示?
2022-03-04
1187
在STM32F103上怎样
去
实现
LCD12864
屛
的设计
呢
2022-01-21
847
请问
MIPI
屏怎么反转
2019-02-22
3063
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
英国威廉希尔公司网站
william hill官网 版块
小组
免费开发板试用
ebook
直播
搜索
登录
