张虎豹
7年用户 1621经验值
在RK3288主板Debian 9.13系统上如何调用CPU硬解进行网络摄像头视频流解码?
回帖(1)
陈丹丽
2022-3-3 09:28:43
在RK3288主板Debian 9.13系统上想调用CPU硬解进行网络摄像头视频流进行解码,本来尝试用FFmpeg+Mpp方式进行,但ffmpeg集成mpp的解码器,解码后的格式为AV_PIX_FMT_DRM_PRIME,也就是 DRM 帧数据,要进行图像识别还得通过CPU转码为RGB或BGR格式。按照这个过程下来,光解码CPU的占用率就很高。。。后来在Rockchip的wiki_Mpp上看到,对Mpp有如下的一段说明:
We offer the Gstreamer Rockchip, it is a standard Gstreamer plugin for the hardware decoder and encoder at Rockchip platform. I would suggest all the user in the Linux don’t develop the MPP directly unless you know what you are doing. Choose Gstreamer rocckchip in you convenience.
简而言之就是建议Linux下的用户不要直接使用MPP进行开发,推荐用标准的Gstreamer插件。了解到,原来OpenCV可以集成Gstreamer进行使用。运行Gstreamer的例子发现,RK3288解码4K画面是很流畅。
  • Debian GNU/Linux 9.13 (stretch) armv7l
  • OpenCV 3.4.11
  • Gstreamer 1.10.4
Gstreamer解码RTSP命令
#!/bin/sh
gst-launch-1.0 rtspsrc location=rtsp://192.168.31.163:8554/ !
        ! rtph264depay ! h264parse ! mppvideodec ! rkximagesink sync=false
安装需要的依赖包
apt-get update
apt-get install -y libgstreamer-plugins-base1.0-dev
                libpng16-16
        build-essential
        cmake
        git
        pkg-config
        libjpeg-dev
                libgtk2.0-dev
        libv4l-dev
        libatlas-base-dev
        gfortran
        libhdf5-dev
        libtiff5-dev
                libtbb-dev
                libeigen3-dev
编译OpenCV
cd到3.4.11.zip文件目录下,执行如下命令:
unzip 3.4.11.zip # 解压zip压缩包
cd opencv-3.4.11 # 切换到源码包目录
mkdir build && cd build # 创建build目录并切换进去
cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local -D INSTALL_C_EXAMPLES=OFF -D WITH_GSTREAMER=ON -D WITH_GTK_2_X=ON -D WITH_GTHREAD=ON -D WITH_TBB=ON -D WITH_OPENGL=ON  .. # 配置opencv 此处注意有两个点
如果配置成功的话,应该会有如下输出:
--   OpenCV modules:
--     To be built:                 calib3d core dnn features2d flann highgui imgcodecs imgproc ml objdetect photo shape stitching superres ts video videoio videostab
--     Disabled:                    world
--     Disabled by dependency:      -
--     Unavailable:                 cudaarithm cudabgsegm cudacodec cudafeatures2d cudafilters cudaimgproc cudalegacy cudaobjdetect cudaoptflow cudastereo cudawarping cudev java js python2 python3 viz
--     Applications:                tests perf_tests apps
--     Documentation:               NO
--     Non-free algorithms:         NO
--   GUI:
--     GTK+:                        YES (ver 2.24.31) # 识别到GTK+ 2.0 如果没有会无法显示
--       GThread :                  YES (ver 2.50.3)
--       GtkGlExt:                  NO
--     OpenGL support:              NO
--     VTK support:                 NO
--   Media I/O:
--     ZLib:                        /usr/lib/arm-linux-gnueabihf/libz.so (ver 1.2.8)
--     JPEG:                        /usr/lib/libjpeg.so (ver 62)
--     WEBP:                        build (ver encoder: 0x020f)
--     PNG:                         /usr/lib/arm-linux-gnueabihf/libpng.so (ver 1.6.28)
--     TIFF:                        /usr/lib/arm-linux-gnueabihf/libtiff.so (ver 42 / 4.0.8)
--     JPEG 2000:                   build (ver 1.900.1)
--     OpenEXR:                     build (ver 2.3.0)
--     HDR:                         YES
--     SUNRASTER:                   YES
--     PXM:                         YES
--   Video I/O:
--     DC1394:                      NO
--     FFMPEG:                      YES # 系统自带了FFMPEG 所以会开启
--       avcodec:                   YES (ver 58.35.100)
--       avformat:                  YES (ver 58.20.100)
--       avutil:                    YES (ver 56.22.100)
--       swscale:                   YES (ver 5.3.100)
--       avresample:                YES (ver 4.0.0)
--     GStreamer:                   YES # 识别到Gstreamer
--       base:                      YES (ver 1.10.4)
--       video:                     YES (ver 1.10.4)
--       app:                       YES (ver 1.10.4)
--       riff:                      YES (ver 1.10.4)
--       pbutils:                   YES (ver 1.10.4)
--     libv4l/libv4l2:              NO
--     v4l/v4l2:                    linux/videodev2.h
--   Parallel framework:            TBB (ver 4.3 interface 8006)
--   Trace:                         YES (with Intel ITT)
--   Other third-party libraries:
--     Lapack:                      NO
--     Eigen:                       YES (ver 3.3.2)
--     Custom HAL:                  NO
--     Protobuf:                    build (3.5.1)
--   OpenCL:                        YES (no extra features)
--     Include path:                /opencv-3.4.11/3rdparty/include/opencl/1.2
--     Link libraries:              Dynamic load
--   Python (for build):            /usr/bin/python2.7
--   Java:
--     ant:                         NO
--     JNI:                         NO
--     Java wrappers:               NO
--     Java tests:                  NO
--   Install to:                    /usr/local
-- Configuring done
-- Generating done
-- Build files have been written to: */opencv-3.4.11/build
执行如下命令进行编译安装
make -j4 # 编译
make install # 安装opencv库到/usr/local下
配置OpenCV
cd /etc/ld.so.conf.d/ # 切换目录
touch opencv.conf # 新建opencv配置文件
echo /usr/local/lib/ > opencv.conf # 填写opencv编译后库所在的路径
sudo ldconfig # 使配置文件生效
测试代码
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
using namespace std;
using namespace cv;
int main()
    string gsurl = "rtspsrc location=rtsp://192.168.31.163:8554/ latency=0 ! rtph264depay ! h264parse ! mppvideodec ! videoconvert ! video/x-raw,format=(string)BGR  ! appsink sync=false";  // 也可以使用 rgaconvert
    VideoCapture cap = VideoCapture(gsurl,cv::CAP_GSTREAMER);
    if(!cap.isOpened())
        std::cout<<"cannot open captrue..."<
        return 0;
    int fps = cap.get(5);
    cout<<"fps:"<
    Mat frame;
    bool readreturn = false;
    while(1)
        readreturn = cap.read(frame);
        imshow("RTSP",frame);
        if (cvWaitKey(30) == 27)
            cout << "Esc key is pressed by user" << endl;
            break;
    cap.release();
    return 0;
使用如下命令进行编译
g++ main.cpp `pkg-config --cflags --libs opencv`
