yqdedli
9年用户 915经验值
擅长:控制/MCU
如何去实现HDMI &codec 喇叭同时输出的功能呢
如何去实现HDMI &codec 喇叭同时输出的功能呢?
回帖(1)
钱一辰
2022-3-3 10:43:27
因为HDMI I2S & CODEC I2S 在芯片内部都是同一个I2S,
因此CODEC有声音时候,也有声音通过I2S 发送到HDMI,
这样取消掉HDMI Audio 检测即可实现HDMI &codec 喇叭同时输出。
diff --git a/services/java/com/android/server/WiredAccessoryManager.java b/services/java/com/android/server/WiredAccessoryManager.java
index c8d3510..2fb231e 100644
--- a/services/java/com/android/server/WiredAccessoryManager.java
+++ b/services/java/com/android/server/WiredAccessoryManager.java
@@ -374,7 +374,7 @@ final class WiredAccessoryManager implements WiredAccessoryCallbacks {
// If the kernel does not have an "hdmi_audio" switch, just fall back on the older
// "hdmi" switch instead.
-            uei = new UEventInfo(NAME_HDMI_AUDIO, BIT_HDMI_AUDIO, 0);
+/*            uei = new UEventInfo(NAME_HDMI_AUDIO, BIT_HDMI_AUDIO, 0);
if (uei.checkSwitchExists()) {
retVal.add(uei);
} else {
@@ -385,7 +385,7 @@ final class WiredAccessoryManager implements WiredAccessoryCallbacks {
Slog.w(TAG, "This kernel does not have HDMI audio support");
return retVal;
