Platform: ROCKCHIP
OS: Android 6.0 Kernel: 3.10.92 user版sd固件升級啟動之后開機出現如下error log: [ 3.036440] rockchip_i2c ff150000.i2c: i2c is not in idle(state = 3) [ 3.036451] ov5640_front_3(rk_cam_sensor:333): read reg(0x300a val:0x0) failed, try to read again! [ 3.036469] ov5640_front_3(rk_cam_sensor:697): read chip id failed [ 3.036560] ret: 0 [ 3.465624] binder: 161:161 transaction failed 29189, size 0-0 [ 4.449713] binder: 161:161 transaction failed 29189, size 0-0 [ 5.433801] binder: 161:161 transaction failed 29189, size 0-0 [ 6.417887] binder: 161:161 transaction failed 29189, size 0-0 [ 7.401973] binder: 161:161 transaction failed 29189, size 0-0 [ 8.386066] binder: 161:161 transaction failed 29189, size 0-0 [ 8.704273] [otg id chg] last id -1 current id 1 [ 8.704291] PortPower off [ 8.704298] rk_battery_charger_detect_cb , battery_charger_detect 6 [ 8.803721] Using Buffer DMA mode [ 8.803733] Periodic Transfer Interrupt Enhancement - disabled [ 8.803739] Multiprocessor Interrupt Enhancement - disabled [ 8.803745] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 8.803752] ^^^^^^^^^^^^^^^^^Device Mode [ 9.294675] ***************vbus detect***************** [ 9.296859] rk_battery_charger_detect_cb , battery_charger_detect 1 [ 9.370153] binder: 161:161 transaction failed 29189, size 0-0 [ 10.354240] binder: 161:161 transaction failed 29189, size 0-0 [ 11.338327] binder: 161:161 transaction failed 29189, size 0-0 [ 12.322412] binder: 161:161 transaction failed 29189, size 0-0 [ 13.306497] binder: 161:161 transaction failed 29189, size 0-0 [ 14.290582] binder: 161:161 transaction failed 29189, size 0-0 [ 15.274667] binder: 161:161 transaction failed 29189, size 0-0 [ 16.258752] binder: 161:161 transaction failed 29189, size 0-0 [ 17.242836] binder: 161:161 transaction failed 29189, size 0-0 原因: system分區默認是512M RKTools/linux/Linux_Pack_Firmware/rockdev/parameter: 0x00100000@0x00092000(system) 0x00100000,單位是512. 而user版本編譯出來的system分區大小超過了512M 解決方法: 擴大system分區. diff --git a/linux/Linux_Pack_Firmware/rockdev/parameter b/linux/Linux_Pack_Firmware/rockdev/parameter index 174241b..1048328 100644 --- a/linux/Linux_Pack_Firmware/rockdev/parameter +++ b/linux/Linux_Pack_Firmware/rockdev/parameter @@ -7,4 +7,4 @@ ATAG: 0x60000800 MACHINE: 3288 CHECK_MASK: 0x80 PWR_HLD: 0,0,A,0,1 -CMDLINE:console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00100000@0x00092000(system),0x00008000@0x00192000(metadata),0x00020000@0x0039A000(radical_update),-@0x003BA000(userdata) +CMDLINE:console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00010000@0x00016000(boot),0x00010000@0x00026000(recovery),0x0001a000@0x00036000(backup),0x00040000@0x00050000(cache),0x00002000@0x00090000(kpanic),0x00200000@0x00092000(system),0x00008000@0x00292000(metadata),0x00020000@0x0049A000(radical_update),-@0x004BA000(userdata) |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1767 浏览 0 评论
2288 浏览 1 评论
1955 浏览 1 评论
3294 浏览 1 评论
4095 浏览 1 评论
GMT+8, 2025-1-13 21:20 , Processed in 0.462700 second(s), Total 40, Slave 34 queries .
